EGR Cleaning: What did I get myself into?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bay Stater, Jan 1, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
  2. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    New PCV installed
    m3pare and Raytheeagle like this.
  3. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Easy access :).
    Excellent time to replace (y).
    Bay Stater likes this.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    But think how much faster it can go with more hands available;).
    When and where are we “randomly” meeting again :whistle:?
    SFO, RMB, Bay Stater and 1 other person like this.
  6. NutzAboutBolts
    1,698
    1,745
    Bay Area
    Lol, you don’t want more than 1 hand on the vehicle, especially if theres nuts and bolts are involved because you might misplace it or accidentally install it in the wrong spot... it happens.
    farmecologist, RMB, m3pare and 2 others like this.
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    A good labeling and can system helps;).
    The key is communication (y).
    SFO, Bay Stater and NutzAboutBolts like this.
  8. Mendel Leisk
    41,457
    Yeah be sure to run pipe cleaner, thin bottle brush or what have you, through these passages, the EGR "capillaries", plus the main EGR gallery. I tried in vain to get it spotless, finally settled for functionally clean.
    farmecologist, RMB, m.wynn and 3 others like this.
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    No need for spotless;).
    You’ll go back in eventually, so good enough for now works(y).
    m.wynn, Bay Stater and NutzAboutBolts like this.
  10. Bay Stater
    534
    771
    Central Mass
    Overall, the intake manifold was relatively clean. The inlet ports were wide open. Very little slug.
    RMB and Raytheeagle like this.
  11. Mendel Leisk
    41,457
    With the EGR cooler and oxiclean I got to spotless, but it's stainless steel. The intake manifold is shite, porous plastic, not happening.
    Raytheeagle and Bay Stater like this.
  12. Bay Stater
    534
    771
    Central Mass
    LOL, and I haven't touched the EGR assembly yet. Have to rewatch your video before proceeding! (y)
    RMB, NutzAboutBolts and Raytheeagle like this.
  13. Bay Stater
    534
    771
    Central Mass
    You got that right! Thanks for the tip. I sprayed brake cleaner through them. Will try to locate a small brush.
    RMB, Mendel Leisk and Raytheeagle like this.
  14. Bay Stater
    534
    771
    Central Mass
    I've tried, but can only get it so clean.:whistle:
  15. Bay Stater
    534
    771
    Central Mass
    Throwing this question out there. Should I reinstall all the parts in front of the engine block before tackling the EGR assembly? :unsure:
    I will also need to rig up the OCC.
    Raytheeagle likes this.
  16. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    If you’ve determined where you’re putting your OCC and it won’t impede access to anything, I’d install;).
    You’ll need the intake manifold on before the egr pipe is installed, so that’s the only order of operation important though:).
    Good luck through your project (y).
  17. Bay Stater
    534
    771
    Central Mass
    Compartmentalize!
  18. Mendel Leisk
    41,457
    You mean the air intake, air filter box. I would leave it off till you're done with the egr: IIRC you need to remove the EGR pipe, and the air box needs to be out of the way for that? Doesn't hurt to leave everything off.
    NutzAboutBolts and Bay Stater like this.
  19. Bay Stater
    534
    771
    Central Mass
    Oil catch can tube routing and intake manifold reinstallation.
    IMG_20180310_231759594.jpg IMG_20180311_001851806.jpg IMG_20180310_231810745.jpg
  20. NutzAboutBolts
    1,698
    1,745
    Bay Area
