Electricity Consumption?
Discussion in 'Gen 3 Prius Fuel Economy' started by Triparadox, Aug 13, 2019.
  1. Triparadox
    Triparadox Active Member
    201
    108
    So if you look at the Hybrid System Indicator, on the page where it shows you your MPG every 5 minutes, you will see car icons stacked on each bar. On the right side there's the info saying that each car represents 50 Wh. What I am not sure is if it's the amount of electricity being generated or electricity being used. In Camry Hybrid, it represents the amount of electricity being used, but in that case, it's mentioned in the display.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    It’s the amount of energy you’ve generated by braking;).
    Always good to see a lot of cars there if you avoid using the actual brake pads (y).
  3. fuzzy1
    10,662
    Also know as regeneration.
    These symbols appear on downhills, and during stop-and-go braking such as city driving. On flat highways at steady speed, there should be none.
  4. CR94
    CR94 Senior Member
    2,794
    1,227
    Northwestern S.C.
    Always good to avoid regenerative braking too, when practical. You don't get back nearly as much mechanical energy as went into braking, due to losses. Worse, much of the lost energy ends up heating the battery.
  5. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Only couple of degrees, but if your pushing pass 60% soc then temps climb faster. As an experiment I drove down from the dam starting soc from 41% to 73%, temp jump 70F to 98F in 2 minutes. With my hv fan mod, the next weekend, temp only went up to 84F, same soc from 41 to 73 exactly.
  6. bisco
    52,679
    if you can coast all the time, congrats, you've defied the laws of physics
    Raytheeagle likes this.
  7. Tideland Prius
    16,658
    It’s energy regenerated through regenerative braking. It’s 50Wh for the 5 min interval and 30Wh for the 1 min interval (hold DISP on that screen to toggle between 1 and 5 min bar graphs)
  8. CR94
    CR94 Senior Member
    2,794
    1,227
    Northwestern S.C.
    ...and that's where your SOC will go if you're cruising merrily along at six segments, then have to stop on a downhill, especially if you have to do the same again soon. That scenario yields considerably more than a couple of degrees increase, in my experience.
  9. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Generated 1.21 gigawatts. SOC 78% in red, ICE only at 150F though. HV air intake mod kept battery below 90F, usually around 105F w/o the mod.
    RMB and Raytheeagle like this.
  10. Threej
    Threej Member
    99
    99
    Portland, OR
    I think we call that condition "orbiting"
  11. Tekken
    Tekken Member
    259
    77
    Los Angeles, California
    How do u mod your HV air intake?
  12. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    He basically disassembles his interior:cool:.
    Not for those who carry passengers ;).
    But if it is just you, why not(y).
  13. Triparadox
    201
    108
    Wait, where are you getting that 1.2 GW figure? You produces 510 Wh in 15 mins. Multiplying that by 4 you'll get the amount of electricity you produce in an hour (2040 Wh or 2.04 KWh). Since you produced 2.04 KWh electricity in an hour, the rate of electricity produced is 2.04 KW. It's nowhere near GigaWatt...
  14. Threej
    Threej Member
    99
    99
    Portland, OR
    Bless you for not getting the reference.
    Grit likes this.
  15. Triparadox
    201
    108
    Thanks for the blessing since I'm not american
  16. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Cold air from AC piped directly to the HV air intake, cools the HV battery to mid 70Fs when it's 100F+ outside ambient temp.
  17. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Thanks for the save.
    Threej likes this.
  18. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    I did not get the joke either. With Three Mile Island finally closing down last week, I was hoping they might be able to replace it with your Prius.
  19. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    Interesting...did you pipe it from the vent under the front passenger seat?
