Electrical component not recognised by Toyota Service
Discussion in 'Gen 2 Prius Technical Discussion' started by mathewjg, Jan 5, 2018.
  1. mathewjg
    mathewjg Member
    84
    49
    Just had my Prius serviced by Toyota. On the service sheet I noticed a cross next to the hybrid battery check. They told me they couldn't test the hybrid system because there is something connected to the electrical system that they don't recognise - even though its been serviced at least 6 times by them previously and I have definitely not connected anything! It looks like a voltage regulator with quite a big heat sink and its close to a small button that looks like its for disabling the alarm. Its located under the steering wheel towards the side window, close to the alarm button and the bonnet release lever car1.jpg car1.jpg car2.jpg car3.jpg
    52,838
    did you buy the car new? maybe a previous owner added it.
    where in the world are you? they don't test the battery over here.
  3. mathewjg
    mathewjg Member
    84
    49
    I am In the UK. I bought the car when it was 2 years old with 19k miles on it. It was new in December 2008. It's a t-spirit so has Bluetooth, satnav, rear camera etc
    Nexus 6 ?
    52,838
    so either they haven't been testing it, or some moron just noticed.
    Raytheeagle likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Can’t it be both:p?
    SFO, fuzzy1 and bisco like this.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Looks like something lockpick would sell.
    Go to coastaltech.com they sell mods for a Prius. One is an ev button the other is a mod to power up the cig lighter plug up front all the time the other is an auto door lock.
    Is the power outlet plug hot even with car off?
    Do the doors all lock above 15 miles an hour? I like that one. Should have installed that one lol.
    If not I have no idea. It’s in that area so they could tap power off the fuse box right there at the kick panel.
    Pull the power wire off that’s piggy backing a fuse after taking a pic of where it went and then see what doesn’t work.
    Good luck.
    uart likes this.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Ed , Coastal Technologies - Web Designers, Ecommerce, Marketing Consulting, Online Marketer | Upper Montclair NJ, is now a webpage design service....
    However, I did a search, try here, MYGIG
    I would have to agree, try to trace where the added wires go, have a copy of the electrical schematic to ID landing points and wire color codes, or yeah, pull the +12, see what stops working!
    #7 KK6PD, Jan 6, 2018
  8. edthefox5
    10,096
    4,837
    Clearwater, Florida
  9. fuzzy1
    10,705
    It is certainly some after market addition, not a factory item. The construction style doesn't match up with anything a car maker would put in there this century.
    I'm seeing an exposed old-fashioned TO-220 IC with a common good-sized heatsink, typically of a linear voltage regulator. (First guess: it reduces the 12V power input down to 5V for the other components.) Another IC, probably a standard old-fashioned DIP package, is on the circuit board hidden and somewhat protected under the gray heatshrink plastic.
    edthefox5, SFO and Raytheeagle like this.
  10. padroo
    padroo Senior Member
    2,763
    2,253
  11. fuzzy1
    10,705
    Much too small for that. A couple watts at most.
  12. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    NSA, Maybe CIA? The government is watching you man :cautious:
  13. fuzzy1
    10,705
    Their stuff is vastly more compact, protected, and hidden than this 1970-80's era stuff.
    SFO likes this.
  14. mathewjg
    mathewjg Member
    84
    49
    Maybe a tracker of some sort? Not sure who had the car before me but I think it was not a private individual.
    Nexus 6 ?
  15. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I agree like a LM reg only reason a reg would be in there is if they need 5 volts somewhere.
    I have never seen any lockpick mod with an outboard 5 volt reg all there chips are 12 volts.
    I would pull its B+ connection at the kick panel fuse block and see what you lose. Easy to find that lead it’s probably piggy backed on top of a fuse in that block. Looks like a butch job it was just pushed up under the valence panel. Should only 3 wires to it b+ and a ground and a power lead to wherever it’s going. What’s really weird is the dealer detected it with techstream.
    Interesting stuff though.
    #15 edthefox5, Jan 7, 2018
  16. dolj
    dolj Senior Member
    8,640
    4,391
    Wellington, New Zealand
    Were does it say that?
    What is weird though, is that they claim they can't do the HHC because of it. I wonder what stops them doing it?
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
    How did the dealer find it then? Did it fall out from being stuffed up in the dash the op never mentioned it just says they refused to test the system because of it.
    The more I look at it may be a small audio amp output IC like in a car stereo.
    Maybe the OP can get th3 part number off that IC that will tell us what it is.
    His pictures don’t show how many wires come out of it.
  18. mathewjg
    mathewjg Member
    84
    49
    Yes I thought that very odd. He said it was because they didn't know what it was connected to. Seems unlikely that a little circuit like that would be connected to the hybrid system. And why in that location
    Nexus 6 ?
  19. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Get the part number off it I can tell you in 10 seconds what it is. It’s the white letters on the black transistor.
    And your right it sure isn’t connected to the hybrid system.
  20. mathewjg
    mathewjg Member
    84
    49
    The ODB socket is not screwed into place to perhaps they noticed the other circuit whilst plugging into that
    Nexus 6 ?
