Electric "Heater In a Box" System
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Michael33, Jan 8, 2014.
  1. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I keep seeing this mantra, but it's incomplete. It should read "In the case of using PIP to heat the net efficiency is higher *than it would be otherwise* BECAUSE you are using the waste heat as well as powering the car." The mere act of using some (not even most) of that waste heat does not magically change the equation from a minus to a plus. I also notice that none of the 'ICE heating' proponents seem to want to mention that gasoline usually comes from another part of the world, or at least the other side of the continent, or that it is a highly refined and processed product.
  2. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Agreed. And I for one think it is a worthwhile experiment to build the battery operated heater...at least to find out does it work, what does it cost, how big is it, etc etc...and THEN form an opinion on whether it makes sense for different people, different climate, different priorities.
    I would probably never use such a device, but I see no reason to be against someone trying it before declaring it non-useful.
    Mike
    usbseawolf2000 likes this.
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    You don't think that Toyota and the electric companies are run by other 1%ers?
    Mike
  4. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    LOL... very true! But, remember I make most of my own electricity so I can at least not patronize them as much. ;)
  5. CharlesH
    2,798
    1,166
    Roseville, CA
    OK, were your solar panels made in the U.S. by non-1%-ers? :)
  6. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Just driving a PiP almost any which way is a big step in the right direction. I'm sympathetic toward your argument though - patronizing the Chinese who are making these panels at near zero profit margins may be better than paying oil money to less benign players around the globe.
  7. SLOW_RR
    SLOW_RR Member
    155
    84
    Mine were made in Canada.... Or so they said. By people who w*rk for a living..... :whistle:
  8. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I may test the 'box' in the Prius tomorrow, my back permitting. I consider the Leaf test a modest success. It would have been a total success, I think, if I had been able to leave both heaters running. The PIP has more interior space than the Leaf, though, and that's where most of the interest lies, so I want to test it in a PIP. I don't expect much if any rise in overall interior temp; I'm instead hoping for that 'bubble of warmth' around the driver.
  9. markabele
    5,084
    1,782
    Nebraska
    How much cost are we talking for "no rise in overall interior temp"?
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Well, that's only the transmussion loss. Why ignore the big elephant in the room? Read my post again.
    Did You Know?
    About 2/3 of the energy used to generate, transmit, and distribute electricity is “lost” at power plants and in power lines.
    Electricity in the United States - Energy Explained, Your Guide To Understanding Energy - Energy Information Administration
    Generating electricity creates a lot of waste heat. That will never reach the cabin of the plugin car.
    On top of that, charging loss is additional 15%. With the cost of the battery and charging time, using gas for cabin heat and propulsion of a plugin hybrid makes sense - while blending (EV-BOOST) with plug electricity.
  11. bisco
    52,849
    i would think a little warm air blowing on the driver would just make you feel better!
    retired4999 likes this.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! Heat sounds good.
    Snowing here 4-7 inches 27 degrees but -17 below again tonight!:eek: I best enjoy lots of coffee before I go home to blow snow!:p
  13. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I did get in a quick test (running late, so after dark). I taped the two 200 watt heaters together and anchored them to the driver's seat adjuster bar like I did with my Leaf. It was 23-24F outside, so the interior of the car was somewhere in that vicinity. I tossed a home weather station in the 'arch' storage area to get some sense of the temp in the vicinity of the driver's footwell, but didn't wait for it to reach ambient. I then turned on the inverter and both heaters, and went for a drive. The ICE came on for some reason (probably cold components) but I left the climate control off so it provided no heat, and it shut down several minutes later, to stay off for the rest of the roughly 8 mile drive. The two heaters together made my legs nice and warm in a few minutes, so I shut one heater off for the rest of the drive. I remained comfortable below the waist. My face, however, was cold, even with an open-face balaclava on. I kept the ventilation in floor/defrost mode, with the recirculate flap closed, opening it for a minute every 5 minutes or so, and just the air being pushed in then by the car's motion was enough to keep the windshield clear. I got home with virtually no range left, but feeling the cold only in my hands (bad circulation, plus no steering wheel heater!) and face. The weather station in the arch was reading 42F, so some heat does escape from the footwell and partially warms the interior. However, that configuration is inadequate, IMO, for more than a short drive. However...
    I was only using one heater for the most part, and there is a space, on the left top of the dashboard, where the second heater would fit perfectly, without obstructing the view substantially. That second heater, secured to the top of the dashboard and aimed at the face area, should work perfectly to keep one's head warm, while the one in the footwell keeps the legs and feet warm. I'm not sure I'll be able to find a way to secure the heater to my housemate's car without doing any cosmetic damage at all, so I suggest that anyone who was waiting to see if this was worth a try, and who owns their PIP, take it from here. I'll summarize the components again later.
    giora, usbseawolf2000 and Tracksyde like this.
  14. bisco
    52,849
    thanks mike, it's getting interesting!:)
  15. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    You're welcome. Unless I get an Inspired Idea on how to secure that second heater to the dash, though, I'm probably done.
    So, what are the components again?
    * Marine battery box. I think mine is a "Group 27" size, and it's much larger than my little 31AH (when new, years ago) storage battery. Group 29 would probably be better for a 100+ AH battery.
    * DC to AC inverter. Get one with at least 1/3 more continuous (not surge) capacity than you'll need, and preferably twice as much. For one 200 watt heater, get a 400 watt inverter. It will likely have a surge capacity of 800 watts, but 400 is the important number for this application. For two heaters, 800 watts continuous. The inverter must be protected by a fuse (most are), and must have either a low voltage alarm (best for this application because you can hear the battery get overtaxed while driving, and just reach down and shut a/the heater off) or a low voltage shutoff no lower than 11.5 volts. An inverter with ring-type terminals that the power cables attach to is most convenient. I strongly suggest you use automotive battery cables with standard battery terminals on the battery end, and attach ring terminals or whatever type you need to connect to the inverter on the other end. I used the alligator-clamp cables that came with my inverter for this test, but that isn't a long-term solution. For multiple heaters and a large battery, use heavy duty battery cables.
    * Heater(s). I like the Lasko 200 watt "My Heat" units because they seem to blow hot air even in a cold car. They also use safer ceramic disk technology. Their main flaw for household use can be a plus for this use: there is no tipover switch, just a thermal protection cutoff. So while you have to make sure it/ they are securely mounted, you can mount them in any position.
    MyHeat™ Personal Heater Model 106 | Lasko Products, Inc.
    * You will also need a battery charger. If the battery will be residing semi-permanently in the car (I put mine in the right rear passenger footwell) then you need to decide if you want a smaller charger that you can plug in away from home, or a larger, faster one to stay in the garage. The charger has to have a setting for "gel" or "deep cycle" batteries. Don't use a battery "maintainer" to charge a large depleted battery. Use an actual "smart" charger with two or three stages and a shutoff or float mode.
    * Deep cycle battery. While you can get away with using a marine/starting battery, and these are least expensive, you will get longer life and more available amp-hours per pound with a true deep cycle battery. Capacity? One 200 watt heater will use about 17 amps in one hour. Two will use about 35 amps. Deep cycle batteries should not be discharged below 20% charged, and if they will be sitting that way for a while, 50% is better. So calculate how long the heaters will need to run, and get a battery with at least twice as many amp-hours capacity as the heaters will need. I can't personally vouch for the claim made by Greensaver that their batteries will not get sulfate buildup if left partially discharged, but that's what I'd use, in the hope that it's true. I do know that these batteries will sit for long periods with little loss of charge, indicating low internal resistance, which is good for a high-drain application like this.
    PRICES:
    Marine battery box: about $25. Less on sale.
    800 watt inverter: $40 to $150. A pure sine waver inverter is not needed for this application, so a good inexpensive one will work. Make sure it has a low voltage alarm, or at least a cutoff, to protect the battery.
    Heater(s): The Lasko heaters run from $20 (usually for the white ones) to about $35. Different colors have different model numbers.
    Deep-cycle battery: anywhere from about $60 for a 75-100AH "marine" battery to several hundred dollars for a Greensaver or AGM type deep cycle in the 150AH range. A small (30AH or so) deep cycle battery will cost about $75.
  16. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Pictures?
    Mike
  17. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    100% agree with you except for my particular case. The electric heat would be instantaneous and great for my short high speed commute. By the time I get to the parking lot at work, on a typical 10F degree morning I may or may not have a bar on the fan started :( so the only heat I get is from the seats. Oh yes the ICE is running (my temperature is typically set at 74) but there is no heat, so Michael's Heater in a Box concept does have some merit, particularly when the temperature Wednesday morning was -17F.
    And if you live where I do and regularly get 160 inches of snow, I prefer a cold windshield so the snow brushes off instead of melting, making ice and you end up scraping. There are some positives, at least for me, for using an electric heater.
    CharlesH likes this.
  18. Michael33
    Michael33 Member
    372
    62
    Upstate NY
    2013 Prius Plug-in
    I took a few quick ones of the components sitting on my porch. I was always pressed for time when testing, so there are none of the components in the car. I'll post one of the porch photos, but remember: "Prototypes ain't pretty." Maybe I should include the price of a roll of duct tape in the last post...
  19. markabele
    5,084
    1,782
    Nebraska
    How long is your commute one way? And do you park in a garage at home?
  20. drash
    drash Senior Member
    2,600
    1,339
    Upstate NY
    XLE AWD-e
    Less than 3 miles. I also do a lot of running around that may include trips between 5 - 7 miles after work. These are the ones that are killers because it's usually after my car has been sitting in the parking lot in, lately, single digit temperatures. I try and mitigate this a little by parking facing south (a no-brainer that I'm usually surprised not a lot of people take advantage of) in the winter.
    Garage with wood stove. So it's heated when I choose it be.
    iPad ? HD
