Electrical cost higher than gas to run Prime (I think)!
Discussion in 'Prime Main Forum (2017-2022)' started by IABoy987, May 21, 2020.
  1. bisco
    51,946
    and even at that, the kwh must have been pretty cheap, relatively speaking, no one had any money
  2. Mendel Leisk
    41,463
    I recall it was a podcast, somewhere in North America, maybe even Van. An elderly Asian patriarch, set in frugal ways. Beside the light bulb, he would also wear a plastic produce bag as a rain hat.
    Story relayed by young lodger?
    Google is not helping.
    fuzzy1 likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Lots of our friends & neighbors in Honduras only had one light fixture ... a bulb socket dangling from the roof (no ceiling) by its wire. And now with the insane restrictions from the virus, there's this. It's something one of my coworkers got involved in since the pandemic. It's a little off topic, but it helps to remind me that we have it pretty good here. Some people don't have light fixtures. Others don't have a place to hang them.
  4. IABoy987
    IABoy987 Member
    203
    Iowa
    2018 Prius Prime
    And so I screwed up my calculations big time BIG TIME. Now stand corrected that EV is always best bet unless gas drops ridiculously low....
    Anyone who is interested, please look here for what I think and several agree, is right way to do this.
    Under fuel efficiency forum Titled "EV calculations revisited or V2.0"
    EV calculations revisited (or v2.0) | PriusChat
  5. Idefix
    Idefix New Member
    Germany
    2019 Prius PHV
    For sure in Germany and Europe driving electric is much cheaper as Gazoline is more than 4$ per gallon.
  6. fuzzy1
    10,453
    At your available electric prices, yes.
    But most customers in other markets must pay higher electric prices, some much higher, so they should still do their own calculations. Some places actually do find gasoline to be cheaper at this time.
  7. eatriceyo
    eatriceyo Member
    45
    33
    Honolulu
    on hawaii it's actually cheaper to pump gas than charging at home
  8. jerrymildred
    11,517
    14,152
    Tampa, FL
    Similar issue in the New England states.
  9. CharlesH
    2,797
    1,163
    Roseville, CA
    Yep. If the price of gasoline per gallon is less than 12 times the cost of electricity per kwh, then gasoline is cheaper (6kwh per full charge, which takes you about as far as a half gallon of gasoline). At least, that is a reasonable first approximation. So I guess that if electricity is $0.25/kwh, and gasoline is less than $3.00/gal, then gasoline wins.
    fuzzy1 likes this.
  10. mistermojorizin
    mistermojorizin Active Member
    310
    137
    usa
    2019 Prius Prime
    On an interesting note, I saw $1.99 at an Arco about a month ago in California. It's $2.25 now there.
  11. fuzzy1
    10,453
    Gasbuddy shows a single sub-$2 price in the state right now, but numerous others not much higher. Statewide average $2.85/gal and creeping up very slowly.
  12. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Using factory sticker mileage/range, the gas/electricity ratio is about 14/1. Meaning it takes about 14 kWh to drive as far as one gallon of gas. Electricity is cheaper as long as 14 kWh is less than a gallon of gas. Makes it easier for me. "Hmmm. $3 per gallon means any electricity under 21 cents/kWh is cheaper than gas."
  13. 3PriusMike
    3,100
    2,419
    Silicon Valley
    LOL is right!
    That was when they first started all the "how many XXX does it take to screw in a lightbulb?" jokes.
    How many Prius drivers does it take to screw in a light bulb?
    None.
    There is plenty of light without any light bulbs
    Mike
    Raytheeagle and Mendel Leisk like this.
  14. Toyo_Tom
    Toyo_Tom Junior Member
    Ohio
    2020 Prius Prime
    OK, so how did they see to screw the bub in?
  15. jerrymildred
    11,517
    14,152
    Tampa, FL
    Yeah. I mean, why would anyone use a light bulb unless it was absolutely pitch back dark and they couldn't even see to turn it on? :ROFLMAO:
  16. fuzzy1
    10,453
    People accustomed to full time bright artificial light commonly forget how well the human eye can adapt to very dim light, including natural night skylight. While reading any print remains impossible, given twenty minutes of adjustment time in the total absence of artificial light, it is possible to move around in a room with good windows and find the socket for the bulb. Add some neighboring candles, campfires, or the additional skyglow of nearby urban light pollution, and the wait time becomes much less.
    Remember that down at ground level where there is enough oxygen to support life, the night sky is never really pitch black except when covered by very thick clouds or a dense forest canopy. When the lights go out, it just looks that way because the eyes are still adjusted to bright lights, and it takes a long time to adjust to the dim natural skyglow.
    jerrymildred and Mendel Leisk like this.
  17. jerrymildred
    11,517
    14,152
    Tampa, FL
    Other than the typical gag they do on cave tours, the only times I've experienced complete blackness was during night time power outages on the island where we lived. They were so frequent that we finally got some battery powered emergency lights. On cloudy nights, it was almost absolute darkness. Couldn't tell if my eyes were open or closed even after a half hour.
    fuzzy1 likes this.
  18. Mendel Leisk
    41,463
    That's what you want when testing a darkroom, especially for film processing.
    fuzzy1 and jerrymildred like this.
  19. jerrymildred
    11,517
    14,152
    Tampa, FL
    Film! I remember that stuff. ;)
    fuzzy1 and Mendel Leisk like this.
  20. 3PriusMike
    3,100
    2,419
    Silicon Valley
    Yes...I remember when I was a kid helping my Dad build a dark room in our garage.
    Mike
