Effects of using 12V Cooler in Car
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Bluebelle, May 12, 2010.
  1. Bluebelle
    Bluebelle New Member
    16
    Sacramento, CA
    I have been thinking about purchasing a 12V Cooler to keep sodas and snacks in my car for some day trips. I'm just interested in a small one that will hold about 12 drinks or even smaller. Looking for recommendations on which brand to buy and also feedback on how using this will effect my mileage. Thanks in advance.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I have used one for several years in my 04, primarily on road trips and did not notice any effect on mileage. Most 12v coolers use between 30 and 50 watts so its not a large current drain.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Also, that 30 to 50 watts gets converted to heat, which must be removed from the cabin. This puts a small increased load on the A/C, but not much. The extra A/C load is about the same as carrying an additional passenger.
    Tom
  4. jdenenberg
    jdenenberg EE Professor
    3,842
    1,830
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My cooler uses about 50 watts which is 1/12 of a horsepower. Assuming about 75% efficiency in storing electrical energy, and taking into account that my 2004 Prius uses about 25 hp when cruising at highway speed, I am using about 0.5% of the car's energy output to run the cooler. That's a loss of about 1/4 MPG.
    JeffD
  5. brandonpa
    brandonpa New Member
    49
    Pennsylvania
  6. nwprius
    nwprius Member
    227
    35
    Lacey, Washington
    I have used my thermoelectric cooler for years in an '04 and '06 Prius with no effect that I can detect. And, when I am out of the car I run the cooler on a Jumpstart 1200 Peak Amp/650 Amp system which I keep plugged into the 12V outlet for recharging while driving. It has been capable of up to 6 hours of operation of the cooler while we visit a museum, etc.
