ECM replacement and reprogramming?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AZ_2005_PRIUS, Dec 3, 2016.
  1. christian cox
    christian cox Member
    115
    ohio
    Funny thing the engine finally started running on its own. It sounded terrible at first then smoothed out and the cam error went away now it’s a misfire in #4 cylinder & bad water pump. I’m guessing the engine was sitting in a wharehouse soo long that it was gummed up and needed to work itself out to improve responses to the ECU perhaps? Just an idea
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,104
    2,006
    NJ-USA
    If the car runs, then good. I wouldn't be too sure that everything is 100%, as anything being "gummed up" (ie, some form of mechanical malfunction) wouldn't trigger a bunch of circuit codes (indicating electrical faults). Time will tell.
  3. christian cox
    115
    ohio
    Yeah there were two breaks in the wire harness right where the wires go into the top of the connector when was the injector the other one was the cam sensor they broke past the wire where you couldn’t really see them.
  4. christian cox
    115
    ohio
    Thanks for all the input everyone and sorry I got on the wrong generation thread. My bad!
