EGR Valve, cooler, pipe...oops
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobzchemist, Jun 6, 2018.
Tags:
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    This was pretty much my original concept - if I could have the spare EGR cooler and pipe cleaned out and ready to go, I would save a lot of time during the install. I only have one car, so if the Prius isn't running, I don't have wheels.
    But - I didn't pay close enough attention when I ordered from Ebay, and not having part numbers on the listing should have been a huge red flag. Hopefully, if I can sell the parts, my mistake won't wind up costing me more than $100, but it still might.
    Since I haven't sold the Prius C assembly yet, I'm going to have to go with removing the parts on the car, cleaning them, and reinstalling. Due to only having one car (and needing to get to work daily), the parts will come off on a Saturday, and will have to be reinstalled on the next day, regardless of what condition they're in, clean or not. Given the heat and humidity of a Georgia summer, I don't have much more than 4 hours total to get this done.
    Raytheeagle likes this.
  2. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Start Friday evening! Then continue Saturday morning. You can do the cooler cleaning Saturday afternoon. Hopefully you will be
    able to start reassembly Saturday evening. If not, you could start Saturday evening and finish Sunday.
    I've been there, done that! :)
  3. Mendel Leisk
    42,380
    Cooler cleaning is basically filling it with strong oxi solution, then letting it sit for an hour, rinse and repeat. A number 3 rubber stopper is handy.
    bobzchemist, Raytheeagle and mjoo like this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    That’s in Rancho Cordova :).
    I picked mine up in their yard and avoided shipping;).
    They have plenty of choices (y).
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Having just cleaned out spare egr cooler with a pressure washer in 15 minutes, I know what I’ll do the next time:).
    1700 psi whipped the cooler right into “like new” condition (y).
  6. Mendel Leisk
    42,380
    Hopefully doesn't distort/break the internal structure. Sounds like you're good though.
  7. ASRDogman
    8,070
    4,092
    Seeing as I'm in Florida, I couldn't go by and pick it up. :) But they have free shipping.
    I phoned a few junk yards around here but they said they don't have any Prius parts. REALLY?
    I might try the pressure washer on this one. After soaking it in gunk.
    I had thought about putting it my self cleaning oven and running it through that, but not sure if that would
    be a good idea. :)
  8. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    The good thing is you can visually inspect to see and you’re in control;).
    We use hydroblasting as a way to clean equipment where I work with pressures up to 40 k psi. Sometimes that doesn’t even work:(.
    But I’ve seen what high pressure washing can do to equipment and what to be mindful of;).
    No signs of damage or distortion at the 1700 psi level(y).
  9. Mendel Leisk
    42,380
    Ultrasonic cleaning might work too.
    But hey, oxi-clean, and 5~6 hours: works, gets in all the corners, no drama, that's enough for me.
    Bay Stater, mjoo and Raytheeagle like this.
  10. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Hmmm... Ultrasonic cleaning and oxi-clean...
    At the same time... :whistle:
    Maybe I'll beat @Raytheeagle's 15 minute time... :D
  11. ASRDogman
    8,070
    4,092
    I received the EGR Cooler today. It is in pretty good shape. I can actually see through it! :)
    So it's not clogged. It should be easily cleaned. I'll plug one end and fill it with gunk!
    I think it was worth the $55!
    What a pain trying to get a photo!
    Bay Stater likes this.
  12. Mendel Leisk
    42,380
    Go with Oxi-Clean, better for the environment, and very effective. I learned the hard way: dumped a can of braklean through mine first, with lacklustre results. I doubt Gunk would that different. I could be wrong but hey: Oxi works, and it's something you can do in the laundry sink, water-based.
  13. ASRDogman
    8,070
    4,092
    I am NOT cleaning this thing in MY sink! EWWW :)
    I don't use oxiclean. I KNOW gunk works because I used it on my original on last week.
    Frankly, I don't care about the environment. It's been taking care of itself for over 7000 years.
    I'm not dumping billions of gallons of gunk into the ground. :)
    It will be dumped on the driveway and evaporates. That's the good thing about gunk! It mixes
    with water and evaporats.
    Remember when that tanker wrecked and leaked millions of gallons of crude oil off the coast of Alaska?
    Everyone said it will take hundreds of years before it's cleaned up. It was less than 10 years I think. Some organism
    eats oil! Go figure!
    And, I also used oven cleaner. I used it on my RD350 when I decarbonized it. That does a good job also.
    mjoo and Mendel Leisk like this.
  14. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    You could always pressure wash it;).
    That’s just water too for our environmentally conscious folks:).
    Does a great job(y).
    Bay Stater and mjoo like this.
  15. Mendel Leisk
    42,380
    Oven cleaner is similar to oxi I think, just a little more caustic.
  16. ASRDogman
    8,070
    4,092
    I also thought about the pressure wash, along with gunk. I need to pressure wash the house anyways. :)
    Oven cleaner is not similar to oxi.
    There is a so called "safe" gunk, it's a foam. It is totally worthless! It doesn't even clean off normal dirt.
    I just don't know how they can keep selling it.
    Gunk cuts the grease. I would buy kerosene if I could find it because it would be cheaper.
    Bay Stater and Raytheeagle like this.
  17. Mendel Leisk
    42,380
    I've still got a can of the old gunk, purchased in mid eighties? (n)
  18. vgrnt
    vgrnt New Member
    Houston, TX | Vancouver, BC
    Hi all, hate to interject myself into this convo, but why aren't folks deleting the EGR system altogether? Especially on older cars that are out of warranty..
    On diesels we do it all the time (for the same reason, they clog, blow cores, etc.) - can be as simple as unplugging the valve. Obv, you get a cel, but afaik it doesn't affect operation of the engine negatively (aside from emissions I suppose).
  19. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    I’ve tried a myriad of options (brake Kleen, oven cleaner, oxy clean, pressure washers, etc) and the pressure washer was by far the most effective ;).
    Other each had their short comings:(.
    But if you have a spare egr cooler, the world is your oyster(y).
    #79 Raytheeagle, Jul 3, 2018
    Bay Stater, m.wynn and JC91006 like this.
  20. ASRDogman
    8,070
    4,092
    I'm sure there are several ways to clean it. I just like to find the least expensive.
    Brake Cleaner is good, but LOT's of money, many cans. Gunk and oven cleaner are inexpensive.
    By starting with those, and then using the pressure washer it should really shoot the soot out! :)
    The more options the better. If one doesn't work, you can try another one.
