EBH Plug Location
Discussion in 'Gen 2 Prius Accessories & Modifications' started by geodosch, Aug 25, 2007.
  1. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
  2. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    83
    Camas, WA
    <div class='quotetop'>QUOTE(FireEngineer @ Sep 10 2007, 06:47 AM) [snapback]510005[/snapback]</div>
    Wayne, I will try to get you some photos tonight. I wanted to take several along the way, but the kids have missplaced the digital camera. And don't worry, I left most of the sacred part of the installation in tact. Not a single one of your lovingly placed tie wraps were compomised.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I've given considerable thought to this problem. After talking with Wayne about cord placement, cutting holes in my bumper, and all that, I have decided to simply pass it through the grill like it is designed.
    To address the concern of forgetting to unplug it, I have devised the setup in the attached image. You have to keep in mind that I am blonde in hair color and mental capacity. I forget some of the most obvious things and simply don't see things on a regular basis. For me, if there were even the slightest chance that I could do damage to home or car, I would not be able to do it.
    Therefore, as this illustration shows, I plan to plug the extension cord into the outlet on the ceiling of my garage. This outlet provides power to the garage door. I will hang the cord so that it hangs exactly where I need to stop the car every time I pull in. Currently, I have a tennis ball that hits the windshield. I admit that this forces me to no longer back into the garage but I guess I have to accept that limitation. The key to the setup is the break-away hanger system. In the event (when) I forget to unplug the heater, the cord will snap out of the hanger system and fall on the car. This will certainly remind me. The way I see it, after having the cord smack the hood of my car and the subsequent ladder usage to re-hang the cord, I should start remembering. Also, there will be enough slack in the cord, that absolutely no damage will result in my forgetfulness.
    The break-away system (currently in my head) is a curly piece of plastic sort of like those pamphlet spines. It is strong enough to hold the cord but loose enough to release when tugged.
    [attachmentid=11334]
    In the words of Doc Brown, "sorry for the crudeness of this model, I didn't have time to build it to scale and paint it."
  4. n8kwx
    n8kwx Member
    236
    Arlington Heights, IL - NW Chicago Suburb
    Sorry Tony, your "house door" doesn't have a "perspective slant" on the top. :D
  5. TonyPSchaefer
    14,816
    2,501
    66
    That's because it's at eye level.
    Yes, Marc, that actually was intentional. :D
  6. NoMoShocks
    1,292
    83
    Camas, WA
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Sep 10 2007, 02:46 PM) [snapback]510267[/snapback]</div>
    My Love must be some kind of Blind Love
    I can see anything but Silver Pine Mica
    For I only have eyes
    For SPM
    Yes I only have Eyes for SPM.
    Tommy, excelent choice of Prius Color for your diagram.
    As promised to Wayne, the photos of IEC320 Computer Style plug hidden (almost) behind license plate.
    1. EBH plug behind plate. Cord showing is the Filler Plug that I put in place when the electric cord is not in use. As a refinement, I think I may cut off the entire cord from the filler plug and teather it with a small tie wrap so there is less mod showing. Minus the cord and my foam gasket around the filler plug hanging down, it would be almost invisible.
    [attachmentid=11343]
    2. EBH supply cord plugged in, Filler plug hanging from its teather (cut off cord tie wrapped behind grille). Yes, I know, I need to work on the foam seal I added to the filler plug.
    [attachmentid=11342]
    4. View looking from side of plate
    [attachmentid=11344]
    5. Looking straight up from ground.
    [attachmentid=11345]
    6. Plate removed to show P-clip securing plug.
    [attachmentid=11346]
    To be honest, I don't think the regular NEMA 15-5P plug looked bad at all with the cover in place, and I probably wouldn't have bothered with this mod if the plug cover had not fallen off somewhere between my home and work.
  7. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    I like where Wayne installed mine, bottom driver side through grill. Its almost invisible. I pull it out a few inches to plug it in, push it back in with only about an inch showing when not plugged in. I am going to secure the cap to the cord with a zip tie, afraid it will fall off at some point since it is not very secure by default. Also, I use an extension cord with a light on the end so I know the timer is working and providing electricity, otherwise you might wonder why its not making much difference in your mpg!
  8. NoMoShocks
    1,292
    83
    Camas, WA
    <div class='quotetop'>QUOTE(abq sfr @ Sep 11 2007, 02:16 PM) [snapback]510811[/snapback]</div>
    I like where Wayne put mine too, same place you describe. I don't think I would have changed anything at all if the plug cover had not fallen off somewhere between my home and work. Due to my electronic, ITE, A/V, multimedia baackground, I sort of had this inkling all along to install a computer plug, and I even considered having one on hand when Wayne got here, but then I thought, why not give the standard plug a try. I was actually very pleasantly surprised with the clean look of the supplied plug and plug cover and how they neetly nested in the grill, and gave up any thoughts of changing it until the plug cover dissapeared.
    I wish I had thought about securing the cover better, but I thought the clip it came with was adequately designed to do the job.
  9. NoMoShocks
    1,292
    83
    Camas, WA
