"EGR DELETE" Instructions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paladain55, Jun 17, 2023.
  1. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I've unplugged the EGR and it's been great. No headgasket yet.
    Not a fan of the PCV to atmosphere. Having a slight vacuum in the crankcase is a good thing that boils off water and fuel. I might check it with an oil analysis to know if PCV is still doing its job.
    SM-A536V ?
    Bill Norton and StarCaller like this.
  2. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    You could check that more easily, by ascertaining that fresh air is entering the PCV intake.
    Between the time of draft tubes, but before universal PCV, some engines got by with an intermedate stage, whereby blowby was vented to the upstream side of the throttle plate, so there was no fresh air entering the crankcase. That met the requirement not to dump nasty blowby gases into our atmosphere, but did nothing to flush condensation out of the crankcase.
    Bill Norton likes this.
  3. Bill Norton
    Bill Norton Senior Member
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    This is so true!
    With the pcv valve tubing directed to the atmosphere there is NO FLOW of air in the crankcase.
    The crankcase blow-by gasses can just as easily go back towards the 'fresh air in' port,, as they are to push through the PCV valve which is expecting a lower pressure to suck the gases out.
    A slightly lower pressure in the crankcase is good for the seals, rotating and stationary seals.
  4. ChapmanF
    19,020
    Back in the day, it was directed to the atmosphere through a 'road draft tube' that pointed down into the slipstream underneath the car. When you were moving at any sort of speed, that would suck the crankcase vapors out, while air flowed in through a breather filter somewhere else on an engine, flowing right through the crankcase.
    Of course it didn't provide much draft when the car was moving slowly or stopped.
  5. Mendel Leisk
    42,343
    Googled:
    If every car owner in a city were to cause their cars to vent the crankcase fumes to the atmosphere, what would be the environmental impact? Say Los Angeles.
    The AI response:
    Venting crankcase fumes directly to the atmosphere in a dense city like Los Angeles would cause a significant increase in volatile organic compounds (VOCs) and hazardous hydrocarbons, worsening air quality and increasing respiratory health issues. This would dramatically increase photochemical smog formation and create a toxic, pungent environment due to high levels of unburned fuel vapors, particularly with LA’s smog-trapping, bowl-shaped topography.
    Key environmental and health impacts include:
    • Increased Smog: Crankcase emissions contain VOCs that, when exposed to intense sunlight, accelerate the formation of ground-level ozone, a major component of LA's infamous smog.
    • Toxic Air Pollution: The fumes release concentrated pollutants like benzene and other hydrocarbons directly into the air, aggravating respiratory illnesses like asthma and bronchitis.
    • Failure of Pollution Control: Modern pollution control (like Positive Crankcase Ventilation, or PCV systems) is designed to recirculate these fumes back into the engine to burn them, which this action would bypass.
    • Environmental Degradation: The increased pollutants, combined with LA's temperature inversions, would trap harmful substances near the ground, reducing visibility and causing long-term damage to air quality.
    This action would effectively return air quality conditions to a pre-1960s level, when such emissions were not regulated, significantly raising health risks for residents.
  6. ChapmanF
    19,020
    I see Immanuel Kant has entered the chat! :)
    Made me think "let's really put Gemini through its paces...."
    Please consider the question "If every car owner in a city were to cause their cars to vent the crankcase fumes to the atmosphere, what would be the environmental impact?" and discuss how an individual's decision to so vent the crankcase might be scrutinized in other, less Kantian, moral theories.​
    Not too shabby, this AI stuff. :D
  7. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Some old crap had the Big'ol oil fill cap as the 'filtered' inlet of air. It had a wire mesh inside.
    I doubt there was any measurable lower pressure in the CC due to the 'baloney' cut on that tube. It was just an easier path out for the blowby, but far from the slightly lower pressure in the CC with a modern PVC system.
    You used to see it puffing out blowby fumes back in the day when the turd was stopped.
    Anyways, I hope this discussion keeps the polluting Offenders awake at night....:cool:
  8. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    That oiled mesh filler cap, first used by "old crap" Chevrolets in 1955, was not a super-efficient air cleaner, but it was still a big improvement over the open holes in the rocker cover my parents' 1954 had---especially if you lived on a gravel road, which we did.
    mjoo and Bill Norton like this.
  9. Monkey-like
    Monkey-like Junior Member
    New Zealand
    My EGR system in my gen3 was kinda dirty but the valve was the issue. it was stuck open. inside the valve was the dirtiest part. I found out the details of the valve after I fully cleaned the EGR system. Im really considering just leaving this unplugged now tbh. I really don't want to mess with this again. Although I did leave the bottom bracket bolt off the cooler because that was an absolute B***H to get off. So the next time I mess with the EGR system it will be a bit easier. I mean seriously, I spent like an hour and a half trying to get that bottom nut off. It was tight. I had to move around so much stuff to fit my impact driver in there to crack it.
    I have no choice but to leave the valve unplugged anyway for the time being until I decide if i'm going to replace or clean it.
    I just went for a drive in my gen3 with it unplugged and honestly the engine feels smoother than it did before the EGR valve issue. Im going to maybe leave it unplugged actually but just keep an eye on everything.
    Btw why is there no temp gauge?
  10. Mendel Leisk
    42,343
    It’s tough to access, but good lord: you don’t need to use an impact on that. Back out the stud there too, and then (with the one stud at the EGR valve removed), you can leave on the 2 studs at exhaust manifold connection, pull the cooler straight forward and out. Those studs will retain the rear gasket too, and align everything during reinstall.
    what was the miles btw?
  11. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    Seriously? It was easy. With the proper tools. That's the key. Having the proper tool for a specific
    job is what makes it easier. I couldn't figure out what everyone was writing about. Until someone
    put up a photo. A SnapOn 1/4 drive with a long extension with a swivel. Easy!
  12. Mendel Leisk
    42,343
    I managed to snake a long-handled, swivel head, 1/2" Jet ratchet through the morass of cables/bracket, with a 1/2-to-3/8 adapter,, and IIRC a 1.5" extension and 12 mm, long socket. For the stud, a 1/4" Jet ratchet with E8 Pex socket, no extension IIRC. Getting that stud backed out was a tedious, one click at a time chore, about 15 minutes, sweating that I was going to round it.
  13. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    My Gen3 definitely was smoother when I unplugged the EGR valve for testing.
    When adding light throttle while driving, it just responds without a hesitation and light stumble.
    If you have an OBD app and the adapter it's no big deal to clear the code after testing.
  14. ChapmanF
    19,020
    probably needs the manifold passages cleaned
  15. Mendel Leisk
    42,343
    My guess would be if the car detects an EGR malfunction it retards ignition timing as a safety measure, and maybe increases fuel in the fuel/air mix, and hence it runs smoother, but incurs a modest drop in mpg and a rise in pollutants.
  16. Bill Norton
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    I agree, which some say is where the imbalance of mixtures in the most clogged cylinders, usually 1 and 2, is where the head gasket problems occur.
    At least that's one theory. That's where my head gasket failed at ~164k miles.
    Had it replaced with the Felpro head gasket. Runs fine now. Haven't tried it without the EGR functioning.
    Alas, now it's for sale because I moved on to a high miles Gen 4 just so I can use the Comma 4 to handle the steering duties.
    There are so many improvements between these generations. And the MPG are noticeably better!
  17. ChapmanF
    19,020
    My comment was simply about the direct natural consequence of dirty manifold EGR passages, which is that the unbalanced EGR flow makes the engine run roughly when EGR is active.
    So if you have a symptom of rough engine running that smooths out of you unplug EGR, that probably indicates your manifold passages need cleaning.
    The business about that unbalanced flow possibly causing gasket damage eventually, and that then maybe causing symptoms of its own, is a whole different, indirect, downstream eventual effect that some here regard as likely, but it isn't what I was getting at.
    Rough running because of a damaged gasket would not smooth out with EGR unplugged, no matter what did or didn't cause the damage to the gasket.
    CR94 and Bill Norton like this.
  18. Paladain55
    Paladain55 Active Member
    414
    172
    The South
    You would be surprised. Originally I had the evacuation screw at the bottom of the catch can closed but it was filling up with water so fast i was dumping it pretty often. The two pcv ports have definitely become steam ports. Surprisingly even though its an oil catch can i have no oil accumulation in it, just water. Now its just open to drip. You would think the oil quality would be worse with open pcv as i read all the horror stories, but honestly it isn't. Our engines are just much tighter and wear the bottom end like a stone now. Its a non issue. After 5 years of open pcv the engine still runs no different than new. This is more or less why people get the start up knock in the winter pretty often. It condenses into liquid in the intake and the engine knocks as it consumes it.
  19. Monkey-like
    New Zealand
    It's all sorted now, It was a bit of a mission though. I initially cleaned the cooler, valve, and pipe. Then I cleared the code but it came back after about 45 minutes of driving, I repeated this a number of times. I finally bit the bullet and took off the intake manifold also. it was reasonably dirty but not clogged. cleaning that did the trick though. That was a mission though... Had to soak in petrol for ages before the caked on grease and soot would budge.
    I'm thinking about putting a block plate between the exhaust manifold pipe and the EGR cooler to do a proper delete. I'd thought about just leaving the valve unplugged but I imagine a fair bit of soot builds up in the cooler and around the valve? But maybe not, maybe there isn't enough vacuum and the soot only accumulates just inside the exhaust manifold pipe > cooler.
  20. ASRDogman
    8,066
    4,086
    How many times did you clean the cooler valve and pipe? :eek:
    The intake is part of the egr system. Those ports are small, they WILL clog like the rest of the system.
    If you use a .22 caliper gun bore brush in a drill and gunk, it will clear those ports in seconds.
    Blocking that won't resolve the problem. How much oil is the engine burning? Do you have an
    oil catch can?
