Electric Heater and Grill Blocking
Discussion in 'Gen 2 Prius Fuel Economy' started by gazz, Apr 10, 2007.
  1. gazz
    gazz Member
    216
    Coventry, UK
    I have noted that it can be a good idear to limit the use of the heater when warming up the ICE. Has anybody got any comments on using an electric 12V heater to help warm the cabin while leaving of the ICE heater.
    Also I have searched a lot on blocking the grill in cold weather, but is there any detailed info on exactly how to do it and at what tempreatures.
    Thanks
  2. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Gazz,
    There are quite a few threads here about different techniques for blocking the radiator. I think that most of the lads that have done it also have some way of monitoring the coolant temp. The lack of a coolant temp gauge is what has prevented me from trying it myself. There are quite a few options for doing so, but I don't know the availability of them in Ol' Blighty.
    Do a search for "Radiator Block" here on PC and just make sure that you search across all forums.
    An engine block heater would help with this as well.
  3. gazz
    gazz Member
    216
    Coventry, UK
    Thanks for that, I'll keep looking and search for Radiator we call it Grill more in the UK.
  4. tripp
    4,717
    79
    Denver, CO
    Aye. Here the grill is the decorative, chrome bit right in front of the radiator. I love the nuances of American/British English. ;)
  5. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(gazz @ Apr 10 2007, 06:14 PM) [snapback]421102[/snapback]</div>
    The car already has 12V electric heater elements. They have been discussed several times on Prius Chat. You have to set the heat to maximum to turn them on.
    - Tom
  6. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(gazz @ Apr 10 2007, 05:14 PM) [snapback]421102[/snapback]</div>
    Look for "My first morning with a blocked grill" as that is my nomination for most definitive thread on this subject. This is where the local availability of materials, your talent, imagination, and artistic sensibilities merge to create a unique look. Start blocking in the Fall when it gets cool. Start unblocking in the Spring when the fan turns on.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    http://video.google.com/videoplay?docid=-4...51993&hl=en
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    <div class='quotetop'>QUOTE(Tom_06 @ Apr 10 2007, 05:12 PM) [snapback]421190[/snapback]</div>
    I don't think that is correct Tom. I think the electric heaters come on when the Air Conditioning system is calling for heat but the ICE is not warm enough to provide it. I know I felt some feeble heat this winter with my AC set to Auto and 70° F (21° C) in under two minutes. An Engine Block Heater would warm the engine and coolant so the cabin could start warming from engine heat faster while achieving better fuel efficiency, but I see no reason an auxiliary 12V heater for the cabin air wouldn't work.
  9. KMO
    KMO Senior Member
    1,543
    429
    Finland
    2023 Prius Prime
    <div class='quotetop'>QUOTE(Tom_06 @ Apr 11 2007, 01:12 AM) [snapback]421190[/snapback]</div>
    It always amazes me how many people believe this, without stopping for a moment to consider whether it makes any sense at all.
    Why on earth would they go to the expense of installing electric heaters and not use them as part of the normal climate control?
