Electronic Test Equipment Qs
Discussion in 'Fred's House of Pancakes' started by Patrick Wong, Apr 1, 2011.
  1. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
  2. Patrick Wong
    18,210
    6,517
    I hooked up the HP test oscillator with the attenuator set to produce the weakest signal, -89 dBm or 7.95 uV, to my Kenwood TS-2000 to compare S-meter readings on the various amateur bands from 1.8 to 10 MHz (since the oscillator will only work up to 10 MHz.) Each band showed test oscillator signal strength of S6 or S7 which was what I had expected to see, except 80/75 meters where the S-meter reading was much lower. It was around S2-3 at 3.5 MHz and did not move the meter at 4.0 MHz. Also, when listening to the signal it is apparent that it is weaker on that band compared to the other bands.
    So, apparently there is something wrong with the receiver RF section for 80/75 meters. Too bad I didn't have access to this test oscillator 5 years ago, when I had bought the transceiver and it was under warranty. I looked in the TS-2000 service manual and there is no provision for tuning 80/75 meters (each band has its own bandpass filter.) My guess is that a diode which switches that amplifier in/out of the signal path is leaky or maybe the transistor is bad.
    I don't use the 80/75 meter band so I don't have a great need to fix this problem soon.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    So you get all this test equipment, fix it up, calibrate it, use it to uncover a sneaky problem......and your not going to fix it?
  4. Patrick Wong
    18,210
    6,517
    Well, the Kenwood transceiver uses surface mount components. Based upon my experience looking at those components in disassembled cellphones, I know that I can barely see them, let alone identify what is what. It's quite likely I would make things worse, not better.
    The 2.5 - 4.1 MHz bandpass filter in question has two diodes and one digital transistor which are used to switch that filter in/out.
    RN731V
    LFB01
    DTA114EKA
    Even the part numbering is weird to me.
    If in the future I decide I need to use the 75/80 meter band, I'll have to ship the transceiver to Kenwood for repair.
  5. fuzzy1
    10,677
    Datasheets for all readily located online (Rohm and Sanyo), giving some guideline for replacements and substitutes.
    Package sizes are still (barely) within my dexterity and vision limits.
  6. snijd
    snijd DIY or die
    243
    52
    PNW
    Ahh, a 1725A scope! I've got one of those, and it works well enough. Also have the 1727A storage scope, and several Tek scopes. The HP is easy to use, and has a nice display.
    As far as a time base, you might want to consider picking up a Trimble Thunderbolt GPS receiver & disciplined oscillator. Around $100, plus power supply and antenna. That will get you a highly-accurate 10 MHz reference for your shop. You can hardly do better, in fact, unless you want to pay considerably more for minimal improvement. You can then add a distribution amplifier to send the signal to your various instruments. tapr.org has offered kits, and there's a really nice one soon to be available, which will outperform their old TADD-1 amp, which I use.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    If you need to remove and replace any SMD parts, send me a message. I do it all of the time with prototypes.
    Tom
  8. Patrick Wong
    18,210
    6,517
    Today I had the TS-2000 hooked up to an antenna and it was picking up plenty of atmospheric noise on 80/75 meters. So I repeated the above test. Now the TS-2000 shows signal strength reading of S7 on every band including 80/75 meters.
    Maybe the Kenwood has an intermittent problem, but it is gone as of this writing.
    Hi Rob,
    Have you noticed broken rubber feet on the rear cabinet of the HP scope? 3 out of 4 were broken on my unit and HP/Agilent no longer stocks spare parts. I ended up buying 0.875" x 1.125" generic rubber "bumpers" from West Florida Components, and then obtained 1/2" aluminum spacers and longer screws from a local hardware store so that the feet would protrude sufficiently to provide protection for the heat sink and power supply transformer sticking out the back.
    Thanks for the suggestion on the time base, that is a very reasonable price. For now, I can sync up my frequency counter vs. WWV at 10 MHz.
    Hi Tom,
    I appreciate your very kind offer! Hopefully I will not have to take you up on it.
  9. snijd
    snijd DIY or die
    243
    52
    PNW
    Patrick,
    The only alternative fix to this problem that I've seen is detailed here. Check the bottom of the page. He's gotten rather creative with some of his repairs. Fortunately, my 1725A has good feet, but the 1727A's are all broken. Neither scope was even close to functional when I picked them up a couple of years ago.
  10. Patrick Wong
    18,210
    6,517
    Thanks for providing the link, quite fascinating. Very creative use of wood! :D
    My preference is to buy equipment that cosmetically is perfect or very close to that condition. It's easier for me to repair an electronics problem (assuming components are not surface mount) than to restore cosmetics.
    My concern is that a complex switch will break, considering that those will be almost impossible to replace.
    If you recall what was wrong with your HP 1725A, I would like to hear about it. I haven't needed to open up mine yet and am wondering what is likely to fail.
  11. snijd
    snijd DIY or die
    243
    52
    PNW
    IIRC, I replaced some power supply electrolytics in both scopes, and on the 1725A a transistor in the sweep circuit, and a transistor driving the reticle illumination.
  12. Patrick Wong
    18,210
    6,517
    Today I bought an HP 608D VHF signal generator from another ham in Mesa, AZ (Phoenix suburb.) This was manufactured in 1957 and has 21 vacuum tubes, only 3 of which actually produce RF. The others provide AM modulation, monitor output RF voltage, produce a 1 MHz and 5 MHz calibration signal, regulate the power supply voltages, etc.
    The frequency range is from 10 MHz to 420 MHz, the output RF voltage range is from 0.1 uV to 0.5V, and it produces CW and AM modulated signals. It works but I plan to replace the various electrolytics since they are so old and have 1957 date codes. Then I will adjust the power supply regulated voltages and the frequency calibration, lubricate the mechanical moving parts, etc.
    See photos. The last one shows two capacitors which are not original. They don't look great so I'll probably replace them again. It also looks like the attenuator assembly was replaced by HP service at some distant point in the past.
    I'm currently looking for an HP 8640B signal generator which is a newer solid-state device, and much more capable with a PLL which locks the output frequency to an internal reference crystal oscillator, to ensure frequency stability. Currently have my eye on a military unit (option 323) located in Atlanta.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I have owned maybe 40 scopes in my life. I still have 2 but my favorite all around scope is the Sencore SC3100. For the money its the best scope ever made imho. It's a really good scope for rudimentary testing and its measures audio dB levels too very accurately. Its a joy to use as it triggers so quickly and takes the fiddle fest out it. And they have a very smart probe system that splits the dc-ac input to separate inputs to the scope so you don't smack the front end of the scope with hi dc by mistake like a tv ho for example. I also have a B & K 40 MHZ that I use to carry around so I don't scratch the hell out of my nice gear.
    But out of all the test equipement I own and it's a shitload the most used is this $100 tester:
    K-7214 ESR meter kit page
    The fabulous Dick Smith ESR meter. I use it almost everyday.
    Finds esr'ed caps instantly.
    I've owned all the cap testers out there and this is the most reliable in circuit meter made. Everything else pales to it. I built this kit in 1980 and its still working.
    My other favorite is my Sunrise Telecom CM2000. I do alot of DOCSIS CMTS and this thing rocks:
    CM2000
  14. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Those are all available from Mouser for pennies. A resistor and 2 Q's.
    The q's are not to hard but the film resistor is tough. So tiny.
  15. Patrick Wong
    18,210
    6,517
    Thanks for the recommendation, I need something like this.
    I measured the AC ripple on the two regulated power supplies and it isn't bad. The ripple on the positive side is below spec and the ripple on the negative side is slightly above spec. So it appears the electrolytic capacitors are working fairly well - but the priority would be to replace the capacitors on the negative voltage supply.
  16. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I've used the 608D and 8640B. The difference in stability between those two is incredible. The 608D you have to let warm up and remain untouched for hours. The 8640B is the exact opposite. Once you get it warmed up after about 20 minutes, it is rock solid with that phase locked, cavity tuned, very clean oscillator. The 8640B is like the Prius of Oscillators......an engineering marvel.
  17. fuzzy1
    10,677
    But is it energy efficient?
  18. Patrick Wong
    18,210
    6,517
    Somewhat, because the HP 608D is rated to consume 220W of AC power while the HP 8640B is rated at 175 VA.
    I've noticed that the frequency stability of the HP 608D is pretty bad, especially above 100 MHz. Compare to the HP 8640B which is rated at < 0.05 ppm per hour drift after a two-hour warmup, when the output frequency is locked.
  19. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Pat,
    We had one of the 608's at the ham shack at my university. It was somewhat sensitive to powerline RF. We would see the level meter jump up when were transmitting. I made a power line RF filter, and that fixed it.
  20. snijd
    snijd DIY or die
    243
    52
    PNW
    Keep in mind that the Opt 323 sig gen lacks the doubler present in the commercial 8640B, so it will only reach 512 MHz. I'm happy with my 8640B, which I can feed with a high-stability 10 MHz reference.
