Electrical energy past and future
Discussion in 'Environmental Discussion' started by tochatihu, May 10, 2017.
  1. tochatihu
    tochatihu Senior Member
    9,957
    3,845
    Kunming Yunnan China
    2001 Prius
    I wish to start a new thread but "unspecified error". So I'll just write here.
    I do have this (sick) interest in counting things. There are certainly people here with deep understanding of economics of fossil-fuel and renewable-energy industries. So, can we consider:
    Revenues, profits, and investments in these, national or global, at whatever level of detail interests the group?
    From wandering around internet I get the impression that oil profits are now much higher than coal profits. But what is the situation really? We have heard (and I have written) that energy is the world's largest financial 'wheel'.
    We ought to be able to get a handle on the counting side, at least for publicly traded companies. Without even a thought to externalities or subsidies or any such controversial topics. Just count money.
  2. bwilson4web
    16,515
    I am not an expert.
    My thinking is fracking has broken the monopoly of traditional oil extraction. Even 'deploited' oil fields have a new lease on life. More importantly, the production suggests methane and fossil fuel gasses have been captured more efficiently and profitable than traditional oil.
    There is a role in paleo going back to when photosynthetic began depositing planetary carbon into fossil fuel feedstocks. But recognize the sun has been getting warmer than when photosynthesis began.
  3. tochatihu
    9,957
    3,845
    2001 Prius
    Sure. Oil recovery has much improved. Exploration for new fields has improved. Extraction techniques are better, and even Arctic sites (tough) are getting new looks. I expect big oil to be big (and get bigger) for decades at least.
    Economics of oil are what they are, supply/demand, but in this instance my interest is pure industry financials.
    Coal seems much more stable in terms of technology. One either puts humans in shafts (which present some personal risk) or open up surfaces (which distribute risks more broadly). Seems very likely to continue 'feeding (most of) the burners' already built. More will get built, but probably less than high-end projections. My palatir suggests steady or somewhat reduced coal in the mix for coming decades. Not a fast reduction, except where renewables can 'fill in'.
    But again, driven by financials, so what are they?
    Renewables' share is small but growing rapidly. Here the story is not just about technological improvements. Intermittent supply means storage has to grow alongside. Power distribution networks were not designed for this :rolleyes:. 'Oversupply' happens (recently in both California and Europe), this is the opposite of intermittent supply, and takes a nick out of those financials.
    Quite apart from strict financials, many (but not all) want to slow CO2 increase. I'd be pleased to set that aside here. What we really need is more energy. Perhaps not in '1000 watt' countries; those are doing very well. Surely in '400 watt' countries, because they can probably make it happen and get economic growth therefrom. Perhaps there will be only slow growth in 'low watt' countries, because they have many other challenges. Seems to depend on external investment, and if Green Climate Fund does not deliver, what alternative will?
    Several future paths are possible. I feel quite impaired in contemplating them, for lack of understanding of energy-industries' financials.
  4. tochatihu
    9,957
    3,845
    2001 Prius
  5. tochatihu
    9,957
    3,845
    2001 Prius
  6. tochatihu
    9,957
    3,845
    2001 Prius
    Very expensive photovoltaics with 44.5% efficiency:
    https://www.sciencedaily.com/releases/2017/07/170711220514.htm
    One use I know of for very expensive cells is 'solar challenge' car races. College engineering students build vehicles. PV companies donate their top-of-the-line stuff. They get a halo effect for marketing mainstream panels.
    fuzzy1 likes this.
  7. fuzzy1
    10,688
    ^^ I wish it said how many junctions their version has. As of April, NREL posted 3-junction concentrator samples at 44.4%, 4+ junctions at 46.0%. Back when I was still working, I was seeing a roadmap (bandgap assignments) up to 6 junctions.
    Because this efficiency level still requires concentrators (focused sunlight, to far more than the unconcentrated 1 (land) or 1.36 (space) kw/m^2), it requires solar tracking. I'm not sure how well that would work with mobile land projects. It should be just fine for space based systems.
    Boeing-Spectolab has been making multijunction PV for space applications for a long time. But their products were vastly too expensive to the consumer market, ambient energy harvest applications I was exploring.
    https://www.nrel.gov/pv/assets/images/efficiency-chart.png
    #87 fuzzy1, Jul 13, 2017
    bwilson4web and tochatihu like this.
  8. bwilson4web
    16,515
    It has been a while since I read much about photocells so a couple of newbie questions:
    • Parabolic trough reflectors? - I've wondered if a parabolic shaped, polished aluminum with air-tight coating might provide an efficient (enough) collector. Say 1-2 ft wide and 10-20 ft long, aligned to the solar track with a polished, vertical surface at each end. This would reduce the mechanical challenge of a full solar tracker as small, incremental changes, would keep the trough aligned through the year.
    • Dialectic layers? - Laser reflector mirrors are made with layers tuned to the specific wave length of the laser to improve their reflection efficiency at the specific wavelength. Does the same technology work with solar cells, layers sized to optimize light capture?
    • Heat recovery? - I suspect the cells require cooling. What sort of temperatures are we talking about, 100C or higher?
    Thanks,
  9. fuzzy1
    10,688
    For terrestrial applications, it seems that the greatly reduced cost of modules over the past few decades has mostly killed off the tracking and concentrating systems. For the additional energy harvested, it is simply cheaper to add more fixed, maintenance-free panels than to build and maintain moving structures and concentrating support hardware.
    For space applications, kilograms per watt is usually the controlling metric.
    The single-frequency laser optics usually have multi-layer interference coatings, using constructive and destructive interference to guide the transmissions and reflections in the desired direction. This is a narrow-band approach, which falls apart at broad bands such as binoculars and PV.
    Broad-band systems reduce total reflection at the boundary crossings by breaking up one big transition (index of refraction in optics, impedance in electrical lines, it all goes back to the same Maxwell equations) into multiple smaller transitions. This is what optical coatings on lenses do, applying a layer with an intermediate index of refraction. More intermediate steps are even better. For consumer PV, any topside coatings must be weather tolerant, and their small improvement increment must again compete against the already declining cost of simply adding more uncoated modules.
    I seem to remember hearing something about putting a reflector on the backside of thinned PV cells, so that any transmission is reflected back for a second pass. But the etching process to thin the substrate wasn't cheap compared to the benefit.
    Silicon PV is most efficient when cold, so records always involve cooled cells. I'm not remembering any other technologies that don't behave similarly. Those top-line records involved concentrations to 200X to 900X, so they must be cooled to prevent prompt destruction.
    This stuff was not my specialty, so you can find vastly better and more up to date information elsewhere. I was looking into possibilities for certain affordable micro-scale consumer applications, but all the available resources were redirected to some other multi-$Billion market. As a contractor, not an FTE, the upper level management deliberations were completely opaque to me. But now that my NDAs have expired, I can be slightly more open.
    At least I learned enough in the process to decide to solarize my home. And even do it myself.
    #89 fuzzy1, Jul 14, 2017
    tochatihu and bwilson4web like this.
  10. tochatihu
    9,957
    3,845
    2001 Prius
  11. bwilson4web
    16,515
    Interesting as the Autoline After Hours program (Autoline After Hours) someone asked about comparing cylinder cells, the Tesla 2710, versus prismatic cells of the Bolt. Sandy Munro, the guest, pointed out the Tesla style cells have been very cheap to make. For fixed installations, cheap and low energy density is not a big hindrance. In contrast, efficient traction batteries need high energy density and that favors prismatic cells.
  12. Trollbait
    12,810
    I think Tesla went with cylinderical cells for the same reason the first Japanese Prius and other early hybrids did; cost and availibility. Since they are branching out into stationary energy storage, sticking with cylinders gives them a cost advantage.
  13. tochatihu
    9,957
    3,845
    2001 Prius
  14. bwilson4web
    16,515
    Per kWh hour, yes. The higher thermodynamic efficiency means more heat is converted to electrons so less is lost to the cooling system(s).
  15. tochatihu
    9,957
    3,845
    2001 Prius
    heat converted to electrons -> forcing electrons through unfavorable gradients
    So, what, halve the water requirement?
  16. bwilson4web
    16,515
    Let me suggest this excellent article: http://www.steamforum.com/pictures/ge%20turbine%20config.pdf
    1- (100C / 538C) ~= 1 - ((100+273) / (538 + 273)) = 1 - (373 / 811) ~= 56%
    1- (100C / 600C) ~= 1 - ((100C+273 / (600 + 273)) = 1 - (373 / 873) ~= 67%​
    Back of the envelope, 67-56 ~= 11% less heat energy needed by increasing the steam inlet temperature (and pressure.)
    #96 bwilson4web, Jul 26, 2017
    tochatihu likes this.
  17. tochatihu
    9,957
    3,845
    2001 Prius
  18. tochatihu
    9,957
    3,845
    2001 Prius
    A detailed, optimistic roadmap for fully renewable energy by 2050.
    susenergy2030
  19. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Watched the 6-7min slide video. Hoping for the same timeframes, but also less optimistic here.
    I wonder particularly about decarbonizing heating (homes, businesses, water heating, clothes drying, etc.), which is a significant component of total carbon emissions. Electrifying transportation and decarbonizing electricity generation have begun in earnest but will not be enough.
    In the US, natural gas furnaces and dryers are common. These will need to be replaced with air or ground sourced heat pumps and heat pump or electric heating element dryers. So far there doesn't seem to be a push for this transition. So if houses/commercial/industrial buildings built in the next 20 years still have fossil fuel source furnaces, goals will not be reached by 2050. Building codes would have to change now.
  20. tochatihu
    9,957
    3,845
    2001 Prius
