Dumb question regarding coil tips
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by R_W, Oct 13, 2024.
  1. R_W
    R_W Member
    82
    25
    @rjparker - Thanks for the photo. I thought that may be what it looks like, which is why I haven't tried.
    My reluctance to cut it as you and @Tombukt2 suggested is that it's like 2.5" long and I'm not sure how to cut all the way down. My Exacto knife and the ones I see in the stores are not long enough, nor are my scissors. I could try with a long kitchen knife, but the point isn't that sharp and I'm afraid it would more push the thing down.
    If you have a suggestion of a tool a mechanic would have... I have access to Harbor Freight, Ace, Home Depot, Advance, Autozone, O'Reilly, NAPA and Amazon. A few days ago at @ASRDogman's suggestion, I tried fashioning a hook out of some wire and tonight, I've cut up a heavy gauge tomato cage which is made of wire which is probably three times the thickness of a clothes hanger. Thus far, I haven't tried sharpening the end, but I have tried putting three of them down the sides and spreading to lift.
    If you have a suggestion of a tool, I'm perfectly willing to buy anything that might work.
    As for "turning it over with the plug out", I'm curious what that would do.
    Thanks and again, I really appreciate the pic.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,224
    6,382
    Texas Hill Country
    Turning it over with the plug out gives small pieces a way out. Remember mechanics have drill bits, picks of various shapes and long exacto knifes.
    Sometimes it pays to use a shop with decades of experience and no time to waste. You are solving this problem for the first time and understandably are over cautious.
  3. Tombukt2
    Tombukt2 Senior Member
    13,098
    2,350
    Durham NC
    When this happened to me I used a long blue point gasket scraper I made sure I freshly sharpen the tip stuck it down in the hole felt it in the rubber basically hit it with my rubber malad a couple of times then twist the scraper kind of sideways as if to pry the sliced rubber tip open a little bit and then reach down with my extremely long hemostats but you're hanging right here on the wall and pulled the mass up one time this didn't work so well and I just took the spark plug socket and stuck it down in the hole smacked on it with the rubber hammer until it seated on rubber flats of the spark plug etc twisted the spark plug out and upcame the rubber tip spark plug and everything jammed into a standard spark plug socket without the piece of rubber in it that's stayed up on deck while I beat the spark plug socket on the coil tip which acted as the new rubber maybe and that was it
  4. R_W
    R_W Member
    82
    25
    @rjparker - Okay, so you're a fan of garages and wherever you live, the mechanics have decades of experience and wouldn't charge at least $300 to get out the rubber, plus insist on selling you a new plug and coil at 125% mark-up and another $200 labor, sometime next week because they are scheduling ten days out. Terrific for you, but it doesn't help me.
    (I'm in Florida, where all services are super-busy and everything costs a lot.)
    I'm not sure that a pick would do anything more than my heavy gauge wire, but I'll go through the catalogs and see what I see.
    I asked earlier this evening, if there is a suggestion regarding getting the air underneath. I dashed out and bought an air gun attachment for my compressor, but it isn't long enough to get underneath. They did have a longer one which would have required a connector, but considering the thickness of the tube, I'm not sure it wouldn't constrict the rubber so much that it couldn't come up.
    I could order a long X-acto knife, but for some reason they are all two-day delivery.
    And, while I have a drill, a lot of bits and am close to a store that sells more. I'm not a fan of getting an electric one so close to the plug and don't know that I'd rust a kid at a garage to try. In addition to it probably costing at least $700, once you add the coil and plug.
  5. R_W
    R_W Member
    82
    25
    @Tombukt2 - Because it's two-day delivery for a long x-acto knife, I could try your trick with the gasket scraper.
    When this all started, my wife had a sharp pair of hemostats that isn't very long. They just take bites out of the rubber. I bought an 11" pair from Amazon at your suggestion. The tip are dull and that may be a factor, but I can look down the hole and get one of the sides between the rubber and the wall, but because the inside is so shallow, I can't really get a good grip and though I can tug (and I have tried pulling gently), they just slide off. (I can get a better grip with my wife's, but they are only like 5" and they just pull off bites.)
    I haven't sharpened a screwdriver, but I can get one down all sides and I have tried using two like I have been trying with the three tomato cage wire, but it just isn't coming up. Maybe I'll try sharpening a screwdriver or some of the tomato cage wire.
    @rjparker suggested a drill. I'm reluctant to try that, but I wonder if there is a drywall tool or something that has a screwdriver handle, but the end is threaded and to a point, so I could screw it into the rubber. It seems like I might have one, but it could be in a box somewhere and it would probably be easier to buy one, if I can figure out what it's called.
    Both of you, thanks for the idea.
  6. rjparker
    10,224
    6,382
    Texas Hill Country
    You use air after it is small pieces. No need to get under it.
    A shop would charge an hour and have time to wash your car. Yes you will need a coil.
  7. R_W
    R_W Member
    82
    25
    @rjparker - Yes. If I take the car to a garage and pay them the $215 to $250 they charge an hour, in about a week, they will do the same thing I am doing with more confidence and I would not have to do it myself.
    And, because the coil that was there is missing a boot, instead of testing it or any of the half-dozen old coils I own, they will sell me a new one that retails for $112, except they will charge me $250, plus $25 for the plug and maybe another hour to install it.
    The least a garage would charge is $500, though it would probably be $700 to $750 and it would take another week. Though, it is now the beginning of Snowbird season, so they may now be scheduling ten days out.
    (I had the sway bar links done at one garage and the struts done at another this summer. At that time they were both scheduling one week out and because they used the Advance parts number on the invoice, it was real easy to calculate their markup.)
    @Mendel Leisk suggested air and air was also suggested by the Microsoft AI. That's why I bought an air gun attachment for my compressor tonight and might go look at them again tomorrow, but as I said, the tube on the air gun in so thick that it could keep the boot squeezed into place and it looks like it would be difficult to get underneath.
    Again, thanks for the pic. It confirmed what I thought and thanks for the suggestion of a drill bit. I have a lot, some of which are burred and some that are eight inches long. If I don't have one that is both, they sell them in town. If it has a sharp enough point, it might be something I could do manually.
    Edit: And, now that you've given me the idea, a long screw might also work. HD lists some for <$3.
    Though, I'll probably have to hit it with @Tombukt2's suggested rubber mallet. Thanks.
    #27 R_W, Nov 20, 2024
  8. Tombukt2
    13,098
    2,350
    Durham NC
    Try the spark plug socket not the magnetic type with the piece of rubber pulled out with your needle nose pliers and set it on the bench now take the spark plug socket and stick it down in the hole with your extension like you're going to remove the plug push down on it with some weight and rotate it slowly until you feel the spark plug flats line up with the flats even if the rubbers in the way you'll feel this when you feel that rock your weight a little bit on the spark plug socket downward pressing and see if you can get it on the flats enough or you can lefty Lucy the plug right out of the hole remember the spark plug socket had a big old space up in there for a rubber The rubber now is your coil tip sometimes even heating the spark plug socket not to red hot but I use my little plumbers torch and I heat the socket up so it's good and warm and it goes down in the hole and it makes the rubber a little more pliable and what have you and the thing is coming out of there I've done this like three times or had to do it just from taking the coils out didn't do anything else one rubber stuck in the hole duh If it sticks on there properly the rubber spark plug insert removed from the spark plug socket goes right over the coil tip
  9. ASRDogman
    ASRDogman Senior Member
    7,644
    3,935
    I don't understand why the claw didn't work. I've used my several times.
    I also have a small hook, 90 degree angle that's long enough to reach and get under it.
    Maybe spray some gunk down there. It will deform the rubber, make it expand some.
    Then you can get a hold of it.
    Tombukt2 likes this.
  10. R_W
    R_W Member
    82
    25
    Thanks to everyone for the help.
    Update: I had not sprayed any silicone lubricant in the hole previously, primarily because I was out.
    A few websites/videos (none of which listed everything y'all have suggested and I have found none that was as complete a list) suggested spraying WD-40 down the tube, but because the WD is for water displacement and the cautions about how petroleum-based products would damage the rubber, plus everybody said spraying it and letting it sit overnight was something you could do if nothing else worked, I had held off.
    After really having no luck. (@ASRDogman - maybe the Ace grabbers are different, but they couldn't find anything o hold onto. Like how the hemostats, even when I was trying two, they all just slid/popped off.) I ordered a decent set of hooks from Amazon -- the parts stores and Harbor Freight did not have any in stock and the ones from Home Depot looked too short -- and I sprayed a lot of silicone lubricant down there once a day for two days.
    After all that, I took one of the hooks from the hook set, grabbed the boot by piercing it and thing literally popped out.
    Then, I used the ShopVac and the air gun to make sure everything was out, including any residual moisture, then I changed the spark plug, put in one of the other old coils and thus far, I haven't had any misfires on that cylinder. So far, so good.
    Again, thanks for the help. It was a PIA. I tried several times over many days, as did my wife and my adult daughter. I think actually having the right tool definitely helped, but I don't know that it wouldn't have worked without the silicone spray.
    If I were to give advice to anyone in the future, if you're having trouble, start with it.
    #30 R_W, Nov 28, 2024
    Mendel Leisk and ASRDogman like this.
  11. ASRDogman
    7,644
    3,935
    I'm glad it worked for you and the car is running.(y)(y)
    Having the correct tool for the job is important and makes it a lot easier.
    R_W likes this.
