... DYI rear brake job; '04 drum/shoe adjustment ~
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by asjoseph, Jan 29, 2017.
  1. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    91
    28
    117
    lancaster, california
    ... gearing up for a DYI brake job on my '04 commuter Prius. I don't have a Haynes or an OEM shop manual; couldn't find video at the you-tube, either.
    Front disc brake assembly relatively straightforward, I'm good to go on that. Just a quick question, if you please? Are rear drum brakes on early Gen IIs self-adjusting? Or, do I have to manually calibrate the new shoes, after installation?
    Even my '73 Celica had self-adjusters (e.g., just roll the car backward; yank up on the handbrake a couple times; that simple). I can't believe my Prius wouldn't.
    A Thousand Thanks,
    - Samuel, '04 Ruthiemobile -
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Yep, there are star wheels, and they work with the parking brake. Good luck.
