Electronic Test Equipment Qs
Discussion in 'Fred's House of Pancakes' started by Patrick Wong, Apr 1, 2011.
  1. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Are you using the same probes for both measurements? Both calibrated?
  2. Patrick Wong
    18,210
    6,517
    No probes. I am using two-foot lengths of RG-58/U cable with BNC connectors on both ends. The same two cables were used with the two measurements so the only change was the scope itself.
    The input on both scopes was set to 50 ohms DC, as the HP 3325A expects to deliver the signal to a 50 ohm load.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Any change in waveform when you change to a high impedance? It looks like the vertical amp is being filtered by something (or lack of something), but could be due to impedance issues. Also, is this consistent between different gain settings on the vertical scale?
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    2K1 is on it.
    You must use the Tek Compensated probe Tek P6137 for 2400 scopes which have LF Compensation. Uncalibrated probes looks like your pictures.
    No compensation= massive rolloff.
    Or your generator is sick.
  5. Patrick Wong
    18,210
    6,517
    The Tek 2467 does not show that ripple in the first square wave, only the HP 1725A.
    And, it is not just square waves. A similar issue also shows up with sine waves at VHF frequencies.
    If the issue is due to not using a probe, why is the problem visible only with the first square wave? I'm familiar with the effect of uncalibrated probes, but in that case, every pulse shows a problem, not just the first.
  6. edthefox5
    10,096
    4,837
    Clearwater, Florida
    I see what your talking about now. That crap on the first hor portion of the first display. I was just looking at all the funky roll off.
    I can see your a perfectionist. It may just drive you crazy.
    I've seen it before.Let me think about if for a day.
  7. Patrick Wong
    18,210
    6,517
    I decided to look at the horizontal and vertical signals produced by the HP 1725A, using the Tek 2467.
    The horizontal ramp appears to be OK. The ramp looks more like a triangle at higher sweeps since the fall time remains constant while the rise time approximates the fall time at the fastest sweep times of 10 and 20 nanoseconds.
    The vertical signal is where the problem is. The HP has a vertical output BNC connector at the back, which samples the vertical sync signal produced for use by the horizontal sweep. When I connect the Tek to that vertical output, I can see some (but not all) of the vertical square wave pulses have that little ripple.
    The basic structure of the vertical amp is as follows: CH A and CH B have individual attenuator boards which also provide some signal amplification. The two boards provide signals to the vertical preamp which has a 40 pin square IC that takes the CH A and B signals and produces a differential output for use by the vertical amplifier and a differential sync output for use by the horizontal sweep.
    It appears that the slight signal irregularity is being produced within that 40 pin IC.
    Something else which is weird is when I use the Tek, 1 megohm AC input to measure the differential output at the 40 pin IC, the signal amplitude is around 550 mV p-p at 1 MHz and below. However the signal drops down to 100 mV p-p with a 20 MHz signal. Further, the square wave signal looks like a triangle at higher frequencies.
    I have one P6137, one P6136, and two P6105 probes. All produce similar results. Since the HP vertical amp has relatively flat response over that frequency range (as it is rated to 275 MHz bandwidth) this must be a measurement artifact...
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Any reason why you continue to use that old analogue scope when the digital ones are so readily available nowadays?
    If you want perfection, buy it :D
  9. Patrick Wong
    18,210
    6,517
    1. I don't earn my professional living with this equipment, it is a hobby. Hence I can't see spending more than three-digit amounts for a particular piece of equipment.
    2. I'm trying to see how far I can restore the HP 1725A with a moderate out-of-pocket investment. I had bought that scope in the mid-90s but it has been sitting around unused much of that time. So far the restoration effort has cost around $50 in capacitors plus lots of my time - which is probably healthier than me spending that time drinking in a bar...
    3. Regarding analog vs. digital, I am working mostly on analog equipment from audio to UHF frequencies (communications receivers and other ham radio equipment for example) and I like the idea that the analog scope shows the waveform more precisely. The intensity of the trace varies depending upon the repetitiveness of the signal.
    I recently bought the Tek 2467 because there's some hope that I can repair it when it fails. I wouldn't be able to service equipment containing surface mount components since I can barely see them.
  10. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    My place of business has much nicer equipment than I have, all my stuff is hobby/personal-business use. I figure my time is worth something, so buying a better unit to begin with pays off in the end.
    Good to see you restoring it, but I would only restore it for nostalgia purposes. It usefulness as a scope is diminishing fast. With the digital scopes you can do repetitive triggers, or persistent vision if you wanted. If you are only interested in how often the pattern is repeated and looking at the intensity then the analogue scope seems adequate. But on some scopes you just set up a statistical measurement and it will tell you exactly what the waveform is doing. If it really is a repetitive signal and you want to make sure it stays that way, then setup polygons so that if it ever goes outside of the region you set, then trigger. I just don't see any benefit to an analogue scope that can't be done more easily on a digital scope. And everything is recorded, so if you find something interesting it is there even when the stimulus goes away. That is priceless.
  11. fuzzy1
    10,677
    A hardcore electrical engineer will use both.
    While most of my work switched to digital scopes as soon as they were available, certain items displayed better on the analog scope. It remained on my bench until the failing CRT made it useless.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    I would modify that to:
    A hardcore electrical engineer will know how to use both.
    I have an old analogue HP model very similar to what Patrick has and can make it function. However in the past 3 or 4 years I have never found a reason to turn it on as everything can be done better and more easily with a digital model.
  13. Patrick Wong
    18,210
    6,517
    $12K for an oscilloscope is out of my personal price range given the almost infinite claims upon my income placed by my wife and daughter. I spent ~4% of that amount for the Tek 2467 (which had an original $11K purchase price back in the late 80's.)
    Agilent Technologies Test Equipment - MSO7034B - Oscilloscopes - Test & Measurement - Allied Electronics
    Nice to see though, that you have that model available for your personal use.
  14. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    With all the options installed they easily double-triple that price.
    However, if you keep your eye on eBay, you can find one used for about $6K sometimes. But $6K to $20K is the going rate for a reason. ;)
    It has saved me so much time. It is nice to blast a second or two worth of 1MHz I2C traffic at a device and capture it all in perfect waveforms and have a lister so that you can scroll through and have it decode in hex what data went to what address and whether or not it was acknowledged and so on. Better than counting wave humps and making sure you don't lose count and throw off your value! :)
    Or leave it conencted via ethernet and grap scope shots, control the entire front panel, and send any command, from a world away. One day I had an idea which might solve a problem and instead of waiting until I got home, I just remotely logged in to my PC reflashed the micro, opened up a webbrowser to the scope and made some measurements. Problem solved from 20 miles away.
  15. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Be careful what you ask for. (Humor, not criticism.) If Patrick had done what you suggested, nobody would have gotten to enjoy this thread. As a tool, the ultimate O-scope will be single IC hooked to an HD display. In the meantime, learning how the insides of all that first rate equipment works can be quite worth the effort.
  16. Patrick Wong
    18,210
    6,517
    BTW, a few days ago I bought a Tek calibration station from New York, with the following plug-ins: TG 501 time mark generator, PG 506 calibration generator with 1 nanosecond rise time pulses, and SG 503 sine wave generator. The time mark and calibration generators seem to be the standard for servicing analog scopes of 1980's vintage. I don't really need the SG 503 since I already have two HP signal generators and one HP function generator, but it was part of the bundle.
    Assuming that they work (or that I can get them to work) then I will be fully ready to calibrate those scopes. The eBay photo showed all three units' displays nicely lit up, so there's some hope they are actually functional.
    I also just bought a Tek 2465A at a highly attractive price today, so analog oscilloscopes will be coming out of my ears. It's not clear whether this unit is working but at minimum the horizontal sweep is functioning and the screen shows the correct indications for voltage scale, sweep speed and trigger voltage, so it passed self-tests and at least the infamous U800 horizontal output IC should be OK.
    That unit is similar to the 2467 but does not have the MCP CRT so the HV power supply and the CRT are different. I believe the other components are pretty much identical.
    If I live another 20 years and the Agilent digital scopes of current vintage are still working by then, maybe the going market price will fit my budget...
  17. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Hi Pat,
    We all kicked it around and to a man they all said "caps"...big surrpise right?
    Those old scopes all the caps are going south. All the caps. All of a sudden that gear is 50 years old. Ouch.
    I have a Sencore LC102 which is a delight to check caps with.
    We feel it may be in the triggering decoupling since its only on the first trace.
    Start pullin' & checkin.
    BTW, I keep getting ads & invites for Tektronix concerning there new
    scopes which do Digital, Analog & RF all in one.
    The "Revolution" as they are calling it.
    Tektronix "Scope Revolution" announcement
    Looks pretty nifty. I sure could use one of those at work. Probably see a demo soon.
  18. Patrick Wong
    18,210
    6,517
    Hi Ed,
    Thanks for discussing the situation with your compadres.
    I've replaced around 30 electrolytics (tantalum or regular, as the case may be) on the vertical preamp board; and the three main sweep integrator, delayed sweep integrator, and holdoff-delayed comparator boards that plug into the main/delayed sweep trigger board. However I have not yet replaced any tantalum capacitors on that main trigger board (which also has the horizontal preamp and Schmitt control.) There aren't that many so I'll work on that soon.
    I've recently noticed another problem which may or may not be related: when the AUTO/NORM button is depressed to select NORM, there is not supposed to be a trace until a signal is present. However, on an intermittent basis, sometimes the trace will be there even when NORM is selected.
    I just removed the cabinet to measure voltages, and naturally the AUTO/NORM function is working perfectly right now.
  19. fuzzy1
    10,677
    That too. But not instead.
    Digital models are superior for almost everything. But in two old HP products, there is a certain signal node carrying a huge amount of information where I still wouldn't voluntarily give up the analog scope used during development.
  20. Patrick Wong
    18,210
    6,517
    Time for another update. Richard's msg encouraged me to acquire my latest toy, an HP 8591E portable spectrum analyzer. What an eye opener!
    This provides the ability to explore a new dimension and see a chart of amplitude vs. frequency (compared to an oscilloscope which charts amplitude vs. time).
    I've attached a photo of the analyzer and another showing the clean sine wave signal produced by my Tektronix UHF leveled sine wave generator. All harmonics are ~ 55 dB down (or more) from fundamental. This shows best case, but average is not too much worse.
    The last photo shows the 1 GHz signal produced by my Tektronix TG 501 time mark generator. This signal has a large number of spurious and harmonic signals although they also are ~ 50 dB down or better.
    I sold the HP 1725A oscilloscope. The little irregularity that showed up on the beginning of the trace was just due to vertical amp noise, when the 20 MHz bandwidth limiter is turned on then the trace becomes very smooth.
