EGR Cooler-Help!
Discussion in 'Gen 3 Prius Technical Discussion' started by Borninblue, Apr 20, 2019.
  1. Mendel Leisk
    42,164
    Taking the engine underpanel off can help. But stuff can still just drop part way. That's where I found my (dropped) rear gasket.
    Yeah something like an old towel under the zone you're removing makes a lot of sense. If you can manage to scrunch it in there, it's so crowded.
    mikey_t likes this.
  2. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    We found a plier on bottom of under panel at our meet ups one time.
    RMB, Raytheeagle and Mendel Leisk like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Grit likes this.
  4. Mendel Leisk
    42,164
    Good pliers? :whistle:
    Grit and Raytheeagle like this.
  5. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    They still worked, so good enough ;).
    I bet the mechanic afterwards was a bit confused where they went:LOL::ROFLMAO:.
    I bet one of the other mechanics was blamed(y).
    Grit and Mendel Leisk like this.
  6. ASRDogman
    ASRDogman Senior Member
    7,967
    4,046
    The gaskets are so inexpensive, it's not worth reusing them. At least not for me.
    If you have no choice, well, you have no choice. :)
  7. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Add a dab of RTV silicone?
    Pixel XL ?
  8. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    Corrosion loves my Pri. I tried to take the two screws off the EGR valve to lubricate it. The screws are corroded and will not break. Sprayed with liquid wrench and soaked them to no avail......can’t win with this project.
    Raytheeagle likes this.
  9. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    I’ve worked on 2 Prii from the east and you can tell the ones that come from the salt belt:eek:.
    But it just means you have to be smarter and more tactful than the rest of us;).
    Good luck and you’ll get there(y).
    Grit and Borninblue like this.
  10. Borninblue
    233
    158
    Cleveland, Ohio
    Finally broke them free....Ohio the lovely rust belt.
  11. Mendel Leisk
    42,164
    Was the engine underpanel intact? Always parked outdoors, heavy dew conditions? I would think those nuts are pretty sheltered.
    OTOH, I've seen some engine bay pics where every nut, bolt, bracket and hose clamp is rusted all to heck.
  12. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Don’t forget the salt spray gets into the engine bay goes everywhere :eek:.
    And the 2 Prii I’ve worked on had all the plastic shielding in place;).
    Makes me thankful we moved to an area free of this phenomenon (y)
  13. Borninblue
    233
    158
    Cleveland, Ohio
    Salt spray, hit the nail on the head. I bought mine used about 15K ago. Was probably kept outside, but I now always garage it. The body is in amazingly good shape. But EVERY bolt has some type of corrosion. The undershield is intact, although missing all but three clips lol.
    Grit, Mendel Leisk and Raytheeagle like this.
  14. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    When I helped @m.wynn with his water pump and egr circuit cleanse a couple of years back, it was amazing what the front of the engine looked like:eek:.
    All the piting corrosion and rusted fasteners:oops:.
    When I cleaned the egr circuit of his 2011 that his daughter had it was in similar condition. Only this time when I removed the splash shield I was pelted with dirt and rocks:whistle:.
    Definitely put through it’s paces off road. A place not a lot of Prii traverse(y).
    Grit, m.wynn and Mendel Leisk like this.
  15. Borninblue
    233
    158
    Cleveland, Ohio
    The project is complete, I’ll admit I was a little nervous after everything was put back together. I changed the plugs too, which the previous owner said were changed at 100,000. I have a hard time believing it how fouled up they were.
    Upon starting The engine was giving a death shake and light smoke was coming out of EGR cooler. The engine shaking and smoke stopped a few minutes later and all was fine. No codes thrown or anything which was surprising. I believe the smoke had to be eithier from oven cleaner that wasn’t totally flushed out or maybe? It was definitely smoking from the cooler.
    The results so far are pretty amazing. I am seeing an increase of 5 mpg ! (after driving on it for few hours).
    I can definitely tell I have more power off the line, and engine is transitioning from from EV less harshly. I’m debating on water pump and thermostat swap next.
    I have a friendly challenge going with family members who have been teasing me about the car and why I’m spending the time and money working on this car. They believe it will be dead within 10-20,000 miles. Creeping up on 128K and I really want to take it to 300K. Hopefully she will last me!
    #35 Borninblue, Apr 25, 2019
    Grit, youdiejoe, Mendel Leisk and 2 others like this.
  16. ASRDogman
    7,967
    4,046
    I'm very happy for you! Now you can reap what you sowed!
    It's a good feeling isn't it? :)
    There's always some smoke after doing all the work you've done. As long as it stops! :)
    Grit, Borninblue and Raytheeagle like this.
  17. Mendel Leisk
    42,164
    Maybe that smoke was from spray used to loosen the back bolts on the EGR.
    Raytheeagle, Grit and Borninblue like this.
