ECO vs Normal vs PWR Mode - really just accelerator mapping?
Discussion in 'Gen 3 Prius Technical Discussion' started by pakitt, Nov 22, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Exactly. The most efficient acceleration comes from keeping the ICE running at its most efficient level.
    Tom
  2. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    Hum. Have you noticed that if you maintain a fixed accelerator pedal position, from a stop, the HSI graph will not stay fixed as it will rather slowly go higher (at least true for ECO mode, in which I always stay).
    Is there any relation with your comment?
  3. qbee42
    18,058
    3,079
    Northern Michigan
    I would expect so. One would assume that the sweet spot would change with load.
    Tom
  4. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    To me also. I understand motors do better when under stress from an efficiency standpoint but I've never found any vehicle to get better gas when accelerated briskly up to speed vs gradually.
    I thought that sometimes the ICE itself would charge the battery and not because "it should" but because if it isn't not being pushed hard and it pushes itself a little harder to charge the battery it can get into its more efficient range, despite some small loss of energy going into the motor > battery > motor later on.
  5. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    An additional note - depending on the modes, the HSI bar changes.
    E.g. in ECO, when the bar reaches middle, is not the same as when you reach the middle in PWR.
    When you reach PWR red zone in ECO, you still have quite a way to go down with the gas pedal. With PWR you can reach PWR red zone more "easily".
    I think this has to do (according to all the posts above) with the accelerator mapping and Toyota trying to teach customers that in ECO mode you should avoid flooring the car since you can reach the "flooring" section (the red PWR zone), even without actually flooring the gas pedal.
    Does that make sense???? (my english today is a bit crap, sorry).
  6. Smirv
    Smirv AkA: Ryan
    212
    Illinois
    My personal two sense on it is the power like you said is just more sensitive to the touch which is nice for pullin out in front of traffic and passing. Eco takes some more pressure to use which for me personally kind of keeps me honest. Im too tempted on power mode to use the gas more often. The eco mode kind of makes me drive lazier and I like it. I know its more of a mental thing but all in all the eco mode is like a reminder to drive more passively to get the best mpg.
  7. Skoorbmax
    2,641
    265
    Western NY
    I'm trying to train my wife that I'm ok with her accelerating briskly but _please_ brake early and long to help the regen. I think she's doing better although when I take the car out the average MPG is always higher at the end of my trip :)
  8. WEB211
    WEB211 Junior Member
    Nicholasville, Kentucky
    With the rolling hills of Central Ky. I've found that normal mode works better than ECO for me. I can get up to speed and glide sooner that way. I will switch to ECO in subdivisions and on flat land, but I'm not sure it matters. I'm still learning and improving.
  9. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    I agree with your considerations. I use ECO mode a lot during my city trips, it helps the mileage and the comfort because the HSI seems to use the battery more willingly, especially in the winter; and I don't feel any particular loss of power, you can accelerate reasonably even in ECO mode. With one exception, hills: ECO mode is a pain if you have to climb hills, you have almost to floor the accelerator if you want to keep a decent speed while climbing steep hills, in that case Power is a lot better.
  10. gazz
    gazz Member
    216
    Coventry, UK
    But from what is being said hills should make no difference as all you do is push the pedal a bit further in ECO to match the PWR acceleration rate, isint it.
  11. E-GINO
    194
    206
    Rome, Italy
    Right, but the force required to almost floor the accelerator pedal is high, so I prefer the PWR with a smaller amount of pedal.... it's just a psychological thing :) Anyway, it's nice to have available three different accelerator pedal behaviors, even if, bottom line, the ICE behavior is the same.
