  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You never know until you look;).
    To get an idea, pull the egr pipe between the cooler and manifold and this will give you some idea. This is what the discharge side of the egr valve looked like which is where the egr pipe is: F53C25E8-A0D6-4E5E-AEF9-C473F2D26489.jpeg
    It’ll give you an idea on timing of your next steps(y).
    sfv41901, SFO, granTORRESmo and 2 others like this.
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I'm in same boat. The thought of this is dreadful o_O
    sfv41901 and Raytheeagle like this.
  3. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Whenever you want to perform this, let me know and we’ll see what we can do(y).
    SFO, m.wynn and Grit like this.
  4. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Yea i know, we did that on my dads Auris Touring Sports, it was completely blocked off lol, so the whole engine was vibrating at low RPM. When i say that the auris was vibrating i mean seriously vibrating... it felt like the front wheels were oval shaped when we first got it. Our 2013 Auris has gone 100K miles, so toyota cleaned the EGR valve and the flushed the gearbox, it felt like a brand new car after they did that, only costed 600 dollars. We usually dont do any service on our toyotas at home, because every service u do at toyota u get one more year of Hybrid warranty on top of the 10 year warranty u get from the factory, (hybrid battery warranty that is). So for us it makes more economical sense to let toyota mess around in the engine room when it only costs 200-300 dollars a year while the battery itself costs like 2700 dollars new. We have used maybe like 600 dollars total on my prius now, wouldnt be that great if we didnt have the battery warranty incase some happens before i sell it. I will most likely buy a 2015 Prius, 2013-2015 Auris, 2013-2015 BMW 3-series or a 2012-2015 BMW 1-series after my 2011 prius.
    I just feel like my car is kinda sluggish compared to my moms 2010 prius which has only gone 40k miles. So i suspect its the EGR valve that needs cleaning (and i obviously know that it has 4 times more miles on it, but i highly doubt its supposed to feel like this, i have done different tests in it using a OBD2 adapter and the engine looks to be totally fine, it fires when it should, emmisions is on point and all that) it kinda vibrates like my dads auris did when we first got that, just not as much lol, But yea, my problem with the car is that its super annoying in roundabouts and stop signs, it takes a second before it reacts since it takes so long for it to start the engine compared to my moms and my dads that is just there with the power right away.
    #15604 MagnusAG99, Apr 7, 2018
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Just completed preventative maintenance day #2:).
    On today’s docket:
    • Intake manifold cleaning. Not as bad as the other components, but the small races from the egr circuit still got cleaned as well as the sponge pool ;) 60802971-AB7F-4062-90A5-5BBE3EE76A0B.jpeg 092F082D-939D-4C98-9015-43C7815927E3.jpeg 538B166B-A0E4-4D43-A4F4-EF577E35836F.jpeg
    • MAP sensor cleaning. Dirty and got its own cleansing BD08CB1C-793A-463B-A1A8-5198F93F8EB0.jpeg
    • Transaxle drain and fill. This was done ~40 k miles ago, but still was not red by any means B7605314-0F5C-4FCE-8B29-731ABF75782D.jpeg
    • Also changed out the oil catch can hoses to fuel line as the clear braided hose that came with the kit were pinched:(.
    Onto the wife’s RX tomorrow for both transaxle drain and fills(y).
    sfv41901, SFO, m.wynn and 9 others like this.
  6. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    (y)
    Awesome job(y)
    Raytheeagle likes this.
  7. Prodigyplace
    12,560
    11,778
    Central Virginia
    You should have been doing the maintenance on your Dad's car! ;)
  8. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    That’s up when we visit them in mid June(y).
    SFO, m.wynn and Bay Stater like this.
  9. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    Another autocross event down! Gotta love the looks on peoples faces when you are faster than them with 1/3'd the HP!
    #15609 TheChip, Apr 7, 2018
  10. Prodigyplace
    12,560
    11,778
    Central Virginia
    You take all your tools? :eek:
    Bay Stater and Raytheeagle like this.
  11. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    There’s plenty there to go around;).
    Some of them migrated into my collection many years ago:whistle:.
    Some are still with me too(y).
    Dylan Doxey, SFO, m.wynn and 2 others like this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Which brand of ATF you refilled with?
  13. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    WS ;).
    I bought a case:).
    The RX takes 8 so just the right amount(y).
    sfv41901 and Bay Stater like this.
  14. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Went to Hybrid Pit to buy some springs from another member. Ended up getting them installed and having Sean disable the ufo noises.
    Turns out 7 other Prius came out. Good meeting everyone. IMG_20180407_190512.jpg IMG_20180407_141005_881.jpg
    Pixel 2 XL ?
  15. Mendel Leisk
    41,449
    I wonder how MAP sensors operate, particularly when drenched in oil??
  16. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    That's NS!
    For "nothing special".:cool::whistle::whistle:
    Prodigyplace and Raytheeagle like this.
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Not sure, but having a liquid coating the probe will act as a barrier to the probe:(.
    But there is good vacuum so not sure how accurate the pressure reading needs to be. I can check on Techstream a little later today and see what she reads;).
    I know I never got a code pointing to the MAP sensor though (y).
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    That may have been an inside info question as at the last meetup we had one member bring type IV for his gen 2:whistle:.
    Caught it before it was too late(y).
    SFO, Grit and m.wynn like this.
  19. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Good thing you caught that as we were refilling the ATF IV on that gen 2 :eek:
    Next atf change, in the late future, I plan on goong with redline for ATF.
    SFO and Raytheeagle like this.
  20. Mendel Leisk
    41,449
    I once poured about a cup of motor oil into an automatic (after a drain), before I woke up and stopped. What I did in that scenario:
    1. Drained it and refilled with proper fluid.
    2. Drove to dealership, and got sufficient fluid for two more changes.
    3. Drained it and refilled with proper fluid.
    4. Drove around the block a couple of times.
    5. Drained it and refilled with proper fluid.
    Prodigyplace, Grit and Raytheeagle like this.
