Electricity cost more than gasoline these days.
Discussion in 'Prime Main Forum (2017-2022)' started by CaliforniaPrius, Jul 19, 2016.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    BUT, and it's a big butt, the car charges quite nicely while driving. So one can continue switching modes when appropriate. I'm speaking of speeds of 35 - 55 mph, probably none of the above applies at 85 mph.
  2. JoePriusPrime
    JoePriusPrime Member
    46
    35
    Denver, CO
    According to GasBuddy.com SC has the cheapest gas at around $2.00/gallon and CA tops off at $3.00/gallon so let's take the national average at $2.50/gallon.
    HV cost: 50miles ($2.50) 25miles ($1.25)
    EV cost: $1.25 / 6.5 kWh = $.19/kWh
    Break even point is around $.19 so if your paying on average more than $.19/kWh then regular petroleum is cheaper than plugging in.
    *Disclosure: these numbers are estimated by my personal research and I do not hold a PhD in mathematics.
    Son of Gloin likes this.
  3. Prodigyplace
    12,555
    11,773
    Central Virginia
    Also, the convenience of charging right there vs your time & inconvenience factor to go home and charge factor into this, especially if home is level 1 charging.
  4. Lemooron
    Lemooron Junior Member
    73
    25
    Lemoore, CA
    I ran 1 complete tank without charging and I got 52 mpg (hand calculated). Currently gas here is 2.779. My car gets an average of 4.57 miles per kwh. I figure that 52/4.57=11.38 kwh to go 52 miles. I am on EV-B rate which is .1214 per kwh. 11.38 kwh costs $1.38 so I figure that EV is about 1/2 the cost of gas for me at this point.
    Prius from Dad and bisco like this.
  5. Dale Leonard
    Dale Leonard Member
    66
    47
    Hartland, Wi
    That's the best way to figure it.
  6. JoePriusPrime
    46
    35
    Denver, CO
    By inputing your local gas $2.78/gallon and by dividing your 11.38kWh by two equals the amount of one full charge 5.69kWh (about 25 mile EV range):
    HV cost: 50miles ($2.78) 25miles ($1.38)
    EV cost: $1.38 / 5.69 kWh = $.24 / kWh
    So your break even point is around $.24 per kWh. And if your paying $.12 per kWh that is exactly half of what you will pay compared to petro.
  7. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    So... if your numbers / estimates are more-or-less correct, and if I'm NOT "misinterpreting" what you say... does this mean that once we have our Prime / "Premium" our driving costs in EV will be lower than HV costs?
    Around here, gas is currently $2.35-ish, and the cost per kWh from our most recent electric bill was:
    A) $.143 ... that's when taking the TOTAL of our most recent electric bill (including ALL "Rider Fees", taxes, etc.) divided by the number of kWh usage - 643 - for the month... OR...
    B) $.073 ... that's when taking ONLY the "Total Energy Charges" (being charged for some kWh @ $.0929 / for some kWh @ $.0542) divided by the number of kWh usage - 643 - for the month.
    PS: I don't have a PhD in mathematics either... snicker....
    Prius from Dad likes this.
  8. JoePriusPrime
    46
    35
    Denver, CO
    A) is what I used to calculate my own cost. My Xcel Energy bill charges for my total electricity $.13 per kWh in Denver, Colorado. This number varies by usage, fees, taxes and it depends on what county you live in.
    Prius Prime battery is 8.8 kWh total but Toyota designed the HV mode to kick in when the battery reaches 25% capacity meaning when we charge from empty to full it's actually 6.5-6.6 kWh not the 8.8 total kWh.
    Hope this helps those of you paying more than $.20 per kWh you should just fill up with regular gas.
    I did pass Calculus 1 in college :)
  9. JoePriusPrime
    46
    35
    Denver, CO
    Maybe this will make it easier for people to understand relating to the original post:
    HV mode (burning gasoline)
    California: $3.00/gallon divide by 52mpg = $.057 per mile
    South Carolina: $2.00/gallon divide by 52mpg = $.038 per mile
    EV mode (using electricity)
    $.20/kWh multiply by 6.6 kWh = $1.32 divide by 25 miles per charge = $.052 per mile
    $.10/kWh multiply by 6.6 kWh = $.66 divide by 25 miles per charge = $.026 per mile
    Toyota Land Cruiser: $3.00/gallon divide by 15mpg = $.20 per mile!
  10. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    So the battery gives you 8.8x4.57 = 40miles EV range in one charge?
  11. JoePriusPrime
    46
    35
    Denver, CO
    6.6x4.57 = 30.16 miles EV range. I've been getting about 32 and others I've seen as high as 37mile. Probably hypermiling at 40mph.
  12. CharlesH
    2,796
    1,163
    Roseville, CA
    The SOC (state of charge) ranges from around 21% (in HV mode) to around 85%. Factor in around 85% charging efficiency, and you get the observe 6.5kWh from the wall. 100% SOC is not good for a LiIon battery.
  13. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    I don't have a Prime, so I only care about gas prices. Even though I live in California, I drive to Arizona every week, and buy most of my fuel there (Chevron/Texaco only). Right now Arizona gas is about $2.35 a gallon, in Cali it's $3.20 or higher.
    For Prime owners, a graph showing break even costs would be nice. Or an online calculator. But it would probably take at least a passing grade in Calculus 1 to figure out the math :).
    alexcue likes this.
  14. alexcue
    alexcue Active Member
    346
    311
    So Cal
    IMG_0124.JPG Courtesy of Lee Jay in case you haven't seen it.
  15. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    FWIW, I've been calculating my kWh used for the past 10 days and the average is 6.28. So I use that to figure my cost.
    JoePriusPrime likes this.
  16. Son of Gloin
    421
    320
    Lafayette, IN
    Thanks for posting / sharing this again... that's good to know, AND it was very nice of Lee Jay to do the math for people like me!
    alexcue likes this.
  17. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    As others have alluded, we’re only using about 6KWh of the battery’s total capacity, and most of us are seeing, for now at least, more like 32 miles from that. My P.Prime itself reports about 4.7 miles/KWh, which is a whole lot better than the 2.5 number from your estimates.
    Granted, that efficiency will gradually reduce over time, as the battery ages.
  18. mr88cet
    2,313
    1,335
    Austin, TX
  19. hill
    8,803
    Yes & No - if I may respectfully pick a couple nits.
    Even though the traction pack will lose capacity, while running Ev, its efficiency will remain the same. Similarly the ice efficiency will remain the same. However, with less traction capacity the vehicle will start using more of the ice, so your miles of EV drive time will decrease. IOW, as your traction pack ages, if you keep driving less & less miles, you can maintain the same efficiency, you will just have to charge up a whole lot more, to avoid using more & more ice .
    mr88cet likes this.
  20. mr88cet
    2,313
    1,335
    Austin, TX
    I seem to recall that the internal resistance of Li-Co batteries does gradually increase over time, which would reduce efficiency. However, now that I think of it, that might be more associated with DC quick-charging than normal use, though...
    I would expect ICE efficiency to decrease gradually as well from wear, although not by a whole lot, assuming that it is well-maintained.
  21. mr88cet
    2,313
    1,335
    Austin, TX
  22. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    My 30-year-old ICE got better mileage when 30 than when new, and not by an insignificant amount (31 -> 35).
    mr88cet likes this.
