E7039 JBL HDD head unit problems 2012 Gen III
Discussion in 'Gen 3 Prius Audio and Electronics' started by Crixus, Sep 22, 2019.
  1. Crixus
    Crixus Junior Member
    16
    New York
    The Head unit audio quits when a song with high bass plays even though the bass tuner is mid center. I had the problem originally with the car. So I had professionally installed New Memphis Speakers and an JL audio amp. With new wire run all the way up to the head unit and the problem persists. Could it be a fault in the wiring harness. It handles other songs at about 50 without quitting but heavier songs will guit at 44. I ruled the amp and the wiring all the way up to the head unit. Is this a common problem? Edit: The Head Unit has been Switched out with a different one but the problem persists. Same model Headunit but the wiring harness is the same. Is it possible the wiring harness Is the culprit? View attachment 178677 0920191354_HDR.jpeg 0920191354.jpeg 1569208373185.jpeg
