EGR cleaning 1st time @240K
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by oasmith, Oct 21, 2018.
  1. oasmith
    oasmith Junior Member
    42
    22
    So I finally caved and cleaned the EGR cooler. After opening it up, I don't even know how my car was still running. I had cleaned the intake manifold and EGR pipe about 30-40k miles ago, and was surprised to see that it already looked about as bad as the first time. A bit of oil in the throttle body, but I didn't have the OCC. Maybe next time, if the car lasts. Anyway, when I was spraying the parts cleaner in one end, of the EGR it was pooling up at that end, not even running through. I only got one "after" picture since I was quickly running out of day time. Since the intake was just as bad, I cleaned that again as well. I finally got the EGR to drain through, and could blow air through it. Thanks @Raytheeagle for pushing me in to doing it.
    RMB, Bay Stater and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Glad you go it sorted:).
    That was very clogged:eek:.
    Prepare for the next round as it will need to happen again(y).
    52,393
    sounds like high speed driving causes more blowby, or less? that's a lot of miles on a '14.
