ECU Diagnostic Codes
Discussion in 'Toyota Prius Service Bulletins - TSBs' started by PriusLove, Apr 26, 2007.
  1. PriusLove
    PriusLove New Member
    31
    Hybrid Vehicle ECU Diagnostic Trouble Codes
    In addition to the letter-plus-four-digit DTC, the HV-ECU generates "information codes" consisting of three digits. These give a more finely detailed definition of the problem. They can be retrieved by the THHT (Toyota Hand-Held Tester) but not by a normal OBD-II scanner. How the THHT retrieves information codes has not been determined, therefore they cannot be retrieved by the Prius Mini-Scanner.
    From pages DI-199 through to DI-205, in the Hybrid Vehicle Control System chapter of the Repair Manual.
    B2799 - Immobilizer Malfunction
    101 No input of signal from transponder key ECU
    C2692 - Regenerative Brake Check
    102 Regenerative Brake Check
    C2693 - Regenerative Brake Check
    103 Regenerative Brake Check
    P1120 - Accelerator Pedal Position Sensor Circuit Malfunction
    This DTC has been caught in the wild on an early 2001 model year Prius. The accelerator pedal position sensor is know to cause problems on these cars and there is a TSB out on it.
    104 Open or short circuit in main accelerator sensor circuit
    105 +B short in main accelerator sensor circuit
    106 Main sensor internal error
    107 Open or short in sub accelerator sensor circuit
    108 +B short in sub accelerator sensor circuit
    109 Sub sensor internal error
    110 When difference between main sensor value and sub sensor value is large
    111 When sub sensor value changes while main sensor value does not
    112 When main sensor value changes while sub sensor value does not
    113 When any of information code 104-112 continues to appear
    114 Accelerator pedal not smoothly returning to original position
    P1520 - Stop Light Switch (Cruise Control System) Malfunction
    115 Open or short in stop light switch circuit
    P1566 - Cruise Control System Malfunction
    116 When STP signal of HV ECU is inconsistent with that of brake ECU, with cruise control indicator ON
    P1600 - BATT Malfunction
    117 HV ECU back-up power source circuit malfunction
    P1780 - Park/Neutral Position Switch System Malfunction
    118 When more than 2 main signals are ON
    119 When main signal is not turned ON even though sub signal has been input
    120 Open or short in sub sensor circuit
    121 When shift position detected by main signal is different from that detected by sub signal
    P3000 - HV Battery Malfunction
    123 Input of abnormal signal from battery ECU (HV Battery System Malfunction)
    124 Input of abnormal signal from battery ECU (high voltage fuse blown out)
    388 Discharge Inhibition Control Malfunction. When charged battery is low due to leaving the vehicle in N position, gas shortage or HV system malfunction
    389 Drop of high voltage. When main battery is dead or main battery is dead due to HV system malfunction
    P3001 - HV Battery ECU Malfunction
    129 Battery ECU malfunction
    P3004 - Power Cable Malfunction
    130 HV Battery Malfunction. When HV battery voltage becomes lower than inverter voltage
    131 Power Cable Malfunction. When main fuse is blown out, service plug is disconnected or limiter resistance is cut off
    133 HV Battery Malfunction. When inverter voltage sensor is malfunctioning or limiter resistance value increases
    P3100 - HV ECU Malfunction
    127 IB Circuit Malfunction. +B short in IB terminal circuit of HV ECU
    128 IB Circuit Malfunction. Open or short in IB terminal circuit of HV ECU
    134 HV ECU Internal Error
    135 HV ECU Internal Error
    136 GO Signal Error. Open or short in GO circuit
    137 Engine Speed Sensor Malfunction
    138 IB Circuit Malfunction. When the difference between current of HV ECU and current of battery is large
    139 HV ECU internal error. IG Signal Circuit Malfunction
    140 HV ECU internal error. RAM Braked
    141 HV ECU internal error. ROM Braked
    142 ST Signal Circuit Malfunction. When ST signal of HV ECU is ON, with ignition switch turned OFF
    143 HV ECU internal error. Immobilizer Malfunction
    144 HV ECU internal error. Primary Check Malfunction
    145 HV ECU internal error. Primary Check Malfunction
    146 HV ECU internal error. Primary Check Malfunction
    147 HV ECU internal error. Primary Check Malfunction
    148 HV ECU internal error. HV CPU Malfunction
    149 HV ECU internal error. HV CPU Malfunction
    150 HV ECU internal error. Motor CPU Malfunction
    151 HV ECU internal error. Motor CPU Malfunction
    152 HV ECU internal error. Motor CPU Malfunction
    153 HV ECU internal error. Motor CPU Malfunction
    154 HV ECU internal error. Motor CPU Malfunction
    155 HV ECU internal error. Motor CPU Malfunction
    156 HV ECU internal error. Motor CPU Malfunction
    157 HV ECU internal error. Motor CPU Malfunction
    158 HV ECU internal error. Motor CPU Malfunction
    159 HV ECU internal error. Motor ECU Communication Circuit Malfunction
    160 HV ECU internal error. Motor ECU Communication Circuit Malfunction
    161 HV ECU internal error. Motor ECU Power Source Malfunction
    162 HV ECU internal error. Motor ECU Power Source Malfunction
    163 HV ECU internal error. Motor ECU Power Source Malfunction
    164 HV ECU internal error. Motor ECU Power Source Malfunction
    165 HV ECU internal error. Motor ECU Power Source Malfunction
    166 HV ECU internal error. Motor R/D Malfunction
    167 HV ECU internal error. Motor R/D Malfunction
    168 HV ECU internal error. Motor R/D Malfunction
    169 HV ECU internal error. Motor R/D Malfunction
    170 HV ECU internal error. Motor R/D Malfunction
    171 HV ECU internal error. Motor REF Signal Malfunction
    172 HV ECU internal error. Motor REF Signal Malfunction
    173 HV ECU internal error. Motor REF Signal Malfunction
    174 HV ECU internal error. Motor Inverter Current Sensor Malfunction
    175 HV ECU internal error. Motor Inverter Current Sensor Malfunction
    176 HV ECU internal error. Motor Gate Shutdown Signal Line Connection Malfunction
    177 HV ECU internal error. Motor Main CPU Malfunction
    178 HV ECU internal error. Motor Main CPU Malfunction
    179 HV ECU internal error. Motor Main CPU Malfunction
    180 HV ECU internal error. Rotation Angle Check CPU Malfunction
    181 HV ECU internal error. Rotation Angle Check CPU Malfunction
    182 HV ECU internal error. Rotation Angle Check CPU Malfunction
    183 HV ECU internal error. Rotation Angle Check CPU Malfunction
    184 HV ECU internal error. Rotation Angle Check CPU Malfunction
    185 HV ECU internal error. Rotation Angle Check CPU Malfunction
    186 HV ECU internal error. Rotation Angle Check CPU Malfunction
    187 HV ECU internal error. Important RAM Malfunction
    188 HV ECU internal error. Generator CPU Malfunction
    189 HV ECU internal error. Generator CPU Malfunction
    190 HV ECU internal error. Genarator CPU Malfunction
    191 HV ECU internal error. Generator CPU Malfunction
    192 HV ECU internal error. Generator CPU Malfunction
    193 HV ECU internal error. Generator CPU Malfunction
    194 HV ECU internal error. Generator CPU Malfunction
    195 HV ECU internal error. Generator CPU Malfunction
    196 HV ECU internal error. Generator CPU Malfunction
    197 HV ECU internal error. Generator R/D Malfunction
    198 HV ECU internal error. Generator R/D Malfunction
    199 HV ECU internal error. Generator R/D Malfunction
    200 HV ECU internal error. Generator R/D Malfunction
    201 HV ECU internal error. Generator R/D Malfunction
    202 HV ECU internal error. Generator R/D Malfunction
    203 HV ECU internal error. Generator Shutdown Signal Line Connection Malfunction
    271 HV ECU internal error. Motor PWN Line Connection Malfunction
    310 HV ECU internal error. Generator PWN Line Connection Malfunction
    390 HV ECU internal error. Charge Inhibition Control Malfunction
    391 HV ECU internal error. Motor CPU malfunction
    392 HV ECU internal error. Motor CPU malfunction
    393 HV ECU internal error. HV CPU Operation Malfunction
    P3101 - Engine System Malfunction
    204 Input of abnormal signal from the ECM (abnormal engine output)
    205 Input of abnormal signal from the ECM (engine unable to start)
    238 Transaxle Malfunction. When engine does not start even though cranking it
    P3105 - Battery ECU Communication Circuit Malfunction
    206 When communication between battery ECU and HV ECU is abnormal 1 sec. after ignition is turned ON
    207 When communication between battery ECU and HV ECU is abnormal 1 sec. after ignition is turned ON
    208 When communication between battery ECU and HV ECU is abnormal 1 sec. after ignition is turned ON
    P3106 - ECM Communication Circuit Malfunction
    209 When communication between ECM and HV ECU is abnormal 1 sec. after ignition is turned ON
    210 When communication between ECM and HV ECU is abnormal 1 sec. after ignition is turned ON
    211 When communication between ECM and HV ECU is abnormal 1 sec. after ignition is turned ON
    212 Input of abnormal signal from ECM
    394 When ECM does not operate
    P3107 - Airbag ECU Communication Circuit Malfunction
    213 When communication between airbag ECU and HV ECU is abnormal 10 sec. after ignition is turned ON
    214 When communication between airbag ECU and HV ECU is abnormal 10 sec. after ignition is turned ON
    215 When communication between airbag ECU and HV ECU is abnormal 10 sec. after ignition is turned ON
    P3108 - A/C Amplifier Communication Circuit Malfunction
    216 When communication from A/C amplifier to HV ECU is abnormal
    217 When communication from A/C amplifier to HV ECU is abnormal
    P3109 - Brake ECU Communication Circuit Malfunction
    218 When communication between brake ECU and HV ECU is abnormal 1.5 sec. after ignition is turned ON
    219 When communication between brake ECU and HV ECU is abnormal 1.5 sec. after ignition is turned ON
    220 When communication between brake ECU and HV ECU is abnormal 1.5 sec. after ignition is turned ON
    221 When communication between brake ECU and HV ECU is abnormal 1.5 sec. after ignition is turned ON
    222 When abnormal data is received from brake ECU
    P3110 - IGCT Relay Malfunction
    223 When IGCT relay is always closed
    P3115 - System Main Relay Malfunction
    224 SMR Cont 1 Malfunction. Open or +B short in system main relay No. 1 circuit
    225 SMR Cont 1 Malfunction. Short in system main relay No. 1 circuit
    226 SMR Cont 2 Malfunction. Open or +B short in system main relay No. 2 circuit
    227 SMR Cont 2 Malfunction. Short in system main relay No. 2 circuit
    228 SMR Cont 3 Malfunction. Open or +B short in system main relay No. 3 circuit
    229 SMR Cont 3 Malfunction. Short in system main relay No. 3 circuit
    231 Deposit of SMR. System main relay + terminal deposited
    232 Deposit of SMR. System main relay - terminal deposited
    233 Deposit of SMR. System main relay + & - terminal deposited
    P3120 - HV Transaxle Malfunction
    234 Energy Balance Malfunction. Small reduction of motor magnetism
    235 Energy Balance Malfunction. Large reduction of motor magnetism
    236 Energy Balance Malfunction. Small reduction of generator magnetism
    237 Energy Balance Malfunction. Large reduction of generator magnetism
    239 HV Transaxle Malfunction. Shaft damaged
    240 HV Transaxle Malfunction. Generator locked
    241 HV Transaxle Malfunction. Torque limiter sliding
    242 HV Transaxle Malfunction. Planetary gear locked
    243 Motor Resolver Malfunction. Motor resolver inter-phase short
    244 Motor Resolver Malfunction. Motor resolver inter-phase short (When there is a history that the state of malfunction continued during inverter fail safe mode)
    245 Motor Resolver Malfunction. Open or short in motor resolver circuit
    246 Motor Resolver Malfunction. Open or short in motor resolver circuit (When there is a history that the state of malfunction continued during inverter fail safe mode)
    247 Motor Temperature Sensor Malfunction. GND short in motor temperature sensor
    248 Motor Temperature Sensor Malfunction. Motor temperature sensor malfunction
    249 Motor Temperature Sensor Malfunction. Open or +B short in motor temperature sensor
    250 Motor Temperature Sensor Malfunction. Motor temperature sensor performance problem
    253 Generator Resolver Malfunction. Generator resolver inter-phase short
    254 Generator Resolver Malfunction. Generator resolver inter-phase short (When there is a history that the state of malfunction continued during inverter fail safe mode)
    255 Generator Resolver Malfunction. Open or short in generator resolver circuit
    256 Generator Resolver Malfunction. Open or short in generator resolver circuit (When there is a history that the state of malfunction continued during inverter fail safe mode)
    257 Generator Temperature Sensor Malfunction. GND short in generator temperature sensor
    258 Generator Temperature Sensor Malfunction. Generator temperature sensor malfunction
    259 Generator Temperature Sensor Malfunction. Open or +B short in generator temperature sensor
    260 Generator Temperature Sensor Malfunction. Generator temperature sensor performance problem
    P3125 - Converter & Inverter Assembly Malfunction
    263 DC/DC Converter Malfunction. +B short in DCDC converter NODD wiring
    264 DC/DC Converter Malfunction. DCDC converter malfunction
    265 DC/DC Converter Malfunction. Open or GND short in DCDC converter NODD wiring
    266 VM Malfunction. Open or GND short in inverter voltage signal circuit
    267 VM Malfunction. +B short in inverter voltage signal circuit
    268 VM Malfunction. Inverter voltage signal is inconsistent with battery voltage
    269 VM Malfunction. Inverter voltage sensor malfunction
    270 VM Malfunction. Abnormality of line connection of inverter foltage signal circuit (When there is a history that the state of malfunction continued during inverter fail safe mode)
    272 Motor PWN Line Connection Malfunction. Abnormality of the line connection of motor PWM (When there is a history that the state of malfunction continued during inverter fail safe mode)
    273 Motor Inverter Gate Malfunction. Motor inverter malfunction
    274 Motor Inverter Temperature. Open or +B short in motor inverter temperature sensor
    275 Motor Inverter Temperature. GND short in motor inverter temperature sensor
    276 Sensor Malfunction. Motor inverter temperature sensor malfunction
    277 Sensor Malfunction. Motor inverter temperature sensor performance problem
    278 Motor Inverter Sinv. +B short in motor inverter stop signal circuit
    279 Motor Inverter Sinv. Over voltage of inverter
    280 Motor Inverter Sinv. Open or GND short in motor inverter stop signal circuit
    281 Motor Inverter Sinv. Voltage drop of inverter power source
    282 Motor Inverter Sinv. Inverter circuit broken
    283 Motor Inverter Finv. +B short in motor inverter fail signal circuit
    284 Motor Inverter Finv. Inverter overheating
    285 Motor Inverter Finv. Open or GND short in motor inverter fail signal circuit
    286 Motor Inverter Finv. Inverter circuit broken
    287 Motor Inverter Finv. Inverter internal short
    288 Motor Inverter Current Sensor Malfunction. Motor inverter current sensor malfunction (V phase sub sensor)
    289 Motor Inverter Current Sensor Malfunction. Open in inverter current sensor (V phase sub sensor)
    290 Motor Inverter Current Sensor Malfunction. Motor inverter current sensor malfunction (V phase main sensor)
    291 Motor Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    292 Motor Inverter Current Sensor Malfunction. Open in motor inverter current sensor (V phase main sensor)
    293 Motor Inverter Current Sensor Malfunction.
    294 Motor Inverter Current Sensor Malfunction. Motor inverter current sensor V phase performance problem
    295 Motor Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    296 Motor Inverter Current Sensor Malfunction. Motor inverter current sensor malfunction (W phase sub sensor)
    297 Motor Inverter Current Sensor Malfunction. Open in motor inverter current sensor (W phase sub sensor)
    298 Motor Inverter Current Sensor Malfunction. Motor inverter current sensor malfunction (W phase main sensor)
    299 Motor Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    300 Motor Inverter Current Sensor Malfunction. Open in motor inverter current sensor (W phase main sensor)
    301 Motor Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    302 Motor Inverter Current Sensor Malfunction. Motor inverter current sensor W phase performance problem
    303 Motor Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    304 Motor Gate Shutdown Signal Line Connection Malfunction. +B short in motor gate shutdown signal circuit
    305 Motor Gate Shutdown Signal Line Connection Malfunction. Open or GND short in motor gate shutdown signal circuit
    306 Failure in Monitoring Motor Torque Performance.
    307 Abnormal Current Value of Motor
    308 Detection of Collision Signal
    309 Motor PWM Line Connection Malfunction. Open or short in generator inverter switching wiring (GUU, GVU, GWU)
    311 Generator Inverter Malfunction
    312 Generator Inverter Temperature Sensor Malfunction. Open or +B short in generator inverter temperature sensor
    313 Generator Inverter Temperature Sensor Malfunction. GND short in generator inverter temperature sensor
    314 Generator Inverter Temperature Sensor Malfunction. Generator inverter temperature sensor malfunction
    315 Generator Inverter Temperature Sensor Malfunction. Generator inverter temperature sensor performance problem
    316 Generator Inverter Sinv. +B short in generator inverter stop signal circuit
    317 Generator Inverter Sinv. Over voltage of inverter
    318 Generator Inverter Sinv. Open or GND short in generator inverter stop signal circuit
    319 Generator Inverter Sinv. Voltage drop of inverter power source
    320 Generator Inverter Sinv. Inverter circuit broken
    321 Generator Inverter Finv. +B short in generator inverter fail signal circuit
    322 Generator Inverter Finv. Inverter overheating
    323 Generator Inverter Finv. Open or GND short in generator inverter fail signal circuit
    324 Generator Inverter Finv. Inverter circuit broken
    325 Generator Inverter Finv. Inverter internal short
    326 Generator Inverter Current Sensor Malfunction. Generator inverter current sensor malfunction (V phase sub sensor)
    327 Generator Inverter Current Sensor Malfunction. Open in generator inverter current sensor (V phase sub sensor)
    328 Generator Inverter Current Sensor Malfunction. Generator inverter current sensor malfunction (V phase main sensor)
    329 Generator Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    330 Generator Inverter Current Sensor Malfunction. Open in generator inverter current sensor (V phase main sensor)
    331 Generator Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    332 Generator Inverter Current Sensor Malfunction. Generator inverter current sensor V phase performance problem
    333 Generator Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    334 Generator Inverter Current Sensor Malfunction. Generator inverter current sensor malfunction (W phase sub sensor)
    335 Generator Inverter Current Sensor Malfunction. Open in generator inverter current sensor (W phase sub sensor)
    336 Generator Inverter Current Sensor Malfunction. Generator inverter current sensor malfunction (W phase main sensor)
    337 Generator Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    338 Generator Inverter Current Sensor Malfunction. Open in generator inverter current sensor (W phase main sensor)
    339 Generator Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    340 Generator Inverter Current Sensor Malfunction. Generator inverter current sensor W phase performance problem
    341 Generator Inverter Current Sensor Malfunction. (when there is a history that the state of malfunction continued during inverter fail safe mode)
    342 Motor Gate Shutdown Signal Line Connection. +B short in generator gate shutdown signal
    343 Motor Gate Shutdown Signal Line Connection. Open or GND short in generator gate shutdown signal circuit
    344 Failure in Monitoring Generator Torque Performance
    345 Abnormal Current Value of Generator
    P3130 - Inverter Cooling System Malfunction
    346 Water pump system malfunction
    347 Electric cooling fan system malfunction
    P3135 - Circuit Breaker Sensor Malfunction
    348 GND short in circuit breaker sensor
    349 Open or +B short in circuit breaker sensor
    P3140 - Interlock Malfunction
    You can make this DTC happen quite easily and safely by removing the service plug from the main battery and turning the car on.
    350 Safety devices operating with vehicle is stopped (ILK signal ON)
    351 Open circuit in interlock signal circuit while vehicle is running
    P3145 - Vehicle Speed Sensor Circuit Malfunction
    352 No input of vehicle speed signal during cruise control driving
    http://prius.ecrostech.com/GenInfo/DTCs/HVECU.htm
Loading...
