Dying traction battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Al Bundy, May 21, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    The Prolong equipment takes the battery to levels outside what the toyota software will;).
    This allows for losing any “memory” the modules have and get them all back to similar states:).
    If you find someone in your geographic area that you can share the charger and Discharger with, the initial investment is lower;).
    Good luck and keep us posted (y).
    jerrymildred, Al Bundy and edthefox5 like this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Like Ray said the outboard charger/discharger goes nowhere close to full charge or full depletion. The cars software does not allow it..
    Doesn't get close to fully depleted or 100% charged. A constant full charge on the battery is very stressful and a full depletion would be deadly to the car. Its all about battery internal heat.
    There's a 20% no mans land on both full charge and full depletion. What your seeing on the mfd when its all green is its 80% charged when it shows the battery very low like one purple bar there's like 20% left in the battery.
    Keeping the battery in this zone is very safe and gives it a very long life.
    The Prolong in charge gives it a full 100% or close to it charge under very controlled circumstances which are low charge current (350mA) over a long period of time (24 hours) and with the car's hybrid fan forced on high. You can discharge it to close to empty using light bulbs as loads or the new prolong is an electronic charger & load with built in timers for the charge/load routines.
    This out of bounds routine from almost completely empty to 100% full really wakes the battery up and rejuvenates the cells.
    It works. Length of rejuvenation time YMMV.
    Ray
  3. Al Bundy
    Al Bundy Member
    140
    69
    florida
    OH I didnt know they had preset charging/discharge limits.. now its makes sense, thanks
    Raytheeagle likes this.
  4. Al Bundy
    Al Bundy Member
    140
    69
    florida
    Thanks.. maybe Ill get lucky and find a used one somewhere..
  5. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Where in Florida are you located?
    Sharing with another member can lower the cost of ownership:).
    I share the charger and Discharger woth another member out here ;).
    Just one option to consider (y).
    Al Bundy likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    Florida is a pretty big place. But if you're in the Tampa area, I think Home - Tampa Hybrids Inc. does grid charges. At least he used to. He can also advise you on other options that are better than a rebuilt and cheaper than new.
    Al Bundy and Raytheeagle like this.
  7. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks, i dont think they do.. looked on his website. said the service isnt offered anymore
  8. Al Bundy
    Al Bundy Member
    140
    69
    florida
    im about an hour north of tampa..
  9. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    That almost sounds close to @jerrymildred land:).
    He has a Prolong setup ;).
    Not sure what his plans are for it after installing a “newish” battery into his wife’s Prius :whistle:.
    jerrymildred and Al Bundy like this.
  10. Al Bundy
    Al Bundy Member
    140
    69
    florida
    hummmmmmm maybe a rental .. how long does the process take?
  11. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    I’ve loaned ours out before to a member who rebuilt his pack about 6 months ago:).
    If doing a 2 cycle reconditioning process, plan on about 3 days;).
    Here’s a link to my Prolong reconditioning thread:
    2010 Prius II HV Battery Reconditioning
    If you talk nice to @jerrymildred , maybe you can work something out(y).
    Al Bundy and jerrymildred like this.
  12. jerrymildred
    11,517
    14,164
    Tampa, FL
    A three-day weekend is best. Too bad we're already so far into this one. But you'd need to get and install the cable before starting. Here's the link to Prolong's discharge ready wiring harness. Prolong® Battery Systems Car Harness - Discharge Ready – Hybrid Automotive
    If you want to get that, I can loan you our charger. I have the old, original version and the manual, lightbulb discharger. The discharger takes careful babysitting, so it's a bit of a pita, but it was all they had in early 2015 when I got mine. You're welcome to use that, too. You'll need to have two 25W bulbs,two 75 watt bulbs, and two 200 watt bulbs.
    As for plans, @Raytheeagle, I'll keep it as long as we have a car I can use it on. I'm thinking about doing the first grid charge fairly soon on the wife's "new" battery (It's from a totaled 2015, if you recall.). It's running great, but I may just do a top end charge.
  13. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Sounds like a good plan for the wife’s “newish” battery;).
    Since you might be in the sharing business, maybe you can upgrade your Discharger :whistle:.
    The cost would be half of what it would normally be:).
    But since @edthefox5 is in the same general area, maybe he’d be in too and the costs would be a third of normal for just the Discharger ;).
    Oh the possibilities. Have a great Memorial Day weekend (y).
  14. Al Bundy
    Al Bundy Member
    140
    69
    florida
    thanks when I have the extra money for the wire harness Ill contact you, dont see it happening anytime soon.. its a pay check to paycheck existence these days .. something always comes up and its never cheap..
  15. jerrymildred
    11,517
    14,164
    Tampa, FL
    I totally get that!
  16. jerrymildred
    11,517
    14,164
    Tampa, FL
    True, but I've never been a fan of dual ownership of tools. It can get complicated when there are scheduling conflicts or breakage. For the same reason, I don't mind lending, but I'm leery of borrowing. If I break someone else's tool, I feel obliged to replace it. Then I've bought something and it isn't mine.
    Not criticizing those who feel differently, but I just feel uncomfortable in those situations. (y)
  17. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Valid point;).
    I look at it this way:
    • If someone is an owner versus a “renter”, there is higher sense of ownership
    • The Prolong equipment is designed well and there is little human interactions with the Intelligent Discharger and the charger (little I or someone else could do to physically damage it)
    • If damage happens and I am at the wheel, I will replace it (no difference if it were in other hands)
    • It sits on the shelf for long periods of time otherwise (I use the Discharger once a year and the charger twice a year)
    • If I can help someone else (as long as they respect the tool and the relationship), I do it
    But appreciate your position and concern (y).
    edthefox5, Al Bundy and jerrymildred like this.
  18. jerrymildred
    11,517
    14,164
    Tampa, FL
    Likewise! (y) I think, if the dual ownership works for anyone, they should go for it. Same with borrowing/lending. I'm just happier lending than borrowing.
    edthefox5 and Raytheeagle like this.
  19. Al Bundy
    Al Bundy Member
    140
    69
    florida
    I agree, I have never been a borrower .. I cant tell you how many trips I made to harbor freight to buy a tool I know y neighbor has but didnt want to impose on him.. thanks god for the 20% coupons ;)
  20. jerrymildred
    11,517
    14,164
    Tampa, FL
    HA! You sound like me. I sure do have a pile of tools as a result. And the only tool I EVER sold (a carpet stretcher I thought I'd never need) I wound up wishing a year later that I hadn't sold it because a friend could have used it.
