Easy to understand help for supposedly bad traction battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jaeco, Apr 25, 2016.
  1. JC91006
    16,936
    8,647
    FYI, the Prius is not made to provide a jump start for another car.......that can mess up a lot of things. But I think you lucked out by not having done any damage.
    You can just charge up your 12v battery, no need to buy another one. That's not the cause of all your error codes. Your main concern would be the HV battery. But a new one will give you another 8-10 years.....
    52,862
    not always. check the 12v health, or just replace it if you can't be bothered. you won't know until you know.
  3. jaeco
    jaeco Junior Member
    Any thoughts on these codes...I'm copying from above.....the codes for electrical system diagnostics....P0A80 (Replace Hybrid Battery Pack) P3000 (Battery Control System) DSIMS.
    I was able to get the price for their diagnostic testing down to $105 from the $210. Called dealer and they are towing car to them...waiving their diagnostic testing fee and also the tow. I'm sure they think I'll be buying a car...and I may, but that is where it stands right now.
    The shop that did the diagnostic test quoted $3100 parts, 645. labor, supplies 38.72...total with tax...high in TN:(....4152.64. It looks like all their repairs are covered by 3 year/36000 mile nationwide warranty. They have been in business for probably 25 years.
    Toyota dealer also suggested that their is a possibility of a goodwill discount by Toyota...said it wasn't unsual. Have not heard back from them but the car is now at dealer.
  4. Saverte
    Saverte New Member
    Indianapolis, IN
    I know. This was an extenuating situation and I gave him considerable hell for it. Perhaps I'll give him more.
    I don't have a portable charger, so I can ask the dealership to charge it tomorrow since the appointment is already set. No telling whether it would rectify any of the other errors, but it at least eliminates one possibility.
  5. bisco
    52,862
  6. bisco
    52,862
    it looks bad, but worth the shot at goodwill. is tn a carb state?
  7. JC91006
    16,936
    8,647
    You can get it charged at Napa for free. I don't think you need to do anything to the 12v, it'll charge itself when you drive.....definitely not the reason for your codes
  8. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Saverte, disconnect the negative lead from your 12 volt battery at the rear body panel. This will effectively reset your ECU's. Then drive the vehicle again and see what codes reappear. This would rule in or out if any of the other codes were previously stored and not cleared once the offending issue was resolved. I would expect your DTC P0A80 code to reappear quickly once the vehicle is back under power after resetting the ECU's. The other DTC's well you'll have to see. IMO this would provide you with the most current and comprehensive disposition of your car's current state of health.
    Jaeco, let's see what the dealer retrieves as far as codes go. As has been discussed on PC countless times if an independent garage doesn't have the proper code reader, the codes that are retrieved may be incorrect and other logged codes may not get retrieved to begin with. I have two readers myself, one that retrieve some codes with a high degree of confidence and the other that can retrieve all codes with the highest degree of confidence. As far as the P3000 DTC is concerned there should be a three digit sub code associated with that primary code. Again if a compatible reader is not used the sub code might not be retrieved or retrieved incorrectly. The sub code further and more precisely directs one to the plausible issue.
    uart likes this.
  9. jaeco
    jaeco Junior Member
    TN is not a CARB state. Yesterday when I was at the first shop that is dealing with the Prius, I think he said in some of their service bulletins that it says that the battery is under warranty for the life of the vehicle??? Clearly this doesn't appear to be the case, but I was going to stop and ask him what he was referring to....
  10. S Keith
    S Keith Senior Member
    799
    330
    AZ
    2003 Prius
    Bad battery
    Then ask him why he's not replacing it under warranty... :)
    Because he is full of the lyings!
  11. jaeco
    jaeco Junior Member
    I know, right? We were talking all around it and later I would swear that's what he said!!
  12. usnavystgc
    3,159
    990
    Tucson, AZ
    Jaeco,
    The bottom line is you need to get your battery fixed. I recommend a new one from the dealer.
  13. Saverte
    Saverte New Member
    Indianapolis, IN
    My dealership trip ended up with them charging my 12V, which was low, and just running a basic diagnostic. That yielded only a few of the codes from before: P0031, P1121, and P0A80... then as the technician moved the car into a spot outside the shop area, the MWL went off. Apparently he turned it on and it was gone. The MIL stayed on so I asked him to check the codes one more time and he only had P0031 and P1121. Took it to AutoZone, same thing. O'Reilly, same thing.
    Searching these forums, the phenomenon of MWL turning off suddenly seems at least not uncommon. Not that I think it was a fluke, I'm sure the HV will die sooner rather than later, but until that day or the day the warning reoccurs, there's no real resolution.
  14. JC91006
    16,936
    8,647
    Check engine light is related to P1121, the 3 way valve. That's a $75 part but the dealer will want $400-$500 to fix the problem.
  15. Saverte
    Saverte New Member
    Indianapolis, IN
    Yeah, those are both relatively easy to fix. I have a friend willing to do it if I buy parts and beer. Dealer wanted $350.
    Nonetheless, I still don't know if the HV issue is solved or just masked. Putting any amount into it if failure is imminent just seems a little pointless.
  16. JC91006
    16,936
    8,647
    The battery failure is there, it'll come up again sooner than when your friend can finish the beer. Since the Prius is not that popular there, maybe you'll have an easy time looking for a HV battery from a wrecked Prius.
  17. jaeco
    jaeco Junior Member
    word from dealer today....total to replace the battery, including labor, tax, everything....2782. I will have it fixed and then probably sell. However the first shop said they may want to buy it, so if I can get a decent offer from them I may just do that and let them fix it. Save me trying to sell. Someone here suggested that the way it is now with the battery not working, that it is probably worth about $2000. I bet I'll be lucky from the shop to get 1000, but hope for 1500. thanks for all the help....who knows, I may keep it!! It may go for another 180,000.....
  18. JC91006
    16,936
    8,647
    Why not just install the new battery and keep driving? If it last 1 more year, you've already gotten your money back. A new car will cost you $300 a month, $3600 plus higher insurance and registration
  19. bisco
    52,862
    are you near steve at autobeyours?
  20. Saverte
    Saverte New Member
    Indianapolis, IN
    I'm a bit north from him, but not more than a couple hours, I think.
  21. bisco
    52,862
    might be worth a call. i've heard he's helpful, and easy to talk to.
