Electricity cost more than gasoline these days.
Discussion in 'Prime Main Forum (2017-2022)' started by CaliforniaPrius, Jul 19, 2016.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I always thought it would be neat to control the heat exchange between the refrigerator, dumping the heat into the house during cold days, and venting it outside on warm days.
    I'd just about be able to heat my house entirely through careful manipulation of the window blinds. I have gone until November without starting the furnace up. If I could somehow connect the blinds to a controller that can monitor indoor, outdoor, and forecast info, the whole thing could be automated. Same goes for cooling by opening windows.
    fuzzy1 and KrPtNk like this.
  2. fuzzy1
    10,393
    After going on a conservation kick, I found that deliberate manual control of solar heat gain had a significant impact. Block most direct sunlight from flooding through the patio slider door in summer. (The roof eve profile is well designed to keep summer sun completely off the other glazing early May to mid August.) In winter, set blinds to maximize this incoming light, wash the windows, and remove the bug screens that block 25-30% of the available heat. And do this on every south facing window, not just the main picture windows. Even the back rooms that are little occupied.
    After improving air infiltration and some insulation, this active (but not automatic) sunlight management is effective enough to keep the heat turned off for more months than when we purchased this house. And now that we have AC (it came free with the ductless heat pump), we hardly have any need for it anymore.
    Automatic controls would be even better.
    Redpoint5 likes this.
  3. hill
    8,785
    one can skew any set of data to make it look however one wants. Leave off oil company tax free operations - leave off gasoline road taxes insufficient to even fix potholes/infrastructure, leave off how PHEV's lug around their ICE/gastank extra weight efficiency loss, compared to their ev counterparts, or that PHEV's incur costs of oil, fluids, tuneups, smogchecks, ect, or that folks who use PV - which eventually pays foritself in X years, leaving zero cost for electric 'fuel' . . . . no need to further beat the dead horse - via respiratory cost issues, pollution/CO2 cost issues, etc. Any way - there's the equally overskewed counter side. But ok, in your area your gas - your exact time frame - your facts. Looks right I guess.
    51,820
    i also have thought of the refrigerator idea. that baby puts out a lot of heat. seems like it would be simple enough to capture it into a duct, which the home owner could choose to take advantage of, or not.
  5. fuzzy1
    10,393
    Better yet, get a modern energy-efficient fridge, it should put out less heat. Many should average about 40 to 50 watts.
  6. bisco
    51,820
    ours is 8 years old. fairly efficient i guess, but i can't see replacing perfectly good appliances every 8 years.
  7. Prius Maximus
    Prius Maximus Senior Member
    955
    810
    Northeastern IL
    How about that gas water heater exhaust duct? That sucker gets really hot. It should be insulated in the summer, and could be used for heat in the winter. I tried the clothes dryer thingie, but that was way too much humidity pumped into the house.
  8. bisco
    51,820
    illegal in massachusetts. not sure how to insulate the hwh duct, double wall pipe?
  9. fuzzy1
    10,393
    You guess? What does (or did) its Energy Guide label say? No guessing necessary.
    Better yet, use that heat for its intended purpose, making hot water. This is more efficient than re-purposing 'waste' heat to anything else. Condensing gas water heaters do this, leaving the exhaust gas cool enough for plastic pipes.
    Trollbait likes this.
  10. bisco
    51,820
    um, i haven't seen it in 8 years?:oops:
  11. fuzzy1
    10,393
    You may still be able to look it up online. My previous fridge's energy consumption was still listed much longer than that.
  12. bisco
    51,820
    could be, but i'm not spending 2 grand to save a little heat, it'll breakdown soon enough anyway.:p
  13. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Just filled up the Sienna at Costco for, you know, $2.29/gallon.
  14. bisco
    51,820
    i thought cali was espensive, that's the same as here.
  15. DavidA
    2,344
    1,820
    Chicago western burbs
    Electric is now looking better. Gas up to $2.50 around Chicago and rising.
    The rear porch just got rebuilt with provisions underneath for easy access (yet hidden) to what will be a level 2 charging EVSE box and cable.
  16. vintagebob
    vintagebob Junior Member
    98
    San Jose CA
    It is nice that we have a choice. Gas or electric, which ever one is cheaper. With my two wine cabinets, a frig and running AC my electric can get to 0.40KW! : 0
  17. bisco
    51,820
    gas still low here, no movement. i with i had gas powered a/c.:(
  18. DavidA
    2,344
    1,820
    You have 2 wine cabinets and a refrigerator in your car? Nice! I was only thinking of adding a latte machine where the rear seat storage bin is in the Prime. I need to think LARGER.
  19. Trollbait
    12,496
    Go big or go home.
  20. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I would say Bisco has it right. It's the total electrical bill that should be used, including "delivery charges", "system maintenance", taxes, etc.
    The reason is those charges are "lumped in" to the cost of the gasoline you buy. Just because you have to drive to the station to get it is no excuse to remove those charges from the electrical bill. The station you use is "handy" (on the way). Charging is also "handy" (at home or work, or a "charging station", again, "on the way").
