Elbow vent tube does not fit new battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Priusdriver2013, Jul 30, 2021.
  1. Priusdriver2013
    Priusdriver2013 New Member
    Van nuys
    Hello all,
    I am a very new to the prius community, I recently acquired a 2013 Toyota Prius that is in need of a 12V battery replacement.
    I purchased a Super Start Platinum Battery Group Size S46B24R (please no slander, it’s already purchased) and tried replacing it with my current, much older 12V battery but the vent tube didn’t fit. It’s seems to be that my current elbow vent tube is more circular and only slides halfway inside the new battery (that gets much more smaller in the deeper inside you go).
    What could I possibly be doing wrong, is there some sort of stopper preventing the elbow from fully sliding through completely…? Any advice or things that I should look over would be helpful! thank you
  2. JC91006
    16,480
    8,397
    If you can get it partially in the vent hole, you can just tape it in place. It's no big deal on the venting of this agm battery
  3. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    check to see if your recent acquired vehicle has the bad flywheel.
    49,440
    that's odd, mine popped right in, but that was 2 years ago. is the new one oem for prius?
    i would go back and ask them to install the elbow
  5. PriusCamper
    PriusCamper Senior Member
    11,092
    4,515
    Pacific Northwest, USA
    Hmm... I though Gen3 Prius moved the 12v battery up into the engine compartment and is no longer inside the cabin where venting would be of use? The more I learn about these vent tubes that never ever get used the more I realize that it's not neccessary for the vehicle, but maybe necessary for Toyota lawyers? So weird?
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    THIS.
    Duct tape really IS the answer for this. :)
    Or just leave the vent tube off.
  8. bisco
    49,440
    gen4
