Eibach Lowering Springs, who's got them?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by PriBlack, May 9, 2013.
  1. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Well I have my photos above with gaps front and rear with H&Rs, running 17s. Not sure exact drop but if someone with TRD and Eibach does the same photo angle front and rear yr. be able to see the gap comparison.
  2. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Hard to see in this picture because of the blacked out wheels but you can see the angle of the cars.
    TRD, H&R, TRD
  3. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Yeah, all essentially the same based on the angle of the cars.
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Pretty hard to tell the difference.. :confused: ;)
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Aye, until you break out the tape measure. :)
    Still, it's not a huge difference.
  6. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    H&Rs, I can fit 2 fingers tight in the gap on the rear on top of tyre, on the front I cannot, so its about 5mm lower on front.
    Here are photo before and after front/rear so you can see what like with H&Rs. image.jpg image.jpg image.jpg image.jpg
  7. Sfcyclist
    1,621
    376
    SF, CA
    From the description of the H&R, they set it so the car has more rake. I don't know if any of you track your Prius. I notice the car already tends to understeers. From what recall dropping the front should help. NTL, since most do this for aesthetically vs pure performance, it's not really a factor. I'm sure both kits improve handling over stock springs.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Here is a better angle.
    H&R, TRD, TRD
    Here is an example of a stock height Five with 215/45/17 tires
    My Three with TRDs and 205/50/17s
  9. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    What's it like with 50 profile?
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It looks nicer IMO and the speedo error is less. The 215/45/17 is .3" shorter than the 195/45/17 so it looks funny to me. The 205/50/17 is .1" taller than the 15" tire. So fuel efficiency should be better with the taller tire.
  11. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Interesting will remember for future reference! Will raise the car a bit and less bumpy ride aswell!
    Any photos of yr ride?
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The ride is about the same because most tires in that size are XL rated so they are more robust. Ride height is increased a bit though.
    This is what it looked like with that setup
    BigPete likes this.
  13. Sfcyclist
    1,621
    376
    SF, CA
    Tires look plumpy.. ;)
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That's because you're used to the wheat thins on your car. :p
  15. Sfcyclist
    1,621
    376
    SF, CA
    One is the ratio and the other issue is the sidewall.. Toyos seems more tapered with rim protections.. those just look.. plump... :)
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    *raises his fist in the air*
    Why I aughta!
  17. Sfcyclist
    1,621
    376
    SF, CA
    wait a minute.. you're not even running those anymore so why do you care?? LOL!
  18. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Because! It's like someone saying your old girlfriend was ugly. It still kinda stings even though they are gone. :p
  19. Sfcyclist
    1,621
    376
    SF, CA
    oh the memories...
    F8L likes this.
  20. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    I like the feel of the ride with coilovers now :)
