Easiest way to fix this bumper damage
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Jan 26, 2018.
  1. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    I hit the fence while parking and did some damage to the right front area of my Prius
    I did not know it was so flimsy
    Here is a pic
    What is the cheapest way to repair this ?
    Everybody get some sleep
    Thanks
  2. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
    Easiest?
    Go to a body shop supplier and buy the special flexible rubber bumper repair "goop".
    Should include some support mesh so apply the support and goop over it on the inside.
    Then once dried and firm, brush touch the color to somewhat fill the crack on the outside.
    Won't be perfect.
    Easiest vs cheapest.
    Or put a bumper sticker over it.
    Buying the flexible bumper repair kit may be the answer you were seeking?
    Good luck.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Where's Mendel with the pic of the crisscrossed zip ties repair?
  4. BZzap!
    BZzap! Senior Member
    1,607
    878
    That’s what I was thinking...white zip ties. Heat up the tip of a small screw drive and pierce some holes on either side of the split and slip them through and pull them tightly from behind.
  5. frodoz737
    frodoz737 Top Wrench
    4,784
    2,549
    33
    Cheapest...Easiest? Duct Tape or Speed Tape.
    Best? Pay the deductible on you insurance and they will replace the clip.
  6. Mendel Leisk
    42,194
    Yes, but black zip ties, much better. Like this:
    A bumper with moxie | PriusChat
    Still, best bet would be @Kenny94945 's suggestion I think. Here at Canadian tire there's a bumper repair kit: 2 part filler, Fiberglas mesh, superglue, solvents:
    https://m.canadiantire.ca/products/productDetail/0475601P?selectedSku=0475601&gclid=Cj0KCQiAwKvTBRC2ARIsAL0Dgk0kZEMjXrQMGqo1U075YWr6PHfxFVfiX_LZiF-my_HBPyY4lJlia2kaAtc2EALw_wcB&gclsrc=aw.ds&dclid=COLGvtDG99gCFcTYwAodhGwCtw
  7. BZzap!
    1,607
    878
    It’s a bit Frankenstein-ish for me.
  8. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Why trash an entire bumper cover because of a little tear?
    Lightning Racer likes this.
  9. frodoz737
    4,784
    2,549
    33
    Taxi/Limo needs to define and clarify his or her definition of "repair" before the question/s can be answered.
  10. Mendel Leisk
    42,194
    My Canadian Tire link went walkies, and Priuschat has closed my ability to edit that post, so a pic:
    And hopefully a better link. I've used this on a bumper repair (not our Prius) and it worked well. The two part filler is tough to squeeze out of the tubes, and you have a somewhat limitted window before it hardens, but it works well, especially with the mesh. You're supposed to "tack" the repair with (supplied) superglue first.
    Automotive and Marine D.I.Y. Plastic Repair Kit (XPSKR) – Largest Supplier of Industrial & Commercial Automotive Products
  11. BZzap!
    1,607
    878
    From a utilitarian point of view, cable ties are the cheapest way to fix the OP’s damaged bumper cover. He did ask, “the cheapest”, eh?
