Emergency (Hot Dam* *t)
Discussion in 'Gen 3 Prius Main Forum' started by Jerry Fletcher, Feb 9, 2022.
  1. Jerry Fletcher
    Jerry Fletcher New Member
    Miami
    I’m pretty sure my battery died I fell asleep in my car with the engine off but the car on.
    Right now with the car in park I’m parked at a McDonald’s and when I press the start button or power button I get nothin…
    Instead of linking me generalized instructions, can a few people answer me based on their specific instructions via a trial and error method I would appreciate it!
    Basically looking for the opposite of an Apple Specialist’s cookie cutter reply on the Apple forums LOL.
    What I’m looking for is the secret of the pros…For Example…Should I Do Something Like…
    - Press & Hold the Start Button for 8 Seconds
    - Pump the brakes x8 times and hold to manually temp charge the battery or spark plug
    - Instructions or short cut to jump the secondary battery
    - Enter maintenance or custom mode and perform a battery reset etc
    ETC….
    …I’M ALL YOURS…
    dig4dirt and mikey_t like this.
  2. ChapmanF
    19,027
    Open the hood.
    Take the cover off the fuse box.
    Find the red flip cover at the top of the fuse box and flip it up to reveal the jump terminal.
    Attach the red lead of your jump pack there.
    Attach the black lead of your jump pack to some nearby car metal (I use the cover bolts on the silvery inverter box that's right next to the fuse box).
    Start the Prius.
    Undo the previous steps.
    mikey_t and jerrymildred like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    So.......what would cause that to happen ?
    Some people leave their's like that overnight.....and fairly often.
    1) A total failure in the 12 V electrical system, causing the battery to be depleted.
    2) The engine runs out of gas.......and then the battery is discharged.
    In either case, there might NOT be a quick fix.
    And since the original post was 5 hours ago, he probably has done something already.
    Hope he reports back.
  4. fuzzy1
    10,710
    No, they don't leave the engine off. They leave the ignition in READY so that the engine can run as needed to charge the traction battery, and the traction battery can charge the 12V system.
    If not in READY, then the engine is off and can't use any gas. The 12V battery can deplete quickly.
    mikey_t likes this.
  5. sam spade 2
    7,035
    2,804
    2017 Prius c
    He said: "with the engine off but the car on."
    I guess that none of us knows what he is REALLY trying to say with that......because that combination really isn't possible under normal conditions.
  6. ChapmanF
    19,027
    If there's a chance that by "on" he meant "on", the condition named in the owner's manual that you reach with two button presses and no brake, then the engine would not have been running, the traction battery would have been disconnected, and the 12 volt battery would have drained.
    mikey_t likes this.
  7. fuzzy1
    10,710
    His Liftback power (ignition) switch can be OFF, ACCESSORY, ON, or READY. He pretty clearly described ON, not READY. From the 2011 Prius Liftback Owner's Manual:
    mikey_t likes this.
  8. ChapmanF
    19,027
    I'll concede that not everybody on PriusChat memorizes the details of the different Prius power states, and so not every poster who says "on" turns out to really mean "ON".
    But when they haven't given much else to go on, at least we can't rule out that by "on" they meant "on".
    mikey_t likes this.
  9. Mendel Leisk
    42,352
    Jump start needed, followed by protracted drive, then charge session and/or replacement (if charging doesn’t do it).
  10. fuzzy1
    10,710
    ... and I just have to read "engine off" as indicating "not in READY mode". Especially after reading his other post about doing some work in the car before falling asleep, and not having the engine cycling on for battery charging during that work.
    #10 fuzzy1, Feb 10, 2022
    mikey_t likes this.
  11. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Let's be real, it was incredibly easy to infer what OP meant and most of us understood. It's funny when someone generalizes while they really are referring to just themselves.
  12. ChapmanF
    19,027
    Did you intend that as a reply to fuzzy1? It looks like fuzzy inferred the same thing "most of us" did, and for about the same reasons.
  13. sam spade 2
    7,035
    2,804
    2017 Prius c
    No, likely that he was referring to ME.
    And it might be a fair statement EXCEPT......
    How many "average Prius owners" really know that there is an ON mode that is different from READY ?
    My guess is 20% or less. Maybe a LOT less.
  14. fuzzy1
    10,710
    While the portion may initially be low, it begins climbing rapidly as they move through the newbie teething problems, such as the car getting turned ON but refusing to actually start and move.
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Agree to disagree.
    I think most will NEVER know any more than they learn in the first week or so.
    I have ownerd 4 Prii over about 7 years and I DO read the owners manuals......at least somewhat......
    and I was unaware of the real "ON" mode.
    Then......just for grins, if you added up ALL of the Prius owners who participate in a forum like this, what percentage of the total owners do you guess that might be ??
    My guess is 1% or less. Maybe .1%
  16. fuzzy1
    10,710
    I can understand that for a short timer or an infrequent poster, but am perplexed how someone making over 8,000 posts over more than 5 years could have missed all the many discussions of it.
    Total U.S. Prius sales have been on the order of 2,200,000 units. Total PriusChat signups have been 172,443.
    #16 fuzzy1, Feb 11, 2022
