electrolysis, HHO intake charge
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, May 12, 2008.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Tom
    Correct, and it even works. Just make sure you're handy with overhauling, as pistons and valves don't appear to tolerate it for very long
  2. jayman
    13,439
    641
    Winnipeg Manitoba
    Oy, my head hurts just thinking about it. No, haven't had enough to drink to make the head hurt
  3. jayman
    13,439
    641
    Winnipeg Manitoba
    Correct, as a "real world" gasoline combustion process will yield NOx, CO2, CO, unburnt HC residuals, H2O, trace metals depending on fuel composition and oil consumption, etc. A lot of the dripping you see from a car exhaust system is condensation
    That said, I don't think any of us will take seriously a magic little box that can deliver more energy than inputed
  4. Trollbait
    12,824
  5. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    Okay, since neither cite has ANYthing to do with electrolysis of water and the introduction of the electrolysis products into an essentially stock ICE, what's your point?
  6. sergio
    sergio McGiver
    Italy
    Shelly
    No one denies that adding Hydrogen can improve engine efficency but the question is : how much energy do you spend to generate such hydrogen ? In my poor knowledge of phisics laws the electrical energy you have to drain from the battery to make electrolysis is higher than total energy supplied by the generated Hydrogen. (You have thermal loss to consider).
    It means that the energy balance will be always negative and also that the extrapower you obtain from the ICE is anyway paid with an extra fuel.
    You can only have an hypotetical advantage if you use an indipendent hydrogen tank but in this case you simply use an external energy to be considered in the total balance.
    But ... anyone is free to have its own dream....
    Sergio
  7. richard schumacher
    7,683
    1,066
    United States
    It's relevant because it describes potential benefits of hydrogen injection (increased octane, decreased NOx), but as you noted the hydrogen is derived by onboard reformation of 25% (!) of the fuel and not electrolyzing water. Generating hydrogen at that rate by water electrolysis would require a big electrolysis cell, a bigger generator to power the cell, a water tank or exhaust water-vapor condenser, and of course a higher-compression engine to take advantage of the octane boost.
    HHO schemes like the OP's can clean up a dirty engine, but the cheaper way to do that is to get the engine tuned up or repaired.
  8. bwilson4web
    16,533
    Hi Shelly,
    I think I see your problem:
    I believe you took this quote from pp. 25 of the reference but unfortunately you forgot to include all of the text:
    An increase in fuel octane number only works if the engine is designed to use that higher octane. Extensive testing with our Prius, Atkinson cycle, engines has shown that our engines are unable, completely incapable of deriving any significant benefit from higher octane. In fact, it takes full throttle application while going up a hill to see a modest, ~1-2% impact but only at the highest power settings:
    It is all but impossible to turbocharge or increase the compression ratio of our Prius engine because two control computers, the engine and hybrid ECU completely manage engine operation. We do not have the source code, much less anything beyond a rudimentary understanding of the sophisticated control laws manage the engine. One Australian did put a turbocharger on his NHW10 but last I heard, it is no longer working and the advantages he described did not seen proportional to the expense.
    "Engines can be smaller and more efficient" only works if the engine is designed from the ground up to use these systems. The mechanics and control laws have to work together with the designed fuel system. Changing the fuel does not magically change the engine. Changing the engine takes tools, parts, and a lot of applied time.
    "Hydrogen addition also facilities ultralean burn" is certainly true IF the engine control computer will support it and you don't 'burn out' the catalytic converter. Our Prius has to properly warm-up and keep the catalytic converter in an optimum temperature range to handle combustion by-products ... including NO_{x} by-products. But this has to be part of the engine control laws, the software that runs in the engine control computer. This is driven by the two O_{2} sensors as well as the air mass flow sensor and throttle position. To simply dump a bunch of hydrogen or for that matter, any combustible fuel into the intake does not change the control laws. Using diesel fuel does not make a gas car into a diesel:
    "Engine efficiency can be increased by up to 30%" does not address the impressive efficiencies already achieved by the Atkinson cycle. What this means is for an ordinary Otto cycle, after doing all of the engine mechanical and control law changes, you can come up with a completely new engine that begins to approach what our Atkinson cycle engine already accomplished. But there comes a limit to the thermal dynamic efficiency improvement and after a while, changing the fuel has no further effect (from Wiki):
    I know this "hydrogen" stuff sounds wonderful but it has to be matched by serious changes in the engine mechanics. Otherwise, it provides absolutely no benefit.
    Now if you really think you can do better, then by all means, buy a Prius, preferably used, and install your "hydrogen" system of choice with an "ON/OFF" switch. That way you can run controlled tests to prove it works. But a better approach is to buy a $600-1,200, Honda generator and apply your system to that small, standalone unit. Make the standalone generators more efficient and you'll really have something:
    If you really want to flog another "hydrogen" fool system, feel free but you might start by first getting the facts and data straight including an understanding of your own sources. It also helps if you begin to study the Prius systems and master these terms:
    • Atkinson cycle - what makes our engines an Atkinson cycle?
    • engine ECU - what are the inputs and outputs of the ECU and control laws?
    • hybrid vehicle ECU - what are the inputs and outputs of this ECU?
    • power split device - how does the power split device work and who controls MG1?
    • mixture trim - how does mixture trim work?
    • catalytic converter - what are the O_{2} sensor signals and what happens when their signals do not match the expected waveform?
    Study: get a Prius to experiment with and come back with your lab results and folks will be more interested in your experiments. But to badly parrot part of someone else's work, lifting their content out of context, this is the wrong way to 'help' us.
    ps. Over the top?
  9. keydiver
    keydiver New Member
    509
    Hobe Sound, Florida
    Device promises to save 60% at the pump | West Palm Beach, Boca Raton, Treasure Coast local news, weather, live radar, investigative from Newschannel 5 | WPTV.com
    Click on the video too. I also would sure like to know if this stuff is snake oil, as I have several friends pressing me to research it because they would like to go together for a group buy. As to the O2 sensor issue, there seems to be some differences of opinion depending which HHO generator website you look at. If the device really does lean the AFR, the closedloop operation of the ECU will just richen it back up until you're back where you started from. I don't see much wrong with a leaner AFR, other than slightly increased NOX, as I've always felt the 14.7:1 figure to be rather arbitrary. I write special code for some turbo cars that allows a 16.5:1 leanburn AFR while at light cruise conditions, and it works just fine. But, I certainly wouldn't want to see someone put the engine under heavy load conditions at that AFR.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Not in the least. It's obvious that you're not mean and cranky like I am, and you have a far nicer and even way patiently explaining things. Just thinking about this snake oil bulls*** makes me want to turn into a Tasmanian Devil
  11. bwilson4web
    16,533
    For a Prius, it is snake oil.
  12. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    Auuugggghhhh! This diagram is going to give me (and probably anyone else who had suffer through Thermo but isn't an ME or Physics major) nightmares for the next week. This is one thing I thought I'd never have to see again. The horror, the horror.
  13. dogfriend
    7,512
    1,191
    Carmichael, CA
    I is a ME and I suggest that you do what I did after the final exam - start drinking heavily to purge the old brain cells. I think Jayman subscribes to this regimen as well.
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    See? There *is* a common basis for engineers and heavy drinking. Though I bet I can drink Tom right under the table if I tried ....
  15. dogfriend
    7,512
    1,191
    Carmichael, CA
    I did subscribe to this regimen back in the undergrad days and found it useful to purge the information overload from studying for final exams. It helped to live within just a few blocks of several bars - it was just staggering distance home.
    In grad school, we had a weekly grad student "seminar" which was held on Thursday afternoons at Sudwerks (a brew pub) in Davis, CA. We would complain about various things while downing lager and marzen, then get on our bicycles and weave our way home. Using a bicycle is much more considerate as a form of transportation when you are falling down drunk because you are less likely to hurt innocent bystanders.
    These days, I must conserve what brain cells remain, lest I want to end up slurping tapioca through a straw in some mental health facility.
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Jayman, I don't know to which Tom you refer, but if it's me, I suspect you are correct. I've heard you describe yourself as looking like a bald ape. Using that same line of description, I'd be more of a dwarf spider monkey. It doesn't take too much to drink me under the table, although I'd give it a noble effort.
    Tom
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    Tom
    Ah, that explains why we make such a team: the mean bald ape and the dwarf spider monkey. Heavy drinking optional (Army + ChemEng = bad for liver)
    jay
  18. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    i didn't know what kind of laughter i was in for when i clicked on this thread...
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Speaking of which
    Drunk Animals of Africa - Video
    "OOOooohhhhh I shouldn't have that last Marula yesterday ....."
    Been there, done that
  20. Goolash
    Goolash Junior Member
    36
    SE Idaho, USA
    That being said, when are they going to come up with acid-resistant ICE components, so I can make myself a nitric acid (HNO3) injection system? It would be like NO2, but even more O! If it's good enough for NASA rockets, it should be good enough for us, right?
