EGR Cleaning: What did I get myself into?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bay Stater, Jan 1, 2018.
  1. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Twins! :ROFLMAO:Finally got it out. What a bear! To remove the lower nut from the bolt, used a long dowel to hold the wrench in place underneath the car. In inspection of the ports, they looked good. Will take apart for later cleaning.
    FYI, My car is mostly driven on the highway at 70-75 MPH.
    IMG_20180311_131049293.jpg IMG_20180311_131232555.jpg IMG_20180311_132346909.jpg IMG_20180311_131336200.jpg
  2. Mendel Leisk
    41,457
    Success!!!!
    I notice in the video @NutzAboutBolts reaches clockwise around with his left hand, is actually able to touch that dang lower nut. Maybe try that when re-installing. Also, did you manage to catch the rearmost gasket, before it dropped? I realized I was one gasket short when reassembling, found it, dropped down a bit. It's too bad they don't have retaining clips on that, would help align it too.
  3. Bay Stater
    534
    771
    Central Mass
    It's been a rough afternoon. I lost the EGR cooler gasket underneath the car frame works. Had to improvise. Ran down to the local auto parts store to buy an exhaust gasket material. Made my own. Should work out.:mad: IMG_20180311_160101238.jpg
    #103 Bay Stater, Mar 11, 2018
  4. Bay Stater
    534
    771
    Central Mass
    The cleaned EGR assembly has been installed. :)
  5. Mendel Leisk
    41,457
    It's in there somewhere. Did you look with good light? In my case (same story) it hung up a little ways down. Or it may be laying on the underpanel. Take that off, or just pry open that flap? Still up on ramps?
    Yeah, it not having clips, like the one at the EGR pipe, is a design fail @Prius Team.
    Bay Stater, RMB and m.wynn like this.
  6. Bay Stater
    534
    771
    Central Mass
    It's in there on the bottom in a tray like crevice.:mad: I could see it from above and tried retrieving it with an magnetic tip pole. Didn't work out. It slipped underneath into the crevice which was out of view.:mad: Not accessable of course.
    I did have the under cover off.
  7. Bay Stater
    534
    771
    Central Mass
    The throttle body, EGR pipe, intake box, and air filter element reinstalled.
    IMG_20180311_184458884.jpg IMG_20180311_182208647.jpg IMG_20180311_190523650.jpg IMG_20180311_172527120.jpg
  8. Bay Stater
    534
    771
    Central Mass
    Everything is done!
    Will have to figure out the OCC mounting some other day. Have a plastic cup as a place holder.:D
  9. Bay Stater
    534
    771
    Central Mass
    The million dollar question of the day. Will it start!!! :unsure:
    RMB, Raytheeagle and m3pare like this.
  10. Bay Stater
    534
    771
    Central Mass
    And the answer is, drum roll please, YES!
    Drove the car for 10 miles or so, no problems.:);)(y)
  11. Mendel Leisk
    41,457
    What, not even a spurious check engine light? Excellent! Great that you have an Oil Catch Can in too, you have all the bases covered.
    Montgomery, RMB, scona and 2 others like this.
  12. Bay Stater
    534
    771
    Central Mass
    No check lights what so ever. I was nervous. :whistle:
    Mendel Leisk, Raytheeagle and mjoo like this.
  13. Bay Stater
    534
    771
    Central Mass
    The only thing left to do is to change the coolent fluids. We'll save that for some other day.:D
    I want to thank everyone on PC for valuable DIY information. Would not have known or done it otherwise.(y)
  14. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Old mechanic's trick for removal and reinstall of spark plugs in deep wells such as in the Prius. A one foot length of black rubber fuel line or ATF line will fit snuggley over the white ceramic insulator part of a spark plug. It will allow enough friction that the plug can be turned, but the line can be easily pushed on for removal and pulled off for install.
    #114 tvpierce, Mar 12, 2018
    HikerTed, Montgomery, m3pare and 2 others like this.
  15. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    I need to do all of this stuff on our two Prius's this spring. Still not quite warm enough to take it on yet. Or that is just my excuse. :whistle:
  16. mjoo
    mjoo Senior Member
    1,156
    1,328
    Michigan
    Congrats! Just think how many thousand$ you saved doing it yourself and preventing the bad headga$$$ket!
    Let us know how much you save on gas as your MPGs multiply.
    Pixel XL ?
    Bay Stater likes this.
  17. Bay Stater
    534
    771
    Central Mass
    I have a garage, and a portable electric heater so the environment was comfy warm. (y)
  18. Bay Stater
    534
    771
    Central Mass
    Plan on a weekend for each. (y) I started the work late Saturday morning and did not get the job done until Sunday night around 9 PM. Then one additional hour to clean up.:eek:
    farmecologist and Raytheeagle like this.
  19. Bay Stater
    534
    771
    Central Mass
    Thank you! Will do! Also installed an OCC.
    Based on the parts inspection (eg. IM, EGR Assembly, pipe, etc.) after removal and at 120 K my car does not consume oil would indicate the car was running pretty good before the cleanings. Should be good for another 120 K.:whistle:
    RMB, Raytheeagle and mjoo like this.
  20. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,698
    1,745
    Bay Area
    I hope you guys can support my YouTube channel as well by subscribing to it :D I’ll appreciate the love heheh
    HikerTed, Robert Holt, RMB and 5 others like this.
