Duralast sway bar links
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by AzusaPrius, Sep 14, 2022.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,249
    938
    Got these with lifetime warranty at Autozone.
    Big difference with new ones it needed them badly.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    those won't last long
  3. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I installed one on one side. The original was still good...
    REVVL V+ 5G ?
  4. Tombukt2
    Tombukt2 Senior Member
    13,697
    2,479
    Durham NC
    Are these the sway bar end links are these the tie rod ends that steer the steering knuckles move the steering knuckles what have you? Move makes a very heavy sway bar in link I think that works on this model May go on Corolla too yeah you can measure them and see but they are pretty stout unlike the weaker originals.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
  6. AzusaPrius
    2,249
    938
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    That definitely needed changing!
    REVVL V+ 5G ?
  8. Tombukt2
    13,697
    2,479
    Durham NC
  9. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    You cannot go wrong with any lifetime warranty sealed stabilizer bar links from local stores. They have the best deal if you are DIYer. I prefer a sealed unit with composite nylon sockets like original Toyota ball joints. Metal to metal contact like in MOOG never last long even with regular regreasing.
  10. Tombukt2
    13,697
    2,479
    Durham NC
    That's wild I put so many miles on Moog and I can't even think of all the American part maker's names SKF etc and have never ever had a problem and most of my vehicles I've kept a good portion of my life and then if I do get rid of them they go to somebody I know and usually come back to me for upfitts and repairs but like everything else man this was a while ago and the last 10 years I haven't used a lot of any of that stuff haven't had to do any of that kind of work I'm coming up on wheel bearings and joints on an '09 and a 13 pretty soon
  11. johnHRP
    646
    189
    KA, DE
    Excel
    The problem with MOOG is the variety of the parts. It often does re-boxing from other suppliers. Stabilizer bar links only break when the boots are torn but for the ball joint, the internal parts are worn out. I always buy original Toyota ball joints, especially for truck and SUV bodies on the frame. For stabilizer bar links and tie rod ends, any brands are usually fine, as long as the boots are strong.
