Electric motor noise when braking
Discussion in 'Gen 3 Prius Technical Discussion' started by white2011, Oct 4, 2011.
  1. white2011
    white2011 Junior Member
    First time positing... Only 1,000 miles on our one month old 2011...
    I hear a distinctive electric motor noise -- similar to the electric antenna noise in our 4Runner -- almost always immediately after applying the brakes (no matter whether hard or soft). The noise lasts maybe one or two seconds.
    I've also heard it right after unlocking the car first thing in the morning, before I've even sat down in the seat much less started the car. It sounds like it could be an electric pump creating brake line pressure. Is there such a thing? Does hearing it so often indicate some kind of leak?
    EDIT: In a subsequent post about 5 or 6 down I've attached an audio file you can download to hear the sound I'm talking about.
    sri81 likes this.
  2. pfjmarina
    pfjmarina Junior Member
    46
    Marina, CA
    Not sure about the noise you hear when braking, but the pump noise you hear when you open the driver side door before getting in is indeed for pumping pressure into the brake lines. It's completely normal.
    I doubt you're leaking any fluid, but maybe put a big piece of cardboard underneath the engine compartment for a few days to check.
    Enjoy your new Prius! We've had ours about six months and absolutely love it:D
  3. white2011
    I found this thread using google. I tried to include a link to it, but I got the following error:
    So copy/paste this into your browser URL box:
    priuschat.com/forums/gen-ii-prius-care-maintenance-troubleshooting/51547-noise-when-braking-even-when-engine-off.html
    Anyway, apparently it's the "brake pressure accumulator pump."
    I'll try to learn to ignore it, but it's hard because it sounds "unhealthy".
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Have you heard of regenerative braking? That is when the electric motor reverses current flow to slow the car down and charge the hybrid battery. That is why you hear the electric motor noise. Perfectly normal and what you paid for with a hybrid vehicle. When on the HSI screen it is when the bar goes to the left in the Charge area.
    You are correct on this one. It is the brake accumulator pump starting to build up pressure before you are ready to drive away. Smart car huh? Once again it is normal and what you paid for with the Prius. No extra charge for either :)
    You really need to read your Owner's Manual and learn more about your new car. Also there are a lot of good articles on this website that will help.
  5. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    What "jdcollins5" said.
  6. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
  7. white2011
    Okay, I've added a zipped Quicktime audio file (.m4a) to this post captured while stopped in Park and repeatedly pressing the brake pedal every few seconds.
    To listen to it you need to download it, unzip it, and open it with Quicktime (standard on Mac, downloadable for free on Windows).
    You can hear the distinctive noise several times, :03-:05, :10-:11, :15-:16, :17-:19 and :23-:25.
    Does every one else's Prius make this sound when you press the brake repeatedly when stopped in Park?
  8. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I have never felt the need to "press the brake repeatedly when stopped in Park". I will try it on my 2010 today.
    Confirmed - on the second push I get that noise.
  9. white2011
    Thanks! Now that I've brought your attention to it, I apologize in advance if you now find it difficult to ignore and are annoyed by it. Sorry!!!
  10. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    normal operation.
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Sounds normal to me. My 2nd gen makes a similar noise. I've confirmed noises that sound like this on 3rd gens I've test driven.
    You should be able to repro this by pumping the brakes even w/the car's power off.
  12. chucko
    chucko Junior Member
    Oregon
    I received a DVD as part of the owners manual pkg with my new 2011. If you received one, give it a view as it explains all of the different sounds that your Prius will make during normal operation.
  13. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The sound is brake pressure pump noise. If you hit the brake pedal, you lower the pressure in the system and the car needs to increase it. Pretty standard noise - don't worry.
  14. Eoin
    Eoin Active Member
    593
    116
    Long Island
    My 2010 makes these pumping sounds every time I push the brake but my 2005 is completely silent. The 2005 brakes are also stronger.
  15. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Lets try to visit a dealer - it is not a standard behaviour. May be the system needs some tuning.
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    That is the brake pressure accumulator pump, which is used to provide pressure for the power brakes. The Prius can't use engine vacuum like ordinary cars, since the engine does not run continuously. An intermittent ratcheting sound while braking is normal. The Prius runs this pump when you open the driver's door on a Gen III, in anticipation of needing the brakes.
    Tom
  17. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    The poster wrote about the pumping sound at every brake pedal hit. It is not standard, I suppose.
  18. qbee42
    18,058
    3,073
    Northern Michigan
    The pump should run about every third time you brake. Obviously that isn't a hard number, since brake application varies by need, but the accumulator pump does not run every time you press the brakes.
    Tom
