Eliminate reverse beeping alarm
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 4sambos, Aug 21, 2013.
  1. Infini
    Infini Member
    169
    30
    Los Angeles
    Can you recommend one? So many to chose from!
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    It's up to you, the ELM327 readers work well. I have the usb version, and others use the bluetooth versions.
    If you get the BT one, you can use it to run the Torque app.
    SCH-I535
  3. Infini
    Infini Member
    169
    30
    Los Angeles
    Oh great! Hmmm how about the iPhone one? I wonder if the app is good.
    Ps: ok no app. Gotta buy them.
  4. 102mm
    102mm Junior Member
    30
    My dealer did that today for me for free. Took all of 5min without an appointment.
    SCH-I605 ? 4
  5. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I've decided to keep my reverse beeps because I had a history of backing into a pole once a decade ago. So, I feel like I can't be too careful.
  6. kramflar
    kramflar New Member
    Allen
    I have a BT ODB2 and the torque app. You say it is easy but and lots of people on the forum say the same but no one says how to do it. I am SO keen to get my UK 2013 Prius to just beep once on reversing. Can you detail what to do please? Thanks.
  7. Infini
    Infini Member
    169
    30
    Los Angeles
    And I cannot find ANY iPhone version nor any iPhone app that will take codes so far. Very frustrating. Last thing I want is to be at the whim of my stealership.
  8. Diver Allen
    Diver Allen Member
    66
    27
    Cincinnati, OH
    2013 Prius v wagon
    It was easy and all the instructions were in a thread on the priuschat forum, however, my device is android and I don't recall any mention of an apple app.
    Here. I just spent 60 seconds on a search and found this.
    JACoH said:
    Nope, did not work on my v2 either. I think this procedure only works on 2009 and earlier.​
    Yeah, that's what I was afraid of.
    To get this to work on the v, check out this thread. Basically, as I understand it, you have three options:
    1. Have it done at the dealership. Some people have gotten it done free, some have had minor hassles, but the dealer CAN do it easily and quickly.
    2. Buy/borrow a Scangauge - nice, but expensive. ($200? IIRC...)
    3. Buy/borrow a ~$16 Bluetooth adapter (ELM-327) and use your smartphone to turn it off. (This is what I did - see post #15 in the thread linked above for more details).
    Read more: http://priuschat.com/threads/turn-the-beep-off.108246/#ixzz2epnBZ4Xv
    Follow us: @PriusChat on Twitter | PriusChat on Facebook
  9. Goin2drt
    Goin2drt Junior Member
    Yorba Linda
    I searched a few "eliminate reverse beeping" threads here and many were outdated so can someone post the link on how to eliminate the reverse beeping as a DYI and not taking it to the dealer? Sounds like a few have done it and it is fairly cheap. Apparently 1 million threads but I only found about ten but they were outdated and didn't help with a 2014 year model.
    Thanks.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In a Gen 3 like yours, you need a OBDII programmer to change the continuous beep to a single beep. The dealer has one, I use a Scangauge II and there are others.
    ScanGauge II ODB Scan Tool + Digital Gauges + Trip Computers - PriusChat Shop
    Some folks have luck with Torque software on an Android device talking Bluetooth to a ODBII dongle, I have not tried.
    Torque Pro (OBD 2 & Car) - Android Apps on Google Play
    Amazon.com: BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY: Automotive
  11. Goin2drt
    Yorba Linda
    OK. Good to know. For $159 I might wait for the dealer ;-)
  12. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If u have Techstream like me, u can do it urself & save the cash for other mods. :D
  13. Goin2drt
    Yorba Linda
    Not sure I know what techstream is. Do share.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    It's the same software that the dealer uses
  15. Goin2drt
    Yorba Linda
    like your avatar would say "doh"
    sfv41901 likes this.
  16. spiff72
    spiff72 Member
    184
    37
    West Michigan
    Check out Carista in the Google Play Store (Android only). It is what I used to change the reverse beeping to a single beep. It can change other settings too. You use it in combination with a bluetooth ELM-327 adapter. You can download it for free (to test with your adapter and find the settings it can see/change). You have to pay the $20 to upgrade to be able to change the settings.
