Eco mode not working right after service
Discussion in 'Gen 3 Prius Technical Discussion' started by Cheapbyte, Mar 21, 2011.
  1. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Old thread that never did get a solution. I suspect that the 12V battery was disconnected at some point and the vehicle had to re-learn the habits of the driver, resulting in a change in mpg. It's interesting how closely some folks monitor their mpg. For the later posts, this might also be the cause. I recall there is a setting to turn on or off the ECO flag in the MFD.
  2. Vulgaris
    Vulgaris New Member
    I would love to know if there is an update on this - did the eco mode return to normal function after some time? I have the exact same issue with my 2015 prius, after having a dealership turn off the reverse beep, the ECO mode is as Cheapbyte described. The engine revs up as if it is in power mode. I noticed it immediately upon driving away from the service center. I am taking the vehicle back to the dealership but doubt if they will be able to figure it out. Hoping there is some sort of solution because I hate to lose mpg!
    52,855
    you don't really lose mpg's in normal mode, just go a little lighter on the pedal and hvac
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Why didn't you turn right around and go back and tell them to fix it?
    Eddie25 likes this.
  5. Eddie25
    Eddie25 Active Member
    503
    213
    MI
    I doubt they can fix it when they have no idea what IT is.
  6. ASRDogman
    8,066
    4,086
    They caused it. It worked when you took it in, and didn't when you left.
    It's their problem.
  7. Eddie25
    503
    213
    MI
    That might be, but that doesn’t mean they have a solution.
  8. bisco
    52,855
    it's not a definitive problem. iow, they'll say no codes, no problem, and toyota will back them up.
  9. Vulgaris
    Vulgaris New Member
    yeah, they took a look at it and said the vehicle is functioning at optimum performance and there is nothing wrong. When I told them as proof that MPG went way down since they worked on it, they blamed the weather. Just a word of advisement to anyone in the future who may come across this forum topic, if you want to keep your eco mode, I would advise not to mess with the reverse beep. I wish I hadn't.
  10. ASRDogman
    8,066
    4,086
    Turning off the continued reverse beeping was the first thing I turned off when I got techstream!
    My echo mode works just fine.
    They did something else too it. Time to find a different dealer.
    Or get techstream and run through it and turn it back on.
