Ebay's selection of mini VCI's
Discussion in 'Generation 1 Prius Discussion' started by vaughnstark777, Jun 28, 2015.
  1. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    Is this what I'm looking for for my gen 1?:
    Description:
    Features
    Support Toyota TIS OEM diagnostic software
    Cost-effective, the price of product is only one-third of similar foreign products.
    High performance with ARM cpu inside.
    High reliability of products using SMD chip, and certified by CE and FCC.
    Support all the diagnostic communication protocols needed for Toyota (since 1996).
    Upgrade the firmware via the Internet to improve product.
    not only provides commonly used J1962 connector, but also provides the old 22pin connector for Toyota.
    Using online feedback function for technical support.
    Supported Protocols
    K-Line ISO 9141
    KWP 2000 ISO 14230-4
    SAE J1850 PWM
    SAE J1850 VPW
    CAN 2.0B ISO 11898
    CAN ISO 15765-4
    Thanks
  2. Patrick Wong
    18,214
    6,531
    You just need the normal cable to fit the 16 pin OBD-II connector.
  3. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    So you would say this one includes what I need?
  4. vaughnstark777
    191
    33
    Roy, WA
    2001 Prius
    I
    Here is the rest of what is included:
    Package Included:
    1 x Mini VCI 16 Pin Cable
    1 x Software and Drivers CD
  5. Patrick Wong
    18,214
    6,531
    This is the one I bought.
  6. DaveGoodrich
    DaveGoodrich Member
    141
    68
    It seems like the MiniVCI's sold on ebay are the cheapest option for a powerful diagnostic tool for the Prius, with the disadvantages being that the software is probably pirated, and only runs on XP. I seem to have found sellers that claim to have version 10 software that will run on Windows 7 and 8. Anybody have any experience with these?
    EDIT: further research suggests that even version 10 still only supports XP 32-bit.
    #6 DaveGoodrich, Jul 29, 2015
  7. royfrontenac
    royfrontenac Active Member
    247
    100
    Kingston Ontario Canada
    2001 Prius
    Roy from Canada here - I have an old xp computer that I have set up with techstream - I had trouble trying to install the software unless your windows xP computer has to have SP2 or higher upgrade for the software to work.
    I also have a computer with windows 7 installed - I purchased the newest version of techstream (version 10) and found it installed OK but you have to follow the supplied instructions for modifing techstream files very closely - if you are a good computer wizard it may be simple - for me it was hard and I had to redo the process many times.
    Their are 2 versions of cables available, the original version 1 was good for the older cars, the newer version 2 covers all newer cars plus the old ones.
    If you have a windows 7 computer buy the software for version 10 with the cable version 2.
    Best of luck
