Early 2004 woes, catalyst and brake system light warnings?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ianmeister, Apr 30, 2023.
  1. Ianmeister
    Ianmeister Active Member
    316
    319
    Meridian Idaho
    Hello all!
    So I’ve got an early gen2 2004 (build date 12/2003). It has $268K on it. I’ve finally solved the P0420 code with a replacement catalytic converter from Amazon. The stock one was packed with what looks like sand. I’ll stick it on a shelf for later. the good news is that it runs better and the mileage is improving.
    Now my vexation is that the ABS and brake system failure lights keep coming on. The come on together at seemingly random times. Always when in motion and always with no brake input. Like barelling down the freeway at 70. Stay on for a few minutes then back off. I tried the “connect a wire from ODB pin 4 to lower ODB pin 5 to start the diagnostic mode trick and clear the lights to reset the ABS system but it comes right back on. Any ideas?
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,111
    2,011
    NJ-USA
    You might consider figuring out why the brake control ecu is turning the warning lights on. Search for "flash codes" in the forum. You want to count which light flashes how many times while the jumper is in place.
    Then the two digit code can be matched up with the normal five digit alphanumeric code in the service manual.
    Another option is to read this thread that reviews several scantool apps and OBD devices.
    https://priuschat.com/index.php?posts/3290690
  3. Tombukt2
    Tombukt2 Senior Member
    13,844
    2,515
    Durham NC
    Abs pump running a lot??? Theirs a reason why . All that whirring etc . You did not have all that 70K miles ago?
  4. ChapmanF
    18,996
    In the march of PriusChat progress, we don't have to do searches for that anymore. There's a wiki page for it:
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    SFO likes this.
