Electric Stovetop Cooking: Conservation ideas
Discussion in 'Environmental Discussion' started by SageBrush, Apr 2, 2013.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    My home uses about 150 kwh a month of electricity this time of year, and I would like to see it drop below 100 kwh. I think I have collected most/all of the low hanging fruit:
    Fridge replaced, currently consuming 0.7 kwh/day
    No phantom loads
    Hot water heating switched to natural gas
    Energy efficient lighting, rarely on when not being used (3 watt garage light the exception.)
    Energy efficient computers (Apple notebooks and iPads)
    I suspect the lion's share of my current use is cooking. I estimate we have a stove-top element on for two hours a day, and the average element is 1500 watts. That works out to 3 kwh a day. If I can cut this energy use in half I'll hit my household goal.
    I'm stuck with electricity, so smarter cooking rather than fuel replacement is required.
    Currently I do the following:
    Water for tea and coffee heated in the microwave (MW)
    Pressure cooking when possible
    Learning to cook an egg in the MW to my wife's satisfaction (~ 5 kwh/month savings)
    Encouraging wife to defrost in tap water or MW rather than using the stovetop
    I'm waiting for triple-clad skillets to arrive in the mail, and then I will discard our cheap aluminium/teflon pans. I suspect them of being energy hogs because they do not sit flush with the stovetop.
    Other ideas ? Guesses how much energy I'll save with the new cookware ?
  2. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Good heavy materials like cast iron will get hot and stay hot better than most other things. But keep in mind with cooking there are times you want the bottom to be super hot but the sides to be simmering. Or times where you need something to cook for a long time at a lower power which uses more energy (because it is not a 100% efficient conversion) than shorter at a higher time.
    But I am flabbergasted that you only use 150KWh per month... I use that in 3 days... Between March 1st and April 1st I used 1801KWh of electricity.
  3. SageBrush
    11,627
    2,533
    Southwest Colorado
    2K1, those windoze 'puters are your downfall ;) :p
    Cast iron appeals to cooks for it's heat properties -- meaning high heat capacity, but I am not convinced it saves energy cooking. Am I wrong ?
    I have been mulling over induction cooking. For now my opinion is that little benefit is gained if good cookware is used on a resistive electric stovetop that sits flush with the glass, and the cookware is sized correctly for the element. Single element induction plates are pretty cheap (~ $80), so I can buy one and experiment if advised.
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It keeps its heat better, so you can keep it at a higher temperature with a lower power input. So instead of using high on a cheap aluminum skillet to maintain boiling water, you can maybe turn the cast iron to 85% power and keep it boiling.
    Then on the opposite scale, you can buy triple wall aluminum insulated baking pans. They do not keep their heat at all which is exactly why you want them for baking pastries. You get nice even baking instead of crispy burnt bottoms and soggy tops. Cooking is not where you sacrifice energy efficiency! You need the right tool for the job unless you don't care what you eat.
    My windows PCs draw almost nothing. Maybe 50W to 80W total on average. Under high load they can draw 800W continuous though. My real pigs are my server backbone equipment. My router and firewalls are both 2 dual CPU 6-core each (12 core total) 3.4GHz beasts with 128GB of RAM in my router and 512GB of RAM in my firewall that run at 20% to 80% utilization constantly keeping up with my network. My PS3 draws more power than my windows PC's at close to 170W. :)
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    I don't want to sacrifice my enjoyment of food to save energy. I figure I can have both :)
    Most of our stovetop cooking that is not pressure cooker is stir fry. We do have a bad habit of not covering the skillet with a lid during cooking. One more thing to nag my wife about.
    About cast iron -- If I understand correctly you are investing more energy to heat that pan up to cooking temperature than a triple clad. For our heat and sear cooking habits I thought triple-clad cookware was a better fit.
  6. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Covering a skillet while stir frying changes the taste. You not only trap in heat, you trap in moisture. Lots of times the exact thing you are trying to do is condense the flavour by evapourating excess water given off by the veggies and sauces.
    You invest the same energy to heat up the pan, and then less to keep it hot. For things like soups, stews, sauces or long cook items the savings might eventually add up. For things where you are searing or skillet frying, the principle is the same but generally you are only sauteing for like 5 minutes or 10 minutes. So it might not save anything unless you then use that iron skillet to reduce another sauce or something where you can keep the heat and do something with it instead of just keeping it there for nothing.
    But one of the main benefits of cast iron or some sort of heavy material is that because it keeps its heat, it also evenly keeps it heat. Every part of it (even the handles!) heats up nicely and evenly. You can see this difference best in what I call the pancake test. Get a cheap $3 walmart skillet and make a pancake without moving it. Just put it on the center of the burner, pour in the batter, wait, flip, wait, and remove. You will see the batter dark in lots of weird areas. The pan is hot is these little spots. Your stovetop may not be even, the pan might not be even, the pan's metal may have deformities in it, etc. Now do it with a cast iron skillet. You should get the same shade across the entire surface. Even heat distribution, even from a crappy heat source like an electric range.
    So with your skillet meals, if you find that things in the centre burn while things on the outside remain luke warm, using a cast iron will help that but might not save you any money.
    SageBrush likes this.
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Low Hanging Fruit????!!!! At 150kWh a month, you have dang near picked all the fruit. I think your only real choice is to give up food.
    I have worked my loads over pretty good but my best is about 600 kWh month (e.g. when the air conditioning if totally off). Unfortunately, pool pumps, water heater, dryer, and big house loads can only be reduced so much before more problems are created than solved. You have to be mighty close to that point, especially if the kitchen is the only major load center left. (Humor intended -- Be sure the kitchen partner is onboard with new cooking directions prior to handing them a cast iron skillet.)
    xs650 likes this.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    LOL
    I have been know to annoy her with my energy OCD, or so rumors says. I thought about heating up a stone outside to use as a skillet, heating element, or oven pre-warmer but if my calcs are correct relatively little heat can be utilized. I came up with less than 200 wh as a practical matter, using soapstone.
    Calc sound correct ?
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
  11. John H
    John H Senior Member
    2,208
    558
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    I know this might sound odd, but I am actually disappointed with 150 kwh/month. My estimate before I made most of the changes in our home was that I could drop to 50 kwh/month.
    US gov websites say that cooking is about 2-3% of the average electric use in a household, so I originally figured we were using less than 30 kwh a month. Unless I have a consumption device I am missing, our cooking is much more intensive. I wish I could put the stove on a kill-a-watt. In a couple of months cooking drops dramatically in our home because of summer heat. That will be a data point if I do not think of anything better.
  13. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I tried some engine cooking a long time ago. My V8 Dodge pickup did a good job on manifold recipes. My 4 cylinder Datsun 510 wasn't good for much more than warming precooked food and was marginal at that. I expect that a Prius with it's more efficient engine (less waste heat) would be even worse than the Datsun
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    It might be 2% to 3% of an average household, but I would think your use is so below average, that it is a much larger percentage.
    The average is supposedly around 1000KWh per month. So 3% of that would be 30KWh. Since you use 150KWh a month, it is more like 20% of your average usage.
  15. fuzzy1
    10,713
    I'm looking for recommendations for home energy monitors to track the 240V loads -- hot water heater, resistance heaters, heat pump, dryer, stove.
    The hot water was moved, re-wired, and re-plumbed to the garage just last week, in preparation for a future heat pump water heater. Before the electrical inspection, I'm thinking about adding a regular electric meter to the circuit, next to its new disconnect switch. Refurbished old fashioned mechanical units (just like the one still on my house, though the utility will start upgrading next year) appear to available for $15-20, not counting the mounting box and shipping.
    But this isn't practical for the other loads without ready-made tap points along the wires. Devices such as TED (The Energy Detective) use a current transformer around a wire (e.g. at the breaker in the service panel), transmitting data back every second (or minute or hour or ...) for real time monitoring. The basic unit starts with one channel (i.e. whole house), but appears capable of 4 channels. Reviews appear mixed. Other similar products exist, but I haven't dug through the choices yet.
    Has anyone here used any of these systems?
  16. fuzzy1
    10,713
    Have you considered a Heat Pump Water Heater? I'm in the market for one, but am sorting through the different cold weather performance issues of the available products. Many quit pumping heat (reverting to regular electric mode) at about 45F ambient (my typical garage temperature for four months), a few work below freezing, but one common unit becomes less efficient than regular electric at about 65F ambient. And they make noise, some quite tolerable, some much less so.
    But they should work much better in your climate, doing double duty by reducing both the hot water load and the AC load, if you can manage the noise level inside the house.
  17. fuzzy1
    10,713
    That should be for an element on High. Do you really use a High setting that much? Most of my household's cooking is at lower power for shorter times. The pressure cooker and stir fry start at full power, but can you turn them down a ways once the steam starts flowing and the frypan is hot?
  18. SageBrush
    11,627
    2,533
    Southwest Colorado
    My googling suggested that the small element is 1200 watts and the large one 1800 watts, so I took the average. So far as I can tell the elements cycle on and off to mimic different power ratings. I was just estimating the time the element is on. Sorry I was not clearer.
    I'm hopeful that better cookware will result in more stir-fry cooking exactly as you describe.
  19. SageBrush
    11,627
    2,533
    Southwest Colorado
    They also reduce ambient humidity, which would be worth the price of admission to me in a place like Florida.
