EGR Cleaning: What did I get myself into?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bay Stater, Jan 1, 2018.
  1. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Purple Power was one of the first mentioned in the EGR cooler cleaning thread because it won some comparison test, and it really does work well. I got mine from pretty clogged to spotless/like-new in over the course of about a day. First you need to push all the way through each passageway with a stiff wire (hand rotating the wire as necessary) under running water at the sink. Then do soaks in Purple Power with the cooler plugged up. I actually started with a Purple Power soak before trying the wire, but would go straight to the wire poking first if I were to do it again.
    Bay Stater and kc410 like this.
  2. Mendel Leisk
    41,455
    I saw a comparison (of diesel EGR cleaner?) where Purple Power was highly rated. Unfortunately it's hard to get locally. So first I went with brake cleaner, but the results were so-so.
    @mjoo suggested OxyClean; I had an enormous box of it on hand, so I gave it a try, with very good results.
    I suspect PP is similar formulation, a moderately caustic cleaner. Maybe some other trace ingredients, who knows.
    I prefer Oxy in powder format, buying a big bottle of liquid format cleaner is likely less economical?
    mjoo and Bay Stater like this.
  3. Lightning Racer
    239
    321
    Anchorage, Alaska
    I got a gallon of Purple Power for around $6 at the local Walmart, so that was pretty cheap. I ended up using very little of it, so I'll find some other uses for the remaining.
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    It doesn't hurt to use brake cleaner or soak with Oxi Clean to soften the crud before pushing a wire through the ports. I filed a point on the wire tip to aid easier push through. Done the ports twice, may do a third time. Been sick for the last few weeks so progress has been slow. :(
  5. Tande
    Tande Active Member
    539
    322
    Mich.
    Has anyone tried This .......yes, a little steep, I know
    Bay Stater likes this.
  6. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Head gasket is holding up great. Now I have no excuse and continue driving it.
    I got used to alot of torque from Volt and Prius feel like going no where unless I flooring the accelerator.
    Raytheeagle likes this.
  7. Mendel Leisk
    41,455
    Are you in ECO mode? That'll do it.
    Montgomery and leeb18c like this.
  8. leeb18c
    272
    202
    SF Bay Area
    I mostly drive in Power mode and sometimes Normal mode. It's just that the instant torque of electric motor in Volt that spoiled me. :)
    RMB, Raytheeagle and Mendel Leisk like this.
  9. Bay Stater
    534
    771
    Central Mass
    The EGR Cooler is finally clean! It went through multiple rod poking through the ports and numerous Oxi-Clean washes. For fun, here are some before and after the cleaning pix.
    The EGR Valve.
    IMG_20171230_125358345.jpg IMG_20180128_163618838.jpg IMG_20171230_130146512.jpg IMG_20180128_163524135.jpg
    The EGR Cooler. You can see daylight through the ports!:cool: The 3rd pic looks like the solar eclipse I saw last Summer!:ROFLMAO:
    IMG_20171230_125419260.jpg IMG_20180128_162643472.jpg IMG_20180128_163100487.jpg
    The EGR Assembly reassembled and ready to be install in my car.:) About a month or two from now.:whistle:
  10. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    You can definitely see visual improvement :).
    Good luck with the replacement (y).
  11. Bay Stater
    534
    771
    Central Mass
    Well, the odometer now reads 120K miles. Time to start the colossal 120K DIY preventive maintenance. The best way to approach it is to break it down into multiple work days. Today I serviced the oil and the ATF. This is the 2nd time changing the ATF. The 1st service was done at 50K (I bought the car used with 40K on it). The ATF drained was darkest red in color. :eek:
    Over the next few weekends, will change the plugs, clean the IM, change the PCV, clean the EGR pipe, replace the EGR Valve/Cooler assembly with the one just cleaned.:cool: Maybe install an OCC during that time while the parts are off. :unsure: Still debating whether I want to do that.
    On another weekend day, will service the ICE/Inverter coolants.(y)
    m.wynn, danlatu, m3pare and 4 others like this.
  12. Bay Stater
    534
    771
    Central Mass
    No more debate! I went ahead and ordered a Ruien OCC from Amazon. Had to get the vented version in order to have it by this Friday :), otherwise would have to wait for at least a month.:( Bought a 10 ft braided hose and 3/8 barb from Home Depot.
  13. RightOnTime
    RightOnTime Senior Member
    789
    1,657
    183
    Kidnapped in OC, CA
    Working on a 2010 Prius with over 300k. Previous owner used car as Taxi and let's just say this is the worse we seen!
    iPhone ?
  14. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    Wow. How does the exhaust manifold look?
    Pixel XL ?
  15. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Ready for this?
    iPhone ?
  16. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    That's one stuffed turkey!
    Pixel XL ?
  17. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
  18. RightOnTime
    789
    1,657
    183
    Kidnapped in OC, CA
    Owner got lucky! No burning of oil! Only major expense was the replacement of the Traction Battery
    iPhone ?
    Bay Stater, m3pare and Raytheeagle like this.
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Wouldn’t have guessed that based on the coking layer and appearance :eek:.
    RightOnTime and Bay Stater like this.
  20. Bay Stater
    534
    771
    Central Mass
    Kindly pass me the bucket. Blaaaah!
