Electrical or Engine Failure?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ElusiveIllusion, Oct 20, 2017.
  1. ElusiveIllusion
    ElusiveIllusion New Member
    New Jersey
    I don't believe I have an icon that says auto at all, otherwise I'd leave it there, but this is good to know. My old Maxima was like this and I left it on auto all the time, i miss those amazing double headlights I used to have, but oh well.
    I'm going to be diligent af to make sure I ALWAYS turn off my lights, lol
  2. Prodigyplace
    12,635
    11,812
    Central Virginia
    Personally my issue is this is the first car I have had where you can turn off the running lights. I need to watch I don’t accidentally turn them off.
    ElusiveIllusion likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Elusive,
    The symptoms you had are unlikely to be due only to a low 12v battery. I'm not going to say impossible, but unlikely. I had the combo meter issue occur on my 2005 one time. It was an unusually cold and damp day for that time of the year. Exact same symptoms as you had. EXACT. Drove fine the rest of the trip, even with the dash off. Parked it when I got home, held the power button for a handful of seconds until the car finally turned off. Figured I should expect to have to replace it soon. When I started it the next time, everything was fine. That was well over a year ago and it hasn't happened since. I wouldn't worry too much about it unless it starts happening more frequently.
    On another note, yes, your headlights should turn off automatically following you turning off the car. Turning them off yourself is a good habit to develop, just to be certain nothing silly happens. Let the 'auto off' be your backup. The auto function on the control stalk being discussed in this thread is for the option of the lights turning on and off automatically, based on light intensity levels outside the car.
    Also found this little tid-bit of info:
    The auto shut-off only works if the lights are on and the Prius is off before the driver opens the door. Failure to meet these requirements will leave the lights on indefinitely, or until the battery dies. Likewise, exiting through another door will leave the lights on.
    So, if you do something like open the driver door, then turn the car off, the 'auto off' timer doesn't engage.
    #23 TMR-JWAP, Oct 23, 2017
    Fred_H likes this.
  4. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Tell us that you are still checking the oil level (on the dip stick) occasionally. Most Prius need this, especially once they're up around 100k miles or more. A good many higher mileage Prius require a top off between oil changes. So make sure you look at oil from time to time.
    Fred_H likes this.
  5. ElusiveIllusion
    New Jersey
    Yes, of course! :)
    uart likes this.
  6. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    We leave the headlamp switch on, the lights turn off with the car.
    fotomoto likes this.
  7. Prodigyplace
    12,635
    11,812
    Central Virginia
    You leave your headlights on all the time? I guess that makes sense on a 2005 with yellowed lenses.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    We do too on our '06 (leave in the on position). They turn off when the car is turned off AND the drivers door is opened/closed.
  9. Prodigyplace
    12,635
    11,812
    Central Virginia
    I would think the daytime electrical draw would reduce your MPG. That would not be as much of an issue with the Gen 4 LEDs
  10. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    The halogen bulbs create a warm area directly in front of the headlight. Lower density in that area reduces the overall drag of the car, actually increasing MPG, which exactly offsets the MPG reduction caused by the power draw.
    AIYBT,IHABTSY
  11. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Sort of the thermal version of dimples on a golf ball, right? :LOL::LOL::LOL::ROFLMAO:
    Prodigyplace likes this.
  12. 05PreeUs
    1,097
    565
    MSP
    You have seen our car? I thought not.
    Since DRLs were not standard and everyone in our family drives with the lights on for safety, seems like Toyota already thought of it, which is why the lights turn off with the car.
  13. fotomoto
    5,639
    3,815
    So. Texas
    Edit: ^ what he said. LOL
    You're correct since all energy comes from gas but it's only to a very small degree. I'd rather be seen and since the Gen2 doesn't have DRL's this is the ghetto fix. :D
  14. 05PreeUs
    1,097
    565
    MSP
    I would not call it ghetto, since before software control, it was the ONLY way to have your headlamps on ;)
  15. Prodigyplace
    12,635
    11,812
    Central Virginia
    I remembered my son's old 2005 having DRLs but it was a Trim 5, IIRC.
    Perhaps my memory is faulty. I know his 2015 Prius v has DRLs.
  16. jerrymildred
    11,517
    14,157
    Tampa, FL
    DRLs or fog lamps. My 2005 trim 6a had fog lights. Talk about useless!
  17. Prodigyplace
    12,635
    11,812
    Central Virginia
    The headlights got quite yellow too by the time he bought his 2015 v.
    jerrymildred likes this.
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    Mine did, too. They polished out OK, though.
  19. dolj
    dolj Senior Member
    8,531
    4,332
    Wellington, New Zealand
    Yes, that is correct, it comes on every 5,000 miles. The procedure to reset is in the owner's manual, if you need to do it yourself.
    Fred_H likes this.
  20. ElusiveIllusion
    New Jersey
    Sooo, it's been quite some time and seemed like everything was OK until it happened again, right after a rain storm. I really don't understand, I drove it this past weekend in the cold and rain fine. The next morning, the digital dash was dead again. We replaced the battery completely which seemed to fix things but then as I was going to try and go to work today, since I've been working from home all week since this happened, the dash was completely out again. It HAS to be the combo meter failure at this point.
    I'm taking it to our mechanic, who doesn't really work on hybrids but he said he can check it out anyway, if he can't fix it, I basically have to go to a dealer. I'm prepared to pay whatever right now because I need a working car! This keeps happening before I take a big trip too, I am going on a mini-vacation this weekend and everything was ready for the Prius. Guess we'll have to take my boyfriend's old nice person car. Annoying is the understatement of the year with this :(
  21. Fred_H
    Fred_H Misoversimplifier
    560
    485
    28
    Germany
    At the beginning of this thread there are some good tips such as:
    If your mechanic can't fix it, maybe Matt @Texas Hybrid Batteries could send you an already repaired one promptly, and you could have it installed by your mechanic or dealer.
  22. jerrymildred
    11,517
    14,157
    Tampa, FL
    Easy to do. Just follow this guy's example and get one from Matt.
    Mendel Leisk and Prodigyplace like this.
