EGR Assembly cleaning help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobzchemist, Apr 18, 2018.
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    I just bought an egr assembly off ebay - tube, cooler and valve all together. From what I can see without taking it apart, the insides are moderately dirty. Does anyone have any recommendations on what to use to clean these out and cause the least damage? Since I have a spare assembly, I can leave it soaking for weeks, if need be.
    Also, does anyone have a list of the replacement gaskets I'll need to install this?
    Lastly, I'm curious about people's opinions on what to do with the original parts. How often do these need to be cleaned out, or in other words, does it pay to keep a spare assembly hanging around for next time, or should I sell it?
    Bay Stater and mjoo like this.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    you can use seafoam or purple power degreaser.clean every 40 to 50k miles.i would keep the extra part so there won't be down time bleaning
  3. mjoo
    mjoo Senior Member
    1,127
    1,317
    Michigan
    Purple power and carb cleaner did half the job of cleaning my spare cooler. A half dozen hour-long soaks in hot solutions of Oxiclean will make it look like a new part.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
  5. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    As others have said, start cleaning with carb cleaner or brake cleaner. If the ports are clogged up with soot, then use a metal poker wire to open up the ports. Then go through several warm oxiclean cycles to get it sparkling clean. Heard that easy off oven cleaner works well too.
    mjoo and Raytheeagle like this.
  6. tankyuong
    1,555
    660
    Central MO
    how does one mix oxyclean in powder form?
  7. Mendel Leisk
    38,737
    I put about 3 heaping tablespoons in a measuring container, then added about 100~150 cc of the hottest tap water I could muster. Stirred the heck out of it, and dumped it in immediately after swirling. Then add another 50 cc or so hot tap water to the residue that stuck in the beaker, swirl and dump it in. A nice rubber stopper in one end of the cooler would be ideal; I made do with a wooden bung whittled from a piece of dowel and wrapped with a double layer of nitrile glove.
  8. Mendel Leisk
    38,737
    Here's some notes I made, regarding stopper sizes:
    Intake opening diameter (at exhaust): 20.9 mm (#3 stopper)
    exit opening diameter (at EGR valve): 25.7 mm (#5.5 stopper)
    Bay Stater likes this.
  9. Bay Stater
    534
    771
    Central Mass
    I used a metal chair rubber end cap to cork up mine. Worked great. (y)
    Raytheeagle, Mendel Leisk and mjoo like this.
  10. Bay Stater
    534
    771
    Central Mass
    I bought the liquid Oxi Clean laundry detergent. Did roughly one part Oxi Clean, five part hot water. Worked out great.(y)
    Raytheeagle and mjoo like this.
  11. tvpierce
    tvpierce Senior Member
    949
    879
    Maine
    2013 Prius v wagon
    Would boiling water aid in the process?
    Bay Stater, Raytheeagle and mjoo like this.
  12. Raytheeagle
    11,251
    15,482
    2019 Prius Prime
    Depends on ones definition of hot vs. boiling ;).
    Boiling water will be ~212 F whereas hot water can be anything above ambient :).
    I used hot water out of our Kerig as we don’t have a tea kettle anymore:cool:.
    The hot water and Oxiclean solution works well after refluxing carb cleaner for a good while(y).
  13. Simonak
    Simonak Member
    51
    32
    If you want to do it fast use Easy off Oven cleaner. No need for hours of soaking.
    Bay Stater and Mendel Leisk like this.
  14. Mendel Leisk
    38,737
    Yeah I think it's reaction of a caustic cleaner that's lifting and floating off the carbon, and oven cleaner is a little more caustic, IIRC oxi-clean is 11 and typical oven cleaner 13? Oxi's a little more benign, and it get's there, though I think you're right, oven cleaner will work faster.
    I'd vote no, and a bit more risky, and it's mostly the caustic quality that's doing the cleaning I think. Maybe boiling water would aid in dissolving more, but all in all I think tap water hot is fine. If you sprinkle lye into cold water it will heat up all on it's own, food for thought.
    Funny, was looking for lye the other day, for drain cleaning, and it's not for sale anymore, apparently used in meth manufacture. o_O
    Bay Stater, tvpierce and mjoo like this.
  15. Bay Stater
    534
    771
    Central Mass
    I microwaved the water to get it hot. (y)
    tvpierce and Raytheeagle like this.
  16. tvpierce
    949
    879
    Maine
    2013 Prius v wagon
    Me too.
  17. Old Wrench It
    Old Wrench It Member
    57
    51
    Used a wine cork in one end and a champagne cork with rubber glove in other
    Raytheeagle and Bay Stater like this.
