EGR Maintenance - Any "tricks"
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Kenny94945, Jul 8, 2020.
  1. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    EGR cleaning seems to be an issue and not so easy for disassembly and cleaning.
    Anyone find a "trick" to reduce the carbon build up?
    Such as, my thoughts: High RPM driving, Use of Techron, more frequent engine oil changes?
  2. Mendel Leisk
    38,730
    Oil Catch Can may slow down the carbon build up.
    More frequent cleanings? Maybe carbon build-up accelerates with accumulations.
    mjoo and Tim Jones like this.
  3. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    If your going to keep your car a long time I recommend getting a spare egr cooler. That way you can swap the clean one out and reduce the down time and trouble. I bought one for $40.
  4. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,724
    Texas Hill Country
    Change the piston rings to reduce blowby... but yours should have been updated from the factory
    mjoo likes this.
  5. mjoo
    mjoo Senior Member
    1,127
    1,317
    Michigan
    Scheduled changing/cleaning of the PCV valve should help prevent blow-by?
