Elearnaid battery replacement question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ryan king, Jan 2, 2013.
  1. Ryan king
    Ryan king Junior Member
    I'm pretty sure my battery is low on charge and I need a replacement. I've heard about the optima battery on elearnaid which is about $100 less than the dealer quoted me. Has anyone here ever done it? Is it hard to do? I have limited tools and I'm a little worried about doing it but if I can I'd like to obviously and save $100.
    Thanks!
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    They send excellent instructions and list the needed tools.
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + with Instructions
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    What is a "straight edge screw driver"? Do they mean a slotted screwdriver?
  4. Rich12
    Rich12 Member
    176
    29
    Might want to buy an Odyssey PC-680 (Amazon) dry-cell instead of the Optima. Some say that the Odyssey is over-priced but I haven't found a lower-priced make and model battery that would work.
  5. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    usnavystgc likes this.
  6. Corwyn
    2,171
    659
    23
    Maine
    Thanks. My father was in the hardware business, and I have never heard them called that.
  7. Ryan king
    So what if I don't have a small battery and lose "presets"? Is that going to matter?
  8. Patrick Wong
    18,210
    6,515
    It doesn't matter if you can go to the effort of programming your radio station presets and resetting the auto up/down on the driver's door power window.
    I also suggest that you plan to fully charge the replacement battery before you install it. It appears that Prius Optima batteries sit on the shelf for a while before they are sold and are likely to be somewhat discharged upon receipt, based upon several recent posts from Prius owners who bought that brand.
    You can buy lots of tools for the $100 savings. Basically you will need access to 10 and 12 mm metric sockets and box/open end wrenches. The 12 mm socket will allow you to remove the brake system power supply located near the 12V battery, for better access to the battery.
  9. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The Odyssey PC-680 will work in the Prius, but as it is only 16 amp/hr capacity it would not hold up for very long and it's life span would be reduced by being continually being in a low state of charge. It is normally recommended that lead acid batteries are not discharge past 50% capacity, and this would only be 8 amp/hr for this battery. The Odyssey also does not have a vent tube again considered by many here as essential. The OEM battery is 40 amp/hr capacity and this is considered as being boarder line when the car is left standing for 3 or 4 weeks.
  10. Ryan king
    Now as far as disconnecting/reconnecting the battery is there anything special I have to be worried about as far as damaging my hybrid battery or causing electrical problems. I'm not that experience with electrical stuff in cars. I have done some stuff on cars before. So I would probably need to charge it as well before installing it? I'm just wondering if all this hassle is really worth $100?
  11. Britprius
    5,194
    1,922
    Disconnect the negative lead first "the best place is where it is bolted to the body of the car"then the positive lead. The negative lead can be fitted to the new battery before it is lowered into place and fastened down. Connect the negative lead back to the bodywork last. Doing it this way round eliminates the risk of shorting the battery to ground possibly burning yourself and melting the spanner (wrench I believe for those in the US).
  12. Corwyn
    2,171
    659
    23
    Maine
    Sorry for the nitpick, but you presumably mean amp*hr (aka amp-hr) not amp/hr.
  13. Britprius
    5,194
    1,922
    No that's the way we designate battery capacity in the UK. In the same way we spell tyres not tires. We speak the same language but we use different words.
  14. Ryan king
    So I found a dealer that will do it for around $200. Can anyone persuade me not to get the battery from them? Is the Optima battery really that much better?
  15. Britprius
    5,194
    1,922
    If your battery is the original it has lasted 7 years. A good life for any lead acid battery and with the same treatment there is no reason why a new OEM battery should not last the same.
    In theory the Optima should be better in some ways "mainly if the battery is miss treated" as the Optima should stand up to rougher treatment, but there have been a number of reports lately of faulty batteries being supplied.
    So the choice is yours, if you were happy with the life of the old OEM battery and you believe the price you have been quoted with fitting is fare that is probably the best rout for you.
    John (Britprius)
  16. Corwyn
    2,171
    659
    23
    Maine
    Then I am confused. What the heck does amp/hour represent? Amps are Coulombs per second, so an amp*hour would be 3600 Coulombs. An Amp/Hour would be 1/3600 Coulomb / sec^2. Acceleration of electrons?
    You can have your own language, you don't get your own math or physics. I do have some AA batteries I bought in Cornwall that are clearly marked 2000 mAh.
  17. Britprius
    5,194
    1,922
    Sorry but I guaranty the batteries were not made in the UK. I know we will not agree on this so we will just have to disagree "no offence meant or taken". The same sort of thing can be applied to a previous post, the screw driver has a strait edge the screw has the slot.
  18. Patrick Wong
    18,210
    6,515
    Frankly, I would say the Toyota-supplied battery is better. At that price it is a no-brainer choice to buy from your dealer.
  19. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Right now the battery being offered at the local Toyota's here is being made by Interstate. They have a reasonable warranty, correct size and fit, and can be had for under $200.00. If one is fortunate to be in the Houston area, you could order it online and pick it up at Champion. Lately battery sellers/dealers are frowning on shipping batteries due to regulations. It is my understanding that stateside Toyota dealers cannot get the 12 volt from Japan any longer.
    I physically looked at a new one, it was plainly marked 12/12 on it. It also had the correct pencil post's on it, as well as the proper orientation for the posts. I plan to buy one of these within the next 30 days and install it myself. I was going to go with the Optima, but after reading the recent post's about the batteries not being fully charged upon purchase, and the fact that the factory is now in Mexico has made me reconsider my choice on the Optima versus OEM.
    2009 TOYOTA PRIUS Parts - Champion ToyotaWorld
    The Toyota part # for the Gen 2 Prius 12Volt Battery with SKS is the following: 00544-21171-325
    Ron
  20. Corwyn
    2,171
    659
    23
    Maine
    Probably in china. But really we can not agree to disagree about whether you can measure the energy content in a battery with a unit amp/hour. Either I am wrong or you are. There really isn't any room for an opinion on the subject. Feel free to convince me that you are right if you like.
    I am happy to have people call the screwdriver whatever they want, they won't be communicating effectively with me, but whatever.
