EGR Valve, cooler, pipe...oops
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobzchemist, Jun 6, 2018.
Tags:
  1. Mendel Leisk
    42,380
    This is the EGR valve, and pipe connecting to intake manifold:
    And this is the EGR cooler, connects to pipe weldment on the exhaust manifold:
    It's imperative to normal engine operation for exhaust gasses to flow through this system under certain conditions, and be cooled along the way. Over time the EGR circuit inexorably clogs up with carbon, probably to about 50% clogged by 120K miles?
    The carbon build-up may be exacerbated by the oil/water/unidentified dumped into the intake manifold by the pcv valve. Time will tell; those with Oil Catch Can installed who later revisit the EGR will see what's happening. The OCC at the least cannot hurt.
    Here's a couple of pdf about the EGR, one on the nuts-and-bolts, and the other I don't believe I've posted before, for monitoring EGR performance with Techstream.
    danlatu, Bay Stater, icyrius and 3 others like this.
  2. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Well, Ray, I was the idiot who bought it for that, so I'll take the loss. How much is it actually worth?
    Raytheeagle likes this.
  3. Mendel Leisk
    42,380
    You can always just clean the one you've got. It's always the right part number, and the price is right...
  4. bobzchemist
    507
    342
    Mendel, I'm going to - but I need to get at least some of the money back that I stupidly spent on the wrong parts - I certainly have no use for Prius C parts. Just throwing them away seems like such a waste.
    Raytheeagle and Mendel Leisk like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I paid $100 for the Gen3 cooler and valve. If they were split, I believe the cooler they charged me $35 and the valve was $65.
    But worth is what someone is willing to pay.
    The price you paid was less than new at least.
    Good luck with the sale(y).
  6. Mendel Leisk
    42,380
    Not enough profit, too much shipping cost, not enough customers.
    Meh, shorten the circuit: clean yur own.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I meant, is engine bay cleaning on your pressure wash list also?
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Nope.
    I keep water out of the engine bay;).
    It may look a bit dirty compared to others, but I don’t like living on the wild side:oops:.
    I’ll just keep it’s use to the egr cooler(y).
  9. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Got the egr cooler cleaned @grid :):
    E817430B-6B19-4275-B556-A8DE4C62D3A2.jpeg 048DF54D-AF1F-46CC-A1CD-68B43171F3E3.jpeg
    Nothing 1600 psi couldn’t handle;).
    Ready for the next member who needs it(y).
    danlatu, Bay Stater, RMB and 2 others like this.
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    How long did it take you? Do you look like a chimney cleaner now?
    Pixel XL ?
    Grit and Raytheeagle like this.
  11. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Including setup: 14 minutes:).
    Pressure washer: a good tool to have(y).
    Bay Stater, RMB and Grit like this.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Lookin clean my dude. My new commute begins tomorrow, egr gonna get clogged even more; 2 hours total- 95% hwy.
    RMB and Raytheeagle like this.
  13. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    My dude:LOL::ROFLMAO::p.
    Enjoy the new commute:cool:.
    Been doing a similar one for 4.5 years now, so I know what it’s like;).
    The coolers ready for a window of time when you want it(y).
    edthefox5 and Grit like this.
  14. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thanks. I should be able to put the blue shop towel roll and orange goop that i left from the last meet up in your garage for the egr cleaning :whistle: Use them as you need, I got plenty here.
    I found a place to move closer to work, the 2 hour commute will only be 2 months at the most.
  15. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    There still sitting on the bench for next time;).
    Better than leaving your torque wrench at least:).
    Good to hear you were able to find a place near Chico(y).
  16. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Hope I'm in the correct section.
    Doing intake cleaning, pcv valve replacement, OCC, EGR cooler/system cleaning.
    So far pretty easy removing things. Just the HEAT is slowing progress. No garage, sun beating down with hi humidity, few clouds.
    One question, should hose go from PCV valve to the INTAKE of the OCC? Then out the OCC to the LARGE fitting on the intake?
    This "seems" correct, butttttt, better safe than sorry. Thanks
  17. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Welcome to Prius Chat (y).
    The routing path is from the PCV valve to the inlet of the catch can, through the outlet of the catch can then finally into the intake manifold ;).
    How many miles on your Prius and any other info your willing to share?
    Keep us posted (y).
    danlatu likes this.
  18. ASRDogman
    8,070
    4,092
    138,000 miles. I bought it last July with 116,000 miles on it. I'm the 2nd owner. It was in pretty good shape.
    He did all the services at Toyota. All service recalls have been completed, at least that's what Toyota said.
    I've change the CVTransmission fluid. It was VERY dark red, almost black. Changing was easy, getting it up
    high enough to do it, Royal pain! My old time jacks wouldn't fit anywhere.
    I did the EGR cooler (and related items) cleaning yesterday and put it back together today. Wasn't too bad to do.
    Cooler was almost completely clogged with soot. Oven cleaner and gunk and water hose pressure cleaned it out
    pretty easily.
    I also cleaned the intake manifold. Only a little oil at the bottom. Toyota had to order all the parts and the intake
    manifold gasket won't be here until Thursday. It was ALL supposed to be here today. I had planned on ordering
    the parts this week and do it next week, but this week opened up so I started it.
    Dealing with the heat and humidity here is killing me. No garage or shade.
    I average 47mpg. Depending on how I drive but believe my best has been 52?? Can't remember.
    I have an OCC, but it won't fit next to the inverter like in the video's. The 2 inverter coolant lines are there.
    I haven't figured out where it can put it so I can get at it to empty it. It's only 6 inches tall. Guess my Prius is different
    than the videos I've seen of people installing them at the top! Or they have shorter cans!
    So now it's sitting waiting for the intake manifold gasket to get here.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    I’m with Ray don’t hose down your engine bay till it’s sqeeky clean. Pros use steam to limit the water.
    Car wash hose will force water into many places It shouldn’t like the many many electronic connectors
    And the inverter.
    You drive away with an engine miss or a check engine light comes on and you will regret it.
    It accomplishes nothing except satisfying your ocd.
    Not to mention it will instantly rust all the pot metal screws and bolts. If anything you should lubricate it like crazy. I like Pb Blaster CSP spray great product it’s thickesh spray grease with no smell.
    It’s designed to stop corrosion. It’s called Corrosion Stop Preventer.
    Under the hood spray the hood latch the hood hinges the throttle body return spring and anything you see under there that’s starting to corrode. Look closing you’ll see a lot. Like all hose clamps. I also spray every connector I can get too. Open them up and spray them.
    Spray door hinges and the rubber bellows.
    I spray the front and rear suspension too and spray Black Magic on the cv boots and the steering rack boots.
    Keeps them from cracking. Lose a boot lose a cv joint.
    Result is car that does not make a sound no squeaks no rattles.
    In the last 11 years I have been on this site ive seen hundreds of cars rusted all to hell because the owners think squeaky clean is good. Squeaky clean engergizes rust. Who cares what it looks like under the hood. All you should care about is how well it gets you down the road.
    I haven’t washed my engine bay on any car I have ever owned . They look like hell but there happy and no rust And no intermittent things going on. Need to work on something i hose it off with choke cleaner and underneath is shiny metal.
    It’s not a car it’s a locomotive. It runs on lubrication.
    danlatu, mjoo and Raytheeagle like this.
  20. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Man I hear you. 2 weeks ago I worked outside for a few hours and didn’t realize how dehydrated I got i was pretty sick later that night. It’s brutal down here. The sun is painful. You can’t drink enough water.
    Going to be brutal next month down here in Florida I’m in the Tampa area.
    Long time ago I bought an patio umbrella and filled a Home Depot bucket full of concrete with a pipe the umbrella just slips onto that I wheel around on a handcart. The concrete bucket is heavy so the umbrella won’t blow away. I see my new neighbor bought this
    10x10 pop up canopy. I looked around on amazon and harbor and found the cheapest one new 10x10 pop up canopy with storage bag for $55 free ship on eBay it goes over the car hood so you are out of the sun. I’m getting one this week. It has more coverage than my umbrella. You can’t work outside in the sun anymore if your not used to it.
    Don’t know how roofers do it down here.
    #40 edthefox5, Jun 20, 2018
    danlatu, Raytheeagle and Mendel Leisk like this.
