1. James Roberts
    James Roberts New Member
    Clarksville
    So ive got my roommate's 2012 Prius Three apart to clean the EGR cooler as it was caked with carbon really bad, got it a majority of the way clean but still having issues cleaning the exhaust side of the EGR cooler, ive run brake cleaner, degreaser, pretty much the typical stuff to unclog it and water flows through it but not completely, been racking my brain to try and figure out what else i can do to clean it the rest of the way so i can get this thing back together and running somewhat smoothly, Help
    (Photos below are from before cleaning)
  2. 20113rdgen
    20113rdgen New Member
    New Zealand
    I used oven cleaner. Run whatever product you use through a quality ai.
    Also more important than the cooler, clean the egr passages on the intake manifold. Special attention on cylinders one and 2
    CR94 likes this.
  3. 20113rdgen
    New Zealand
    You want to make as sure whatever products you use are 1. Effective and 2. Don’t damage the material.
  4. Mendel Leisk
    42,323
    The cooler is stainless steel. Accordingly, I would recommend:
    Put rubber stopper in the the smaller of the two end holes. It’s roughly 21 mm inside diameter, and a #4 stopper is suitable. This allows you to prop up the cooler, say in corner of laundry sink, and pour in just enough cleaning solution (takes about a cup), and let it soak.
    For solution, I’d recommend a water based caustic cleaner, 20% (by weight) potassium hydroxide (KOH). AFAIK that chemical is still readily available in the States, being a component of DIY soap making. And it’s actually a bit more effective, say compared to sodium hydroxide (NaOH). The latter is used in oven cleaner and drain cleaning products, but is difficult to buy now without a licence, due to being used to produce meth.
    anyway, cork the cooler, then (carefully, with appropriate precautions) mix the solution, pour it in, prop up the cooler in corner of laundry sink.
    after about an hour, pour it out, rinse thoroughly, repeat as needed. After each cycle inspect with a good pinpoint light source, till you’re seeing virtually no carbon, just clean/bare metal.
    if the cooler is clogged to the point that solution can’t even penetrate, gently working a wire through helps.
    Have a look through the EGR links in my signature (on a phone turn it landscape to see signatures), for tips, tools, workflow.
    #4 Mendel Leisk, Jul 10, 2026
  5. James Roberts
    Clarksville
    I mean would that work to break up the carbon deposits? Like this thing is completly clogged and like no light is coming through when i do shine a light through it, ill try it nd see cause if i can get this thing clean enough to function until i can get a new one itd work
  6. 20113rdgen
    New Zealand
    Its really low effort so its worth trying. I did 3 rounds of spraying it in both sides, waiting 1 hr, then rinsing.
  7. Mendel Leisk
    42,323
    Its primary function, like its namesake, is to cool the exhaust gas, not just “allow” gas through. For that, the cleaner the internal radiator is, the better.
  8. cdherman
    cdherman Member
    68
    27
    Kansas City
    I have cleaned three so far. One failed after cleaning (using stopper technique and Draino). Failure means coolant into the chambers and a blown HG. Do a basic pressure test on the EGR cooler after cleaning (hold a finger over two of the coolant ports and blow into the third). If you get a hissing sound, you are leaking and the cooler is toast. Do NOT reinstall.
  9. Mendel Leisk
    42,323
    Did you use mechanical means to clean the cooler interior, say a wire? By hand, or chucked on a power drill?
