Electrical issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PapaGallo, Aug 5, 2014.
  1. PapaGallo
    PapaGallo Junior Member
    58
    22
    nj
    HI
    i am having a problems with my prius.
    its all intermittent, the windows will not work, or the sun roof,neither will the ac.
    with the ac, no cold air comes but the the fans works.
    also i get the parking brake light when i am driving, but the flashes on and off and goes away after a minute or so. the
    has anybody had similar issue like mine. I have never replace the 12 volt, can these issues be traced to 12 volt batter that need to be replace.
    purchased it in 9/10 so the batter is 4 years old, i have 44 k miles.
    any help will be greatly appreciated.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    These do not sounds like 12v problems. It sounds like rodents honestly. The car (as with most modern vehicles) has an unbelievable amount of wiring. If a mouse or something chewed through some of the insulation and now you get intermittent shorts between wires, this could explain things.
    I would just get on your back and look around under the dash of the passenger and driver side. Make sure what you are looking at looks normal. Wires are bundled and clipped and look like new. Check your cabin air filter. Mice love making nests inside of that area.
  3. PapaGallo
    58
    22
    nj
    thanks ill check it out
  4. PapaGallo
    58
    22
    nj
    HI
  5. mrbigh
    3,686
    699
    Long Island, NY
    Was this vehicle involved in a flooded circumstances? or it had a salvage title?
  6. PapaGallo
    58
    22
    nj
    No, I am the original owner.
    It has never flooded, I also check to see if there was any leaks into the car by the dashboard , there was none.
  7. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Your 12v battery is probably on the weak side. If you have a -Nav or -Solar you can use the diagnostics to check the battery's voltage.
  8. PapaGallo
    58
    22
    nj
    I have nav , how would I check the status of the 12 v battery?
  9. bisco
    52,393
    check to see if the viper smart start is wired correctly.
    #9 bisco, Aug 5, 2014
  10. PapaGallo
    58
    22
    nj
    Hi Bisco
    what values would denote a weak battery and a good battery?
  11. bisco
    52,393
    a new battery is around 12.9 volts. when you get down toward 12, they become a bit sketchy.
  12. Okinawa
    Okinawa Senior Member
    1,333
    320
    I would just put in a new 12 volt battery. You are due anyway.
  13. PapaGallo
    58
    22
    nj
    Okinawa
    what battery would you recommend?
  14. nedear88
    nedear88 My 1st Prius.
    246
    142
    San Bruno, California
    I bought this one and installed, peace of mine for the next 5 years.
    It's still cheaper than dealer.
  15. Okinawa
    1,333
    320
    For a Prius, I don't know. I would just have to take the safe course and have Toyota replace it with a genuine Toyota battery. I'm sure you will get some recommendations from people who are more knowledgeable about batteries for a Prius than I am.
  16. worrachai
    worrachai Junior Member
    48
    thailand
    I'm Prius owner in Thailand. The battery checking is below method.
    After stop your vehicle by push start/stop botton 20 mins.
    -push the start/stop bottom without push brake paddle.
    -hold the info bottom on your car radio(navigation)
    -turn on the head light and turn off 3 times. Your navigation will show the service menu
    you can select the mode that show on the battery voltage on currently.
    I'm not sure, Prius of your country is same operation program with Thailand side or not.
  17. PapaGallo
    58
    22
    nj
    Thanks for all the responses to my post,
    I took it to the dealer,they diagnosed that a Viper smartstart system was causing the electrical issues.
    Seems that the leads to power the startsmart system were the ones causing the issue, the dealer, rewire the power leads, and the issues stopped.
    also they checked the battery, and its good.
    thanks again
  18. bisco
    52,393
    congrats, good dealer!
