Electricity cost more than gasoline these days.
Discussion in 'Prime Main Forum (2017-2022)' started by CaliforniaPrius, Jul 19, 2016.
  1. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I have done this with the PiP. It takes 3 kWh to charge from "empty", and I go about 13 miles on the charge. At my $0.08 / kWh, the total cost to charge is $0.24. $0.24 / 13 miles = $0.02 per mile. My cost per mile is about $0.04 / mile on gasoline at current prices.
    Now that I'm using a 240v L2 charger, I don't have the equipment to measure energy consumption, but as Hill pointed out, it's about 15% more efficient. Finishing the charge 1hr sooner means the cooling fans don't have to run as long.
  2. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    Not only that, it's worth noting that the Prius two Eco gets better MPG then the prime. That of course assumes that you're not taking very short trips all the time, if that's the case then you might be better off with the prime if the energy price levels flip, but I drive on the highway four hours per week, the prime just doesn't make sense for me.
    week
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    EPA rated, and without any electricity used in the Prime.
    You'd have to be paying more than $0.15 per kWh for electricity for the Prime to lose in cost per mile at today's gas prices in your area.
  4. hill
    8,803
    How does one account for less ICE wear ...
  5. Trollbait
    12,531
    That could have been factored in by longer oil change intervals, but Toyota uses a flat miles driven regardless of mode and engine conditions.
  6. Lee Jay
    5,850
    4,036
    Considering the ICE is highly likely to out-last the battery, I don't consider this an advantage of the Prime.
  7. Lee Jay
    5,850
    4,036
    Does the car record how much electricity is used to charge it? Or do I have to break out the Kill A Watt for that?
  8. fuzzy1
    10,440
    Folks handy and comfortable with electricity can even put together their own KWH meter for 240V.
    I've done this for my water heater, ductless heat pump, and electric dryer, using standard old but refurbished electric meters previously used by utilities for ordinary home billing. These are available cheap from some RV supply houses.
    The water heater and heatpump are hardwired, so I added meter bases in their branch circuits, and just plugged the meters in. Because this goes into the house wiring, it legally requires a permit and an inspection. I was doing my own electrical work when moving the water heater from kitchen to garage, and when installing solar PV, so simply included the sub-meter projects in with those permits and inspections. This will not be a friendly or inexpensive route as a stand-alone project.
    But the electric dryer is plug-in, so no hardwiring or electrical permits are needed. Just take another meter, a meter base, a separate dryer pigtail to plug in to the wall, and a new socket on a pigtail. Voila, a 240V 'kill-a-watt', or at least the KWH function of it.
    Don't attempt this sort of project if you are not already comfortable working with electricity. The potential dangers are considerable.
  9. hill
    8,803
    The attached pic - for DIY'ers is about as simple as it gets - splicing one of these bad boys in line. uploadfromtaptalk1479671173314.png
    But like fuzzy says, don't do it if you aren't knowledgeable about electricity
    #129 hill, Nov 20, 2016
    fuzzy1 likes this.
  10. Redpoint5
    1,026
    509
    Portland, OR
    The car shows how much charge it accepted in the battery, but doesn't show how much was wasted as heat, or in running the charge controller, fans, etc. This is how you calculate the charge efficiency. Take the kWh the car shows in the battery, and divide by the kWh from the wall as measured by a Kill-a-watt. This is how we know 240v charging is more efficient than 120v.
    If I recall, that device is about $150 on Amazon. The disappointing thing is that you can pick up a 120v Kill-a-watt for $15, but there isn't anything even remotely as cheap for 240v, even though the principle and construction is the same.
    #130 Redpoint5, Nov 20, 2016
  11. fuzzy1
    10,440
    Ingredients for my 240V watt-hour meter for my clothes dryer:
    Refurbished meter: $16.50 at Hialeah Meter Co.
    Meter base: $11
    Dryer pigtail: $9 at a big box hardware store
    Dryer outlet (surface mount): $7
    Wire: leftovers
    Wire strain relief/clamps: leftovers
    Samprocat likes this.
  12. hill
    8,803
    I think we picked up ours for about $90 on Amazon. I used it to see the accuracy of our inverters' meter.
    #132 hill, Nov 20, 2016
  13. Trollbait
    12,531
    You can also just get an EVSE that has the kW meter built in.
  14. Andrew May
    Andrew May New Member
    Orange County, CA
    Is that accurate? I thought they recently removed the quota on stickers. My neighbor has an Audi Etron and he just got his green sticker a week ago...
  15. bisco
    51,899
    you're quoting from july. they have since extended the stickers.
  16. GA_Prime
    GA_Prime Junior Member
    Atlanta, GA
    According to this study in 2013
    https://www.veic.org/docs/Transportation/20130320-EVT-NRA-Final-Report.pdf
    "A more granular analysis of the data revealed Level 2 charging to be considerably more efficient than Level 1 charging in “low-energy” charge events—when less than 2 kWh drawn from the grid. Level 2 charging was observed to be 12.8% more efficient on average than Level 1 charging in these instances. In “high-energy” charge events—when greater than 2kWh was drawn from the grid—Level 2 was shown to be more efficient than Level 1 but by the more modest margin of 2.3% on average."
    Redpoint5 likes this.
  17. bwilson4web
    16,204
    Typically due to what are called "(I**2)R" losses. Higher voltages deliver power more efficiently than lower voltages.
  18. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Wow, so much info in this thread. Can I ask for an updated calculation if someone has already done it?
    I live in San Francisco and have solar and also switched to the EV-A plan for California. Under the EV-A plan, I would pay 11.6 cents in Summer and 11.9 cents in Winter.
    I was going to do some calculations to compare my Electric vs Gas costs, but not sure I will get the correct formula. So if someone has already done the homework and don't mind sharing, it would be greatly appreciated.
    Thanks in advance.
  19. Lee Jay
    5,850
    4,036
    Something wrong with the break-even chart I posted on page 4?
  20. bwilson4web
    16,204
    Excellent table.
