EGR and engine trouble
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bobert53, Jul 7, 2022.
  1. Bobert53
    Bobert53 Junior Member
    Mid-Coast Maine
    Just finished an EGR cooler cleanup. 130k and totally blocked. Got it cleaned up and reinstalled. Double checked all the connections. When the engine starts it surges and stumbles, little response from the accelerator and finally dies. Suggestions? I'm stumped!!
  2. JC91006
    16,935
    8,646
    Start it and drive off right away.
  3. Mendel Leisk
    42,293
    Did you push the pcv and fuel vapour hoses back onto the intake manifold?
    (just guessing)
  4. ChapmanF
    18,971
    Yes, my first thought is that something has been overlooked, even with the double-check.
  5. JC91006
    16,935
    8,646
    many people forget to plug back the maf sensor
  6. Mendel Leisk
    42,293
    IIRC I've done that, and it ran ok, 'cept had check engine light.
  7. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    loose connection or connector
  8. Bobert53
    Mid-Coast Maine
    Thanks for the replies. Tore it all down again today. What a bear!! There are a couple of nuts and a stud down in there somewhere!!!
    Paid due diligence putting it all back together, especially the gaskets. I realized this is one of those units you don't tighten until all the bolts are in. The car fired right up as she should have. Happy camper here. Now to get the check engine light off......
    CR94 likes this.
  9. Mendel Leisk
    42,293
    I had check engine light after one of my EGR forays. Might have been disconnected MAF, can’t remember. Anyway, after about 4~5 startups (after fixing the issue), light went out.
