Electricity cost more than gasoline these days.
Discussion in 'Prime Main Forum (2017-2022)' started by CaliforniaPrius, Jul 19, 2016.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    There have been some threads on here that argue using more charge cycles from the battery is worse off than wear and tear on the gas engine. The battery has a finite number of charge cycles and will wear out faster than the gas engine. We can certainly argue but there isn't enough data to point one way or the other.
    Andyprius1 likes this.
  2. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Very true.
  3. Andyprius1
    2,327
    859
    Cool CA
    This way you'll be able to sell a antique Prime with a brand new engine. Seriously, the ICE has a very good charging potential on the road.
  4. bwilson4web
    16,205
    Don't forget to update your will and testament to pass on the brake pads to your survivors.
    What I'm suggesting is we don't have metrics on how long these Prime traction batteries last. In contrast, one of our former cars continues to run over 172,000 miles on the original brake pads and shoes.
    Unlike the Gen-1 Prius, there has been a lot of development and improvements in traction battery management. It turns out we do have data for the first generation, PiP: 2013 Toyota Prius PHEV | Advanced Vehicle Testing Activity
    So I took a quick look at the PiP traction battery aging:
    I'm sorry but looking at these numbers, the PiP did pretty good. Of course I've assumed the PiP has a similar LiON traction battery to the Prime and that has not been asserted. But we do know the Prime capacity is significantly larger.
    #184 bwilson4web, May 21, 2017
  5. hill
    8,803
    true - but, there is SOME data. There are hybrids that have traveled over a ¼mil miles, & there are a handful of Model S's that have traveled over a ¼mil miles. So - people that say such things are in part - speaking out of ignorance. The cost to rebuild both the ice & traction pack are pretty similar to rebuilding just one huge traction pack. The reliability of both ICE & traction packs continues to increase. Also, traction packs continue to drop in price, while costs to rebuild an ICE continues to cost more. Just something to think about.
    #185 hill, May 21, 2017
    bwilson4web likes this.
  6. bisco
    51,908
    well, it is li-on, but i don't know how similar.
    btw, electricity costs more than gas in only a handful of areas in the u.s.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Based on ordinary Li-ion technology, I can give you a mathematical argument on why the battery should last more than 150,000 Ev-only miles before losing 15% of its capacity.
    An ICE won't last that long on very short trips. It will last much longer than that on longer trips.
  8. bisco
    51,908
    i guess you would have to research corolla chat, or some such, to find out how many ice problems they are having.
  9. hill
    8,803
    true, but our area is one of those expensive gasoline areas. And we are in the area where the largest amount of cars exist. Just one of the factors to toss into the mix.
    Saw several stations that were charging around $3:50 /gallon through our travels down to San Diego yesterday.
  10. bisco
    51,908
    sure, we all have those, but what is the best deal locally, and how much do you pay to charge?
  11. hill
    8,803
    I, like many around here charge via surplus solar. Our 2nd ev though, means the meter will run forward ~ $25/month - for the extra 1Kmiles of gasless driving.
    If we are filling up the hybrid Lexus (which we seldom Drive anymore) prices for regular run between $3:29 / $3:49 thru out the city - according to quick look on gasbuddy.com.
    #191 hill, May 21, 2017
    Son of Gloin and bisco like this.
  12. bisco
    51,908
    so it sounds like gas costs more than electricity.
  13. hill
    8,803
    Yep .... Everything or nothing
  14. bisco
    51,908
    that's why i say electricity costs more than gas in only a handful of places.
  15. JoePriusPrime
    JoePriusPrime Member
    46
    35
    Denver, CO
    EV: $.13/kWh x 6.5kWh = $.85 (25mile range)
    HV: $2.30/gallon = (about 50mile range)
    So to go 50 miles EV cost me around $1.70 and HV mode cost me around $2.30
    EV is slightly cheaper especially when I charge at free ChargePoint stations.
    JoePP
    Denver, CO
    Xcel Energy Tier 1
    #195 JoePriusPrime, May 24, 2017
    bodgm likes this.
  16. bodgm
    bodgm Junior Member
    58
    US
    So, the Xcel energy cost in Denver is 0.13/kwh
  17. JoePriusPrime
    46
    35
    Denver, CO
    The cost varies every month depending on your usage. Xcel energy list rates per kWh on their website.
    I think if I stay under 500 kWh total monthly usuage (tier 1) the rates are cheaper than (tier 2) which is over 500 kWh.
    The NJ dealer finally got my plates and FedEx over to me tomorrow. Can't wait to drive legally again!
    Prius from Dad likes this.
  18. Andyprius1
    2,327
    859
    Cool CA
    while I was eligible for free charge at charge point, I noted thier normal price was .33 a KWhr, at home my cost is .075, where's the incentive?
    3PriusMike and Son of Gloin like this.
  19. Prodigyplace
    12,558
    11,775
    Central Virginia
    That depends on the cost of fuel for your trip until you get home to recharge.
  20. Andyprius1
    2,327
    859
    Cool CA
    .13 in CO and .33 in CA ? sounds unbelievable!
    Its much more complicated than that. The engine has a warmup penalty, after that it's very efficient. On a short trip I like to start in HV. With slow city traffic the engine keeps the charge up with very little loss, then once on the freeway I switch to EV. I'll use most of that, if getting low I'll switch back to HV. No matter what the dash says, it's really a blended mode and whenever the load changes (hills) then the blended mode also changes. The car is smarter than I am and programmed thru many computers to operate at peak efficiency.
    Unless you change the programming by stomping on the accelerator.
